medengines Posted October 12, 2012 Report Share Posted October 12, 2012 if i can send this! this is 12.7 at 112 mph..shitty video quality but it is sound!! <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1242.photobucket.com%2Falbums%2Fgg523%2Fmedengines%2FMOV00292.mp4"> Quote Link to comment
Stoffregen Motorsports Posted October 16, 2012 Report Share Posted October 16, 2012 1 Quote Link to comment
FiveSeventyZee Posted October 17, 2012 Report Share Posted October 17, 2012 jesus....some of these bays are so clean....makes me want to keep my hood down... :/ 1 Quote Link to comment
Sealik Posted October 17, 2012 Report Share Posted October 17, 2012 LZ23..... Noticed an improvement in WOT....... and top end after I installed some 'horns' Not advisable in rutting season............. :lol: Quote Link to comment
Dawa Posted October 18, 2012 Report Share Posted October 18, 2012 i spent all weekend cleaning up and reducing the amount of wires in my engine bay, through this process i learned that it used to be an automatic. before: Quote Link to comment
Tristin Posted October 18, 2012 Report Share Posted October 18, 2012 Dawa, you forgot the after pic. Quote Link to comment
Stitebunny Posted October 18, 2012 Report Share Posted October 18, 2012 Very nice! Can you explain the breather setup? Quote Link to comment
Dawa Posted October 18, 2012 Report Share Posted October 18, 2012 ^ Stitebunny , looks like theyre just connected to a catch can. even though i spent all weekend just to get it to this point (learned what wires are what, and how to solder) it's still at least a day's worth of work from being done. Quote Link to comment
bananahamuck Posted October 18, 2012 Report Share Posted October 18, 2012 I thought it deserved a little bit more enthusiasm 2 Quote Link to comment
H5WAGON Posted October 19, 2012 Report Share Posted October 19, 2012 A little dirty from a oil leak that I just fixed..(Fuel Pump) and I just got my flange for a new down tube to fix my exhaust leak. My daily Datsun fix. Quote Link to comment
CharlieW Posted October 19, 2012 Report Share Posted October 19, 2012 Here it is before the top end rework...I will get another picture tomorrow of it as it stands now. Quote Link to comment
elmerfudpucker Posted October 19, 2012 Report Share Posted October 19, 2012 ^ boy, that looks familiar! ^ Quote Link to comment
dimeguy 510 Posted October 20, 2012 Report Share Posted October 20, 2012 Posted this on Valve cover thread but rising sun radiator cover is new. Enjoy!!! :) :) 1 Quote Link to comment
Creepy Cruiser Posted October 20, 2012 Report Share Posted October 20, 2012 Very cool. Quote Link to comment
Stoffregen Motorsports Posted October 20, 2012 Report Share Posted October 20, 2012 Very nice! Can you explain the breather setup? It's a baffled reservoir that has a hose coming into it from the valve cover, a hose going out to the side of the block (so the oil that spits out of the valve cover can drain back to the block), and a filter on the top because you gotta have a filter somewhere! The big bore motors tend to spit oil at high RPM and I was sick of having to drain the catch can, so I devised a system so it would drain back to the block. I tapped the side of the block to 3/4" NPT to accept a -8 nipple. But I have done it before with a press and epoxy in fitting before too. Quote Link to comment
Tristin Posted October 20, 2012 Report Share Posted October 20, 2012 What type of baffling are you using? Plates or unravelled "brillo pad?" Quote Link to comment
Dawa Posted October 21, 2012 Report Share Posted October 21, 2012 i might have to borrow that idea, stoffregen Quote Link to comment
EricJB Posted October 21, 2012 Report Share Posted October 21, 2012 Mine does the same thing. It just isn't as pretty. There is a steel tube that goes around the back of the block and under the header to the breather hole in the block. Right now it's getting a moroso crankcase evac in the exhaust down tube, so I might ditch this and build something else. It never dumped any oil on the ground, but I'm not sure how good it worked. Quote Link to comment
Tristin Posted October 21, 2012 Report Share Posted October 21, 2012 I've been thinking about making a setup like that too... I have all the pieces needed at work already. Maybe I should make a couple if you guys need them. Quote Link to comment
EricJB Posted October 21, 2012 Report Share Posted October 21, 2012 i think it's important to keep some sort of vacuum set up intact. The stock pcv set up draws from the block, and pulls air in through the valve cover. Without that you will have to change the oil more often. I change my oil every 10 passes anyways, Quote Link to comment
Tristin Posted October 21, 2012 Report Share Posted October 21, 2012 Unless you're doing strong autoX or drag passes, very minimal oil goes through that system. I know plenty of people running vented PCV systems instead of vacuumed. They never have any issues. The trick is having a good can with a good internal filter/separator. An empty can is worthless... Quote Link to comment
72240z Posted October 21, 2012 Report Share Posted October 21, 2012 Unless you're doing strong autoX or drag passes, very minimal oil goes through that system. I know plenty of people running vented PCV systems instead of vacuumed. They never have any issues. Can add me to that list. Even with prolonged high rpm driving I never get a drop. So I just leave everything vented. Quote Link to comment
Stoffregen Motorsports Posted October 21, 2012 Report Share Posted October 21, 2012 i might have to borrow that idea, stoffregen Be my guest. Quote Link to comment
