Doty (Deal of the year)
skyblue
  • Replies 1.9k
Installed a 1 in. sway bar on Saturday.
DD7F60A9-7D5D-493A-A5E4-75CE135C5B63_zps
DACCD73F-FC64-4E58-9C54-131A435116A7_zps
Install was kind of a bitch cause I used these bushings and the holes did not lineup with the frame holes. So I had to hack them up.
DD781C74-ECCB-406D-8614-D59E1477BD4C_zps
Made it work with some help from tendril.
L just don't pump out what ka do power wise. Unless you throw outrageous amounts of $$. Plus I like the mpg's and cold starts ease
I bet you'd get about the same mileage with an L20 with a well tuned single side draft as you would with a KA. It'd probably be easier to find bigger L stuff than doing all the work for a KA.
I do remember Antony saying he wants to put his matching numbers L16 back in his car. Take his 2.2 :p
How are you gunna get good mpg and easy cold start when you're throwing carbs on the ka?....... ;)
Haha. Carbs would be sweet. But I'm gonna keep it EFI.
Mileage yes. But power I don't think so. ;)
went to the pick n pull to get these.
98A7F528-58D6-4939-AC69-386150A4C6B5_zps
and found and bought this
012B2FC4-53A9-4B58-9F7F-49BE59D01A1E_zps
https://youtu.be/t7qIOqA7xEE
collecting parts for the KA swap. Just need the engine, ecu and harness now. lol
I have a spare ecu, maf, and a few other stuff if i look laying around, put some on craiglist and ppl hitting me up, let me know what u need, ill stall them so u get 1st dibbs
Cool. Thanks for your input.
Did some more track prep yesterday.
Weight reduction. Lol
ED8FCD82-ED76-49EF-BC97-9D8375EED052_zps
Fucked with the carb and checked tire pressure.
B77686ED-D921-4B88-81C0-E49241AC3209_zps
Wrapping it up for the night.
87F166C5-D4BA-4AFD-88CE-ADEA01087D87_zps
  • Like 3
  • 3 weeks later...
Small update.
I was cleaning out my carb a week ago for the fun run and noticed I had mix matched pump jets
3CF9F719-5FF2-4091-8405-776E957F9F6D_zps
Rag10 had a pair of 45's so I put those on. But I felt a loss of power.
58748EFE-4B02-43DD-B695-1152CC790EE7_zps
Couple of fun run pics by kawagon
When we got back to the shop I found the other mix matched set of pump jets. I guess I fucked up the jetting when i was setting up the carb. So I put the 50's in. Feels muck better with the 50's.
  • Like 3
Yesterday i changed out my alt cause it started making noise. Bearing started taking a shit. Kind of a bummer cause the old alt was only 11 months old in my car.
D97A5EDD-F82D-4D8D-A342-A2FC31184C89_zps
Also put the snowflakes back on
850843D7-FDD8-4C92-AE3D-D0D90BC0B0F6_zps
420039FF-F38C-4DD4-A96D-128975B0DA31_zps
And did some more carb tuning. I swapped emulsion tunes from F15 to F11
30A01883-CDCD-4267-AB03-7029816F3171_zps
  • Like 4
