Doty (Deal of the year)
skyblue
  • Replies 1.9k
Thanks!!
So I spent all morning and early afternoon driving around looking for fittings fir the fuel system. Mostly a tee for the pressure gauge. The gauge has an 1/8 in. Fitting but the fuel pump and regulator have 3/8 in. Fittings so I needed n adapter.
Started out with this monstrosity
C34EA21C-B339-49F2-935E-7949A3B1F32C_zps
Then found a single adapter and looks a lot better
1AD607C6-13D2-4041-A077-972A44269C76_zps
wow L motors are die hards no proper oil and it lived
where did the flat tops come from
is that an L16   never m,ind I looked back at the freshly painted motor and it is clearly an L16
and flat tops are not stock
Yea that's what I said. Starved of oil and still going. Love these L engines. The flat tops where in there already. Just cleaned them up. This engine was already rebuilt once it seems so I guess the PO put them in. What was stock on L16's? Do flat tops give you moar power? Higher compression?
yes and yes dished were stock in the L16
There's a speed shop in Petaluma that can get or stocks all that stuff (plumbing), Larsen Racing on Lakeville.  They are cool :thumbup:
Sweet! Thx I'll check them out.
Mocked up the carb to figure out the linkage.
5A55CEDC-25E0-4AA7-B023-1641BAF64B6B_zps
Close up
52278FA4-93C4-4496-883A-222360591621_zps
Worked on that today and cleaned up the wiring harness.
That looks real good,now change the bolts and bead blast the manifold.
Just take it easy there turbo.......when you do the work yourself it takes longer........... :rofl:
Close up
Single sidedrafts are sexy as fuck. That's on a list of things for me to do. Good build man. Love the colors you chose for the motor! SEXY!
