sick620 Posted March 16, 2013 Report Share Posted March 16, 2013 What are your top 5 favorite mods that can be done to a 620? Example: 1. front air dam 2. yellow fogs 3. aftermarket steering wheel 4. wink mirror 5. no hooks... Quote Link to comment
datzenmike Posted March 17, 2013 Report Share Posted March 17, 2013 Matchbox dizzy (never have to replace/set points or timing again, better starts) KA hgh volume oil pump (more pressure at low speeds, more volume if running a spray bar) Internal regulated 90 amp KA alternator (run the largest sub and amp you like and extra headlights) Gear reduction starter. (simply because I like the distinctive sound it makes) Mid 90s MonteCarlo rear view mirror. (button mount on inside of windshield, Has two handy map reading lights with switches, can be connected to door switches and used as a much better interior light) 1 Quote Link to comment
Jayden71 Posted March 17, 2013 Report Share Posted March 17, 2013 Well I dunno bout a 620 but for a 521 EI dizzy Hi volume oil pump dogleg 5 speed good carb higher output alt oh and number 6.....just having my Datsun dependable is a great mod for me! :thumbup: all these require no cutting of truck. It still looks stock and cool as hell 2 Quote Link to comment
Wide14u Posted March 17, 2013 Report Share Posted March 17, 2013 mike i want to see the map light and mirror Quote Link to comment
Pacific coast Datsun Posted March 17, 2013 Report Share Posted March 17, 2013 1 permanent convertable 2 flowmaster 40 muffler 3 EI dist. W/ hei module 4 weber carb 5 88 sentra bucket seats 2 Quote Link to comment
Siqx20 Posted March 17, 2013 Report Share Posted March 17, 2013 Weber Lowered Shaved handles Yellow highs Stainless vent shades. Quote Link to comment
datzenmike Posted March 17, 2013 Report Share Posted March 17, 2013 mike i want to see the map light and mirror Ha ha I guess I stole from my 620 and put it on my goon. Anyway heres through the windshield... ... and looking up from under. The map lights shoot down in front of the dash and light up your lap. You can drive with them on unlike the roof mounted interior lamps which light the whole cab. Haven't wired it yet but they will light with the door switches and you can manually work L & R as a map reading lamp. I think this was in a MonteCarlo but the Lumina has them also. You have to get the special glass mounting epoxy to hold the metal button and the lamp just screws to it. . 1 Quote Link to comment
darrel Posted March 17, 2013 Report Share Posted March 17, 2013 The button mount rvm is getting to be a necessity for most datsuns. The sun has really done a number on my zx plastic. Quote Link to comment
Wide14u Posted March 19, 2013 Report Share Posted March 19, 2013 mike i went out and got me a mirror mike i hope you don't mine 1 Quote Link to comment
sick620 Posted March 19, 2013 Author Report Share Posted March 19, 2013 woah, strong language! Quote Link to comment
DeviousPsycho620 Posted March 19, 2013 Report Share Posted March 19, 2013 1 ka swap 2 5 speed trans 3 disc brake conversion 4 rims 5 refer to #1 1 Quote Link to comment
converted_to_datsun Posted March 19, 2013 Report Share Posted March 19, 2013 Not in order but... 5 speed swap lift or lower wink mirror Add all the factory options (intermitent whipers, tach, disc breaks, ect) Build up the L motor (peanut head, flat tops, su's) I'm sure i'd fall in love with a dual cam ka swap... which is why i must never ride in one haha my wallet would never be the same Quote Link to comment
]2eDeYe Posted March 19, 2013 Report Share Posted March 19, 2013 1. Disc Brakes 2. Lower (or SAS for 4x4) 3. KA swap (or 5-speed swap if the L is in good shape) 4. Good seats 5. Stereo Quote Link to comment
q-tip Posted March 19, 2013 Report Share Posted March 19, 2013 Disc brakes Weber Ei Ka alternator Lower or lift Quote Link to comment
slayer510 Posted May 29, 2013 Report Share Posted May 29, 2013 "flowmaster 40 muffler" only if your not looking for perfomance out of your Lblock. I use to think flows were all that and had one on my dime. At that time I built my first L22 with a decent cam,big valves,dual 40's,unilight dizzy,nissan comp header,2 1/4 exhaust and a flowmaster and after it broke in I was disapponted that I had an engine that ran flat at 6000 rpm. After a few weeks driving like that ifor whatever reason decided I wanted to try a magnaflow,to my amazment gained an extra 1200rpm of useable power. It now felt like had expected and used 7200rpm as ashift point when I was gettin it. Just my 2 cents. Quote Link to comment
KA620KC Posted June 4, 2013 Report Share Posted June 4, 2013 1) Ka swap 2) Full independant suspension swap 3) Stereo 4) Tint the windows 5) Refer back to #1 (converted to datsun, you gotta go for a spin at least once !!) Quote Link to comment
red76datsun Posted June 4, 2013 Report Share Posted June 4, 2013 1). weber 2). el 3). disc brakes 4). new shoes 5). nice bench B) Quote Link to comment
converted_to_datsun Posted June 4, 2013 Report Share Posted June 4, 2013 1) Ka swap 2) Full independant suspension swap 3) Stereo 4) Tint the windows 5) Refer back to #1 (converted to datsun, you gotta go for a spin at least once !!) Haha as long as I don't drive it I might still be happy with my L20b, I have a peanut head, 5 speed, 4.11s, and 38mm su's so it ain't exactly slow haha 1 Quote Link to comment
izzo Posted June 4, 2013 Report Share Posted June 4, 2013 Louvers. Mopar shifter Shaving it Wrecking it and getting a different datsun 1 Quote Link to comment
Guest Rick-rat Posted June 5, 2013 Report Share Posted June 5, 2013 Cut the top off remove mirrors throw away seat belts discard muffler Put in a big ass speaker with tons of bass, so we can feel you coming 3 Quote Link to comment
q-tip Posted June 5, 2013 Report Share Posted June 5, 2013 Ha! Rick made a funny :lol: 1 Quote Link to comment
Brad's 510 Posted June 10, 2013 Report Share Posted June 10, 2013 1) slam it 2) build an L-16 (11:1, 219 head, 45 Webers, Howard's cam, nitrous) 3) shave handles, weld up seams, tailgate 4) convertable w/o kit 5) 3" chop top got a 510 to drive while doing the body mods, put motor in 510, lost interest in 620, got married, had kids, 15 years later, body/frame got hauled off for scrap. Kick myself everyday for letting that happen. Still have all the powdercoated disc brake suspension parts & new susp. pieces sitting in a box in the shed though. Quote Link to comment
DaveyDaveDaveDave Posted December 6, 2013 Report Share Posted December 6, 2013 Havent seen yet... 1. Remove stock side mirrors 2. Flatten stock valance (they came stock all fucked up, far as I can tell) 3. SEEAAAAFFOOOAAAAAMMMM!!!!!!11!!!!!!1 (not really. Im a Marvel man, myself) 4. Top up fluids that have gone unchecked for six years 5. foil around fuses Shit. I need six. 6. Splice in miscellaneous pieces of wire that go to nothing. Wrap in dollar store electrical tape. Quote Link to comment
