skyblue Posted February 16, 2016 Author Report Share Posted February 16, 2016 Steered hearing an exhaust leak recently. The culprit. Changed it out and much better. But it still leaks slightly. Annoying, but at least it's much quieter. Quote Link to comment
mattyhacks71 Posted February 16, 2016 Report Share Posted February 16, 2016 I have the same problem, brand new gasket but still leaks. I even did my best to grind the flange down flat 1 Quote Link to comment
skyblue Posted February 17, 2016 Author Report Share Posted February 17, 2016 New emblem 1 Quote Link to comment
Anonymous Waffle Posted February 17, 2016 Report Share Posted February 17, 2016 Steered hearing an exhaust leak recently. The culprit. Changed it out and much better. But it still leaks slightly. Annoying, but at least it's much quieter. Is that the gasket that comes with the metal rings around the inner exhaust pipe? I had to remove the rings on mine in order for it to have clearance, and that caused it to leak after about 1k miles later. Quote Link to comment
Draker Posted February 17, 2016 Report Share Posted February 17, 2016 Also if your exhaust pipe doesn't angle towards the manifold correctly.. the mating surface will not be even. Pressure on one side would cause a leak eventually. Quote Link to comment
skyblue Posted February 17, 2016 Author Report Share Posted February 17, 2016 My exhaust hangs a bit low cause of a broken hanger at the rear crossmember so in thinking that's the problem. 1 Quote Link to comment
hobospyder Posted February 17, 2016 Report Share Posted February 17, 2016 New emblem the rest of the car needs a bath now, that one spot no longer matches 2 Quote Link to comment
skyblue Posted February 17, 2016 Author Report Share Posted February 17, 2016 haha. yea she's kinda filthy. been trying to do my part with this damn drought and all 1 Quote Link to comment
4perrev Posted February 18, 2016 Report Share Posted February 18, 2016 Clique, but Honda polish works wonders on dirt, tar and ugly people!! 1 Quote Link to comment
skyblue Posted February 22, 2016 Author Report Share Posted February 22, 2016 Got some stuff done today. Photo dump New filter. Finally. K&N And 510T let me borrow a 195/50R15 to test fit on a 15x7 +0 wheel cause i want to get some race tires in that size. Front Findings: the 195/50R15's clear the rear no problem. Up front they rub the fender some. But do-able. And for hobo 4 Quote Link to comment
4perrev Posted February 22, 2016 Report Share Posted February 22, 2016 Sweet looking. So jealous of the Weber! I need to buy me a set, when I get the car ready to drive, but still a ways off! Don't you get water inside with the wells cut? Quote Link to comment
skyblue Posted February 22, 2016 Author Report Share Posted February 22, 2016 Thanks. Pretty happy with the weber. In the trunk a little I'm sure. But in the back no cause the hole is outside the weatherstripping. Quote Link to comment
hobospyder Posted February 22, 2016 Report Share Posted February 22, 2016 Nicely done sky, looks good Adding motivation to my already wanting to be home brain too, thanks 1 Quote Link to comment
shacks510 Posted February 22, 2016 Report Share Posted February 22, 2016 Damn. I need to pick up a stock body 510 so I can have the joy of playing with all the factory Z wheels. Quote Link to comment
skyblue Posted March 1, 2016 Author Report Share Posted March 1, 2016 Took a trip to Eugene this last weekend and noticed a rattling sound in mid 2000 rpm. Turned out it was my velocity stack. The new air cleaner assembly made enough of a gap leaving the stacks loose. My solution, Zip tie pieces on the clamps. 3 Quote Link to comment
mattyhacks71 Posted March 1, 2016 Report Share Posted March 1, 2016 Another fix would be ditch the air filter and just have sweet looking stacks ;) 3 Quote Link to comment
r0p0doe Posted March 1, 2016 Report Share Posted March 1, 2016 Another fix would be ditch the air filter and just have sweet looking stacks ;) I 2nd that motion 1 Quote Link to comment
Duke Posted March 2, 2016 Report Share Posted March 2, 2016 Or leave the air filter and go with bolt on stacks. Not running an air filter on a street car is not the smartest thing IMO. 2 Quote Link to comment
skyblue Posted March 2, 2016 Author Report Share Posted March 2, 2016 I've had no filter since the engine was rebuilt. But I figured since I DD this bad girl I probably want to avoid anything bad getting in there to fuck shit up. I'll take it off For track days and autocross. I didn't even consider bolt on stacks. Thx. 1 Quote Link to comment
KoHeartsGPA Posted March 2, 2016 Report Share Posted March 2, 2016 Ya don't run without filter in street use ;) Quote Link to comment
mattyhacks71 Posted March 2, 2016 Report Share Posted March 2, 2016 Ya don't run without filter in street use ;) If you live in the desert maybe! I ran without a filter on my E7 Corolla for like 4 months and it was still spotless Quote Link to comment
Lockleaf Posted March 2, 2016 Report Share Posted March 2, 2016 Banged a girl without a condom and didn't have a kid. Doesn't make it a good call. It means you got away with it. 6 Quote Link to comment
KoHeartsGPA Posted March 4, 2016 Report Share Posted March 4, 2016 If you live in the desert maybe! I ran without a filter on my E7 Corolla for like 4 months and it was still spotless How are your cylinder walls and valve seats looking? Get a go pro put it aiming at carb, drive for a day around town & freeways and get back to us :thumbup: Quote Link to comment
mattyhacks71 Posted March 5, 2016 Report Share Posted March 5, 2016 Probably terrible. I'll blow my motor up before any of that causes problems though Whats a freeway? 1 Quote Link to comment
