74 620 V8 AutoX
Cpl620
  • Replies 508
 question: should i make the trans tunnel bigger to tuck the exhaust, or should i run it bellow the bracing? it will be about an inch lower than the frame, and probably scrape where ever i go...
What about tucking your exhaust just enough to be above the bottom frame rail? This would lessen the intrusion on the inside.
EDIT: Went back a couple pages to get a better idea of what your looking at. Are your X braces welded in the center of the frame rail? Seems that will be about the limit for tuck.
  • 3 weeks later...
Nah, I started the exhaust a little more that what is there. I ran out of money for now and school started back up. The only problem with running it on top is im running an X pipe so it would get in the way some way or another. Later ill go with a trudual exhaust and run it through the tunnel. No updates right now. Things left to do are finish the exhaust. Redo the clutch, run wiring, build the tunnel and fire wall, run cooling system. A few cuts to fit fenders and bed. Then tune the thing.
Hey man, it can wait. Just concentrate on your school work. Right now is the perfect time to take a break from the build and just think about what you want to do next break.
While you are daydreaming in class about it though, consider doing the exhaust and tunnel the way you want and do it first.
Really digg'n the build man.  :thumbup:
  • 4 weeks later...
wow, almost 2 months since I've touched this thing. its just been sitting in the driveway collecting dust. learning Japanese and Math is hard foo! plus i started training for the Crossfit games...and started playing a new online game...but im broke, so yeah.
Drive shaft is on order on Oct. 1st then its just small shit and me actually having time to finish up the small remaining crap. lots of cutting more than anything. only welding left is on the exhaust and making mounting points to clip the front end to. shit, i forgot i have to make a new shifter assy. fml.
  • 1 month later...
So i got to work on the truck a little today. i had to pull the engine, take apart the clutch and re-mic everything for the proper bolts and crap. took most of my time, so i just cut the front up a little to put it back on and start looking like a truck again. Also bolted up the Drive shaft. the engine actually looks kind of small with the front end on and the fender wells cut out.
1982186_795715377140752_1216492602789135
1908455_795524947159795_3916254854655144
10635736_795625323816424_298956607962811
  • Like 9
  • 3 weeks later...
Thanks teague, its feels like its been a long time coming, but this build is actually going pretty quick all things considered. Another week and a half of school and then ill be back on it full time. There is a local show on the 13th so ill be towing it out. I expect start up before the end of the year. Im out a computer right now or I would upload pics, they're just sitting on my phone. This exhaust is harder to make than I thought. Should of figured....hahhaha.
Too much text, not enough OICs.
half my remaining supply of pie cuts. along with how much pumpkin pie i ate over the last two weeks, i dont want to see this shit for a while...
10801618_805399412839015_505929554875665
my welder decided it wanted to play "just the tip" shit got really annoying. reason #2 for headder wrap right? to hide more heinous welds.
10806258_805399552839001_482949309288822
passanger
10361303_805399242839032_472596270223720
10523285_805399269505696_803037733853550
10151170_805399296172360_326835504339041
Driver
10806459_805399362839020_877354628081212
10696288_805399389505684_133525152833287
my retarded placement on my X-pipe, as well as its hook up. oh well. this is going to be redesigned with the new engine down the road.
10420752_805399132839043_827711770133994
Corvette dont have shit one me!
10370962_805399222839034_860996031902013
10470606_805399196172370_571413891252882
  • Like 4
After you pull the wire out of the liner, take the whip out of the machine. Grab both ends with one hand creating a big loop. Smack that shit on the ground a couple times then blast it with compressed air. FREAKING AMAZING how much shit comes out. When you go to put your wire back through the feed rolls, shove it through an ear plug to wipe away shop dust and particles of crap. Helps keep your feed rolls and the liner nice and smooth.
Welding supply houses sell a welding wire cleaner pad for  this, it just cost more money. If your cheap, use and ear plug at least.
