]2eDeYe
620/720 KA24 Motor Mount brackets
KA620 mounts.
....and because everyone likes pics. How about some SR620 motor mounts?
I have 4 sets of these ready to ship. They are a little more than the KA mounts due to their size and relative complexity.
  • Like 3
Share this post
Link to post
Nice work as always, but Redeye what are those other 2 brackets for with the ka620 motor mounts?
Share this post
Link to post
MAF bracket on the left, fuel pump bracket on the right.
Share this post
Link to post
That feeling when you think you're seeing your future. ;)
Looking forward to them! It might be a little bit until I get it in, but I'm getting there with my parts collection.
Share this post
Link to post
Complexity, Is the hippy using spell check again!!!  LOL
620 KA mounts work in a 720 for the KA swap?
Does this cover the L20B, Z20, Z22, & Z24 engines in the 720s?
Share this post
Link to post
It does, but the Z series swap requires using the Z series rubber mounts. This also requires grinding off the clocking nub on the rubber mount as it is in a weird spot.
The 720 also requires a custom oil pan.
Share this post
Link to post
Are those SR620 mounts bolt in? This is to get a SR20 into the engine bay correct? This solves the need of having to move the stock mounts and reweld them?
Thanks
MantisX
Share this post
Link to post
That is correct. There are still modifications that need to be done to the center link as well as slotting the cross member for the longer transmission. The alternator also needs to be relocated.
Share this post
Link to post
Awww yiss. Stay tuned, im going to go do some reading on what needs to happen after the engine is in the truck. I may very well be going SR20de or det. Ive had alot of fun with the L turbo, but I feel like more potential is in a SR or KA.
MantisX
Share this post
Link to post
Almost have my sr20det purchase narrowed down. Im trying to find a closer source but if not, im ready to have one shipped. Waiting patiently for these mounts!
Share this post
Link to post
Latest run of KA620 mounts are ready to ship.
Share this post
Link to post
Now that I spammed my other threads lol...one last time
Another run ready to ship. I now have the KA & SR covered for the 521, 620 & 720.  :)
I got a few pics from a 720 customer recently, motor looks right at home in there.
He has since sold this truck was ordering another set to build his next 720. :)
Share this post
Link to post
Got my set yesterday for the SR into a 620. Beautiful product. Well worth the cost. I'll edit this post to add some pictures as soon as it's in the engine bay. Thanks Redeye!
  • Like 3
Share this post
Link to post
From what guys have been telling me. It is best to get the trans and motor in and install the crossmember with the trans mount bolted to the crossmember only.
Then lift the motor to install the motor mounts.
At this point you should be able to tell how much the trans mount needs slotted, same as the KA swap.
9E7EEA4C-332D-4E2C-966D-D195BA45FAE9_zps
All the 240sx KA swap info in this thread applies to the SR swap. :)
Share this post
Link to post
Another run of KA260 mounts done and ready to ship.
Share this post
Link to post
you now have specific mounts for the ka into 720? when i got mine from you last year i got the 620 mounts.had to fabricate some spacers,but hey they work.if i can get 720 mounts specific i may just change them out to the correct mounts. then i can do away with the spacers correct?
Share this post
Link to post
Sorry I didn't see this, notifications are behaving oddly.
What did you need the spacers for? Guys have been using the 620 mounts for the 720 for a while now without any issues. Did you use the 720 rubber isolators?
Share this post
Link to post
New cross member for the 620 KA and SR swap.
Share this post
Link to post
OK I used your mounts for my Ka24e swap several years ago in my 720. I was happy with them but the shift lever contacted the body on the passenger side in fifth gear and I had to trim some metal. No biggie compared to other swap issues. Anyways another member suggested  the ka trans had a 3 degree shift from the B series. I now have the front of the b compared to the c and cannot find the difference. So the shims were to correct for this? Anyways love the mounts but they may need a small adjustment for the 720.
Share this post
Link to post
Thanks for the info. So the L would be 0 deg, the Z seires 11 deg and then the KA would be 14 or 8 deg... interesting.
Share this post
Link to post
Redeye I am getting parts together for a VG30 (95 Pathfinder) and a KA (90 D21) swaps into 720s and I am wondering if the this transmount will work on both swaps if needed.
I will be ordering your KA 720 engine mounts soon.
Do you have VG30 mounts for the 720?
Share this post
Link to post
I don't know if this would work in the 720. If you got me some measurements from a 720 cross member I could check.
I don't have VG mounts, yet. Hobo has a VG I am going to play with at some point. Not quite ready for that yet though.
Share this post
Link to post
