Alleycatgarage So Cal shop
  • Replies 313
I am weak ! got this in for repair and was getting towed from buddies apt. and already am buying , due to cost of repair is much has not driven in 14 yrs-1981 Corolla 2dr notch 5spd.two dings on whole car ,another time capsule. Also another car porn shot of my car at night ,and last is my dream for shop a spray booth on trailer.104_1869.jpg104_1870.jpg]104_1866.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_1861-1.jpg.html]104_1861-1.jpg
Car had sealer on it, no filler there ! and paper thin plastic in rear quarters ( where someone bumper tested and cracked my lower section ,makes altogether three sections to re-paint ) and in doors a little only, but my stuff never gets done ! my car has cut window rubber gaskets from paint project, cause I need new ones.
  • 1 month later...
Have much construction going on !The roof had to be raised and was made with surplus junk when first erected ,so now is 11 ft for clearance for spray booth ,here are a few oics of construction ,and is not cheap ,have an electrician willing to wire up my lower yard panel ,I need to paint his striped 911 shell later ,and the 521 blue truck is my shop truck for sale ,due to bought red one for new shop truck getting z20 with SU's and 4wheel disc brakes and a fresh red paint job soon ,has no rust holes and check out mini trucker mirrors I may leave them , have not posted for a while try and post weekly have three paint jobs waiting for booth,have a tech starting soon maybe thur.104_1951.jpg104_1954.jpg]104_1965.jpg104_1967.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_1962.jpg.html]104_1962.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_1964.jpg.html]104_1964.jpg
The red truck looks so good in floors had 2" thick possum shit and bones from small animals in it paid 600 for no brakes and not running no radiator or grille and feel I got a nice body near rust free my other one has small amount of rust but Lt blue is nice and running driver should sell quick , had to post sick hood on 610 Zerow's car.104_1960.jpg104_1919.jpg100_1660.jpg We still have weird radio here some of you may like respond back if you like it ,it is safe no spam hit indie1031.com
104_1970.jpg 1960 Dodge Dart Phoenix slant six push button auto. ,Reminds me of Christine car ,I was going to paint gold with white roof ,now my customer is moving (to UK)wants out of project as is,  I may take to car swap at Pomona Ca.10-20-14 and try and move it.
WANT!!!!!
I have a weakness for Forward Look cars......
 Hi out there ! here is some stainless hoses for a cust. fuel lines for LS1 Camaro (these are crimped SS  hoses -the 56 in oic is in my garage and other 620 I sold 3 trucks ago)
Hi Louie from N.H. when you come out I will let you drive 510 sr20det , last time almost 10yrs ago I let you drive my  rhd Silvia out for Mexican food ! with Norm and guys remember ? that car was faster than my 510 ,you need to come out and see your family.[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_1985.jpg.html]104_1985.jpg
Re. pwr steer hoses , I have a cust . that restores early bronco's with a Nissan pathfinder pumps ,both are inverted flare fittings 16 & 18 mm, the pressure is the 16mm I believe with a 5/16 metal line I make about 4" then I weld on a #6 AN to tube this allows infinite adj. and you use #6 straight swivel fittings on a hose to pump side another #6 weld on pump fitting,return is easier ,18mm also inverted fitting comes 5/16 ,I drill out to 3/8 flare tube and put hose clamp bulb on other side for clamps or I can weld another #6 and put swivel fittings ,I will try and post a pic of fittings.
1960 Dodge Dart Phoenix slant six push button auto  ,I was painting is now almost mine , my buddy went to UK and left his car , anyway the lien starts soon  ,anyone with interest in a RARE  boat with new mtr, please speak up.It was going lt gold with white roof ,runs and drives.104_1970.jpg
  • 3 weeks later...
Anyway Happy T. day I am at my shop re-assembling my car, I drive my car daily  !, had cracked exhaust -got welded ,bad u joint on axle -swapped out a used one, rear differential has been sticky and clunky ( Nisssan comp 160 locker) so I tried an lsd 85-140 Valvaline  with additive from napa ,8$; toothpaste tube ,rear brakes grooved  and winey ,turned rotors and remove caliper shims ,Also had small oil leak at rear center of turbo ,I smell sometimes  ,also my 1st sr swap and look at turbo feeds with hoses , I may change to all hard lines and at that time I pulled my oil pressure line from turbo oil feed , fuel pump and 3/8 ss,and look at my low oil pan ,ouch ,.Anyway you do things different  after you have done a few ,my car is getting a freddy copy intake soon ,reasonable and better performance upgrade .Orange car was a drive by.104_2028.jpg104_2031.jpg104_2033.jpg104_2030.jpg
  • 3 weeks later...
Here is a couple of shop shots ,trying to thin my herd so I can build booth and hire a bodyman/tech ,that is a Mercedes grill in 1960 Dodge ,and my drivers on street in front of shop.Hey Louie are you coming down for xmass from NH. Maybe New years day waffles at pad !
104_2057.jpg104_2052.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_2056.jpg.html]104_2056.jpg
  • 1 month later...
NEED TO HIRE a swap / brake mod TECH please apply ! Been a while ! here is a VW Vanagon with Subaru 2.5 JDM mtr, with bell housing adapter ,I cut and modded Sube AC tubes to VW factory hoses due too much work to change full length to roof ac so I crimp in engine bay left rear side in car ,I have done about four of these mods ,other oics of shop all turned over junk ,moved box container , 104_2095.jpg104_2094.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_2097.jpg.html]104_2097.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_2097.jpg.html]104_2097.jpg.html
Sold Olds posi , was too wide and different bolt pattern , so now keepin Sedan Delivry , welding in skirts and painting soon , here is my 2" drop from stock height was raised like 6" from previous drag race guy,I lower oldschool by re-arcing leafs , measure arc at beginning was 5.5" after press job 3.5 on #2 leaf so I pressed total of three leafs ,press two at a time tapped together about every 4" ,for more flatter so no blocks needed ,removed one long leaf and bottom leaf added a DATSUN 620 overload stiff bitch leaf .I want a pro tour style handler so I installed a stiff leaf for cornering when gets into body roll beast ! , also found some old Mullholland shocks in my container,air and oil no gas bs , next step 2" drop spindles and some disc up front. Needs 500 more for parts.104_2111.jpg[104_2112.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_2113.jpg.html]104_2113.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_2115.jpg.html]104_2115.jpg[url=http://s1183.photobucket.com/user/Alleycatgarage/media/104_1669.jpg.html]104_1669.jpg]
oooo is it complete? ill trade my 56 chevy pick up for it
