smoke Posted October 1, 2014 Report Share Posted October 1, 2014 For a 460? I can fix that up for you. Quote Link to comment
q-tip Posted October 1, 2014 Report Share Posted October 1, 2014 I figured since you turbo everything you might want to boost the hi boy. That has a 429 right? Quote Link to comment
smoke Posted October 1, 2014 Report Share Posted October 1, 2014 428 fe. But no, I think the next huge change I would do is a Cummins. Quote Link to comment
q-tip Posted October 1, 2014 Report Share Posted October 1, 2014 That's what I would do, p pump 24 valve if you want to get fancy Quote Link to comment
Mattndew76 Posted October 1, 2014 Report Share Posted October 1, 2014 no, this does not benifit me directly. Make a cheap fuel injection kit for ac vw. I would have to come study the motor. Then see if I could make a less expensive kit. EDIT: The intake runners could have Injector bungs fitted close the heads, and small fuel rails would be easy to machine up. Unless we are talking an individual throttle body for each port. Quote Link to comment
smoke Posted October 1, 2014 Report Share Posted October 1, 2014 That's what I would do, p pump 24 valve if you want to get fancy I have an 04 here that I am going to use on another deal, but I keep leaning toward wanting in the ford. The old fe is pretty cool though. Quote Link to comment
q-tip Posted October 1, 2014 Report Share Posted October 1, 2014 The fe is cool, if you were to change into would go cummins, but nothing wrong with a good ol' fe Quote Link to comment
smoke Posted October 1, 2014 Report Share Posted October 1, 2014 As little as I actually drive it, the cummins would really just be for the cool factor. The FE sounds really great, I've done some work to it, it hits pretty hard (for what it is). Quote Link to comment
q-tip Posted October 1, 2014 Report Share Posted October 1, 2014 Its cool that its all ford still, nothing wrong with that Quote Link to comment
bananahamuck Posted October 1, 2014 Report Share Posted October 1, 2014 I have been debating putting one of these in my old 55 pickup after i have the front drums turned. Does anyone know who makes a kit to bolt it in?? 1 Quote Link to comment
smoke Posted October 1, 2014 Report Share Posted October 1, 2014 Check tire pressure too. Quote Link to comment
Mattndew76 Posted October 2, 2014 Report Share Posted October 2, 2014 Solid core tires may be needed Quote Link to comment
RTB Posted October 3, 2014 Report Share Posted October 3, 2014 https://www.youtube.com/watch?v=m3J-eVgNQww 1 Quote Link to comment
Burabuda Posted October 3, 2014 Author Report Share Posted October 3, 2014 must have that oil cap 2 Quote Link to comment
datsunfreak Posted October 4, 2014 Report Share Posted October 4, 2014 Repost. A sexy, sexy repost... B) 1 Quote Link to comment
VFR800 Posted October 4, 2014 Report Share Posted October 4, 2014 Repost. A sexy, sexy repost... B) Thanks,repayment here. :thumbup: 1 Quote Link to comment
datsunfreak Posted October 4, 2014 Report Share Posted October 4, 2014 RB30E? Have wondered if that's ever been put into a Z... 1 Quote Link to comment
paradime Posted October 5, 2014 Report Share Posted October 5, 2014 Is this an engine, or a dehumidifier? Too much plastic to qualify as "porn" IMO. I feel much the same way about Lingerie. Why cover up the good stuff? 1 Quote Link to comment
VFR800 Posted October 5, 2014 Report Share Posted October 5, 2014 Is this an engine, or a dehumidifier? Too much plastic to qualify as "porn" IMO. I feel much the same way about Lingerie. Why cover up the good stuff? Re: lingerie - I like my presents wrapped so I can open them.... Quote Link to comment
