74 620 V8 AutoX
Cpl620
are you just running the log headers?
Yeah im just useing the stock logs. Any manifold I run will have to be modded if you see the clearance im dealing with, ill post it later.
The only other option is reverse the the manifolds to run it like a single front mount turbo and turn it down the passenger side. But I already got the parts for the exhaust coming.
  • Replies 508
Wait what? Thats news to me. Sounds like a bunch of witchcraft.
In other news, dropped her off tonight at a local shop to get some brake lines made. I dont feel like spending $500 to get good tools to straighten, flare, and bend stainless that ill use a hand full of times. Probably have her back by the end of the week. Gives me time to get stuff donw around the house...
Cheater Poor broke bastard :poke:
fixed
im actually going to go there tomorrow and ask him if I can just rent his equipment if he's going to really charge me $93 a damn hour for labor.....on a truck that's basically bare frame....am i unreasonable or do you shop guys think that's pretty messed up?
Our shop rate is $80 an hour for custom work, but of course that will vary depending on your area. If it's a bare frame he's working with, the hourly rate won't change but the number of hours should be fewer...
I'd see if he can quote you for the job, rather than hourly- puts the burden on him to quote accurately and work efficiently.
Good luck! I'm not looking forward to the brake lines on my car, either.
It's worth talking to him. I know we've dropped our rate or underbid a job before- usually if it's something unique or cool to work on, or an opportunity to design a new product. This guy may do the same, if he digs your build.... Never hurts to ask!
yeah so screw that noise. i decided to do it my self with some cheap ass tools. Brake lines MOFO! and whats next?!?! exhaust! it seems so close until i remember that i have to wire the whole damn thing and then tune it. and im official broke, i wanted it done by the end of summer, that may be on hold. anywho, im not doing the last two lines yet because i may have to scoot the pedal box back another inch or two so the wheel does not hit the lines off the masters. SUCH a huge pain in the ass to go from 3/16 & 10mm to 1/4 line, dont ever do it......EVER. the right fittings dont exist and your project will looks like a tongue punched fart box. now to please all you OIC whores...
1622234_745249735520650_2703086292119677
10574256_745249895520634_108215446292780
10403307_745249842187306_141924736264803
10525598_745249752187315_445792220865484
10527351_745249768853980_783369183171531
10479531_745249815520642_488483662396478
10492490_745249928853964_565781553234482
  • Like 5
Frame is 100% done now. No more flex in the front towers, the suspension actually works now. Mount the steering wheel and pedals tomorrow finally. Then run those last two brake lines. Maybe start the exhaust tomorrow too. i want to do the seat brackets, but i need to put the new tunnel back in for support before i do that.  on a last note,  these are probably the nastiest weld i have done so far on this thing. hahaha, fk it, the dash will cover them.
1377421_745749345470689_6716265041010104
10593231_745749355470688_486099271145597
10557196_745749375470686_182193493329372
10487459_745749395470684_739110817451502
10353693_745749428804014_475568402258126
personally, this fab work inside makes me cringe. just getting that out of the way. this will be redone when i go to do the role cage, which probably wont be until next summer. for now, it "works."
Spent most of the day getting the final mounting position right and then finished up the brake lines. i wanted to fill them up and see how hard the pedal feel was, but ill wait until i get her closer to running. tacked the manifold on to some plate to keep it straight while i cut it up. my only option to make it past the steering column is to do a center back manifold. ill start that tomorrow, as well as the rest of the exhaust.
10574256_746189548760002_685719575995756
10397834_746189508760006_841277567586428
10561784_746189525426671_567133930918353
Wow, I love it man! You're fabs skills are great! What are you majoring in for school? I'm just getting into college and putting my projects on hold for now while I'm in school. I don't see how you can balance a build of this scale AND school! Anyway, keep up the work, can't wait to see it moving under it's own power. :thumbup:
what about using some log headers? most toyota pickup guys use them. i used them to clear my steering on my 2x4 4runner on pickup chassis
this is why i cant. the steering column is right under the exhaust port in the first pic
Thanks man, im an Architecture major. prior to that i was a mechanic for jet engines.
It's a pride thing. Just knowing I have an ugly weld on something bugs me, whether it will be seen by people or not.
this right here. just like this make shift manifold. i have a high standard, and when i cant meet it, it makes me a sad panda.
this manifold kicked my butt today, thats about all i got done. at least header wrap will go over this one.... lol the exhaust should be fun though. question: should i make the trans tunnel bigger to tuck the exhaust, or should i run it bellow the bracing? it will be about an inch lower than the frame, and probably scrape where ever i go...
10353191_746685675377056_279649109561559
10592817_746685695377054_610604064376181
1623641_746685712043719_3821362053587132
10371901_746685735377050_591826171288020
1610755_746685745377049_6021840423831510
