Sign in to follow this
allen dodson
datsun 521 king pins
Hi went to have the front end allined and they wouldnt do it because they said it needed new kingpins. Were do you buy them and should i have a shop put them in?
Share this post
Link to post
Lame...
Try rockauto.com
Replacement of the kingpin is about a 3.5 bannana :D
Share this post
Link to post
2eDeYe;53385']Lame...
Try rockauto.com
If Rock Auto doesn't have it.
Try this guy in Ebay
http://cgi.ebay.com/ebaymotors/Datsun-520-521-New-King-Pin-Repair-Kit_W0QQitemZ280201375960QQcmdZViewItem?_trksid=p3286.m20.l1116
I got 2 from him 3 months ago for only $16
He raised the price more than double now.
Or upgrade to a good used 620 spindledog bone assembly.
It's a lot of work to replace those king pins.
Search for Mike's write up on king pin replacement.
Share this post
Link to post
I have a kit in the back of the Suburban, the 521 now has 720 ball joints. $20 shipped, let me know.
Share this post
Link to post
Correct, 78 & 79 use ball joints.
Share this post
Link to post
woot, i win again!!! doess the 78 have disc too? i thought they didnt and the 79 only had the upgrades....
Share this post
Link to post
Looks like rockauto doesn't have these any longer. At least I don't see them listed for a '70. Now that I think of it, I'll go check for other years.
I'm curious about the 620 'dogbone' upgrade. Is there a thread on that here somewhere?
Share this post
Link to post
I can't find said thread. I did search.
Share this post
Link to post
'78 first year front discs, ball joint, EI distributor (other than California), internal regulated alternator. The same discs were used through '82 at least on the 720.
859_KP1t.jpg[/img]
Edited by datzenmike
Share this post
Link to post
The thread was actually a Hainz thread and I'm pretty sure it was on NWDE....I don't know if it's been transferred over to here or not......do a search of threads that Hainz(banzai) has started and see if it pops up. That would probably be easier than sorting through a 1000+ posts of mine :)
You'll want to get a fixed price if you're paying somebody else.....if they run into trouble, it could easily jump the price drastically. Ask them if they have the correct reamer....the bushings have to be reamed after they're pressed in.
That's a good suggestion on finding a 620 with decent spindle/kingpins.
Share this post
Link to post
Didn't find it in the NWDE archive. Are you suggesting using a '78< spindle w/kingpins? What would be the advantage? It's still kingpins, right?
It doesn't look like the 620 control arms are a direct bolt in for the 521...
This is good info here re: swapping/removing 620 pieces
http://forum.ratsun.net/showthread.php?t=2082&highlight=dogbone
Edited by nukeday
Share this post
Link to post
I guess you needed to dig a bit longer and harder.....took about 30min to find it :(
The first page of the archived site has all the pics, but missing pics on page two. Once I found the thread name had a space and an "s" at the end, I was able to find it on nwde.....where it has all the pics :)
http://ddgonzal.members.winisp.net/nwde/4234.htm
http://www.nwde.org/extras/forum/forum_posts.asp?TID=4234&KW
Share this post
Link to post
So yeah you guys might be mad, I tossed ALOT of stuff From my build. What is the point of this post?.. Knowledge is everything.. I do still have the original cluster, gastank, outside and a few of the inside door handles, and some of the wireing harness.
I wish I knew there was a need for it.
Share this post
Link to post
Thanks Mike, my search skills leave something to be desired. It's like I'm 'search string impaired'. Appreciate your digging this up, when does the 'newbie' thing wear off? ack...
Share this post
Link to post
olddatsuns.com has the write up and others
True, but it's just a link to NWDE.org. I -HIGHLY- recommend putting that info elsewhere as the NWDE.org forums -WILL- go bye-bye this year.
Share this post
Link to post
I own it....can't hardly say I run it since Dave still does any of the changes....I have no clue!! :)
ddgonzal's site has all the info archived. Maybe we can at least get the links switched around. I'm hoping to figure out the webpage stuff so that I can start posting the "how-to's" straight to olddatsuns, instead of the forums.
Share this post
Link to post
A fellow was asking me if his (new to him) 320 truck has king pins and if they are interchangeable with the 520/521 models?  I don't think they are or not sure if the 320 even has king pins?  Anyone know?  thanks.
Share this post
Link to post
Go to YouTube, search blue hands king pin. He's got a few videos on them. Thank Mklotz
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
