620/720 KA24 Motor Mount brackets
]2eDeYe
  • Replies 201
Sorry to say I completely forgot about getting back to you on the measurements for 720 brackets. Unfortunately my plans have changed and I don't think I'll be able to provide the needed help.
I'm a loser, this I know.  Figured it was better to let you know than leave you hangin'
  • 2 months later...
]2eDeYe -
PM to you regarding your mounts.
I have my 78 with a KA ready to go.  You, sir, are going to save me so much time!
  • 1 month later...
  • 1 month later...
those mounts look way better than my middle of the night garage made ones lol. i need those mounts clearly since i had to have my ka24de oil pan massaged and welded to clear the centerlink :confused:
please pm me with details on the mounts if you dont mind. i think i will have to get a pair if i cant fix mine easily.
PM Sent
  • 3 months later...
  • 2 months later...
Adding a new bracket to the lineup. This attaches to existing holes on the frame and provides a place to strap an external pump (I used an Airtex E2000) and a filter down. I suggest using some foam rubber to isolate it from the bracket, my pump came with some foam for this.
I used large nylon straps to hold the pump in place. You can get chemical/UV resistant straps at mcmaster.com
These should be good enough to last longer than the pump though and are decently priced.
http://www.mcmaster.com/#70215k68/=11wpdhx
The brackets will be powder coated black.
PM Replied to :)
New fuel pump plates are cut bent and off for coating.
Left one aside for Adam to make green
Do those mounts work for SR20DET swaps? And if so, does it move the motor forward and/or down?
EDIT: I believe I found the answer...No, they don't work.
  • 1 month later...
What up everyone..im more interested in getting my hands on the engine mounts ]edeye has im doing a ka24de from a car"easier to find in cali" and putting in my 83 nissan 720 the problem i have is brackets everything else has been taken care off im not good n welding so when i saw this post and the link to those brackets i said hell yea but the link is broken neeed help getting these brackets
They do not. If I could get a set of SR20 mounts, I would be able to develop some, but have not found a set to use yet.
Sorry for the late reply, I don't get notifications for some reason.
As I stated in my reply to your PM; (without the spelling errors :lol:)
I have been told that my motor mount brackets work in the 720, but I have not verified this myself.
The fuel pump and MAF bracket would likely not work at all in the 720.
From what I have been told, so heresay mind you, you can use one of the Z mounts and one of the KA mounts to get it to fit. I would think this rolls the motor though and might bind the trans mount.
Both KA mounts put the motor too high in the bay and the Z mounts put it too low.
My mounts or the mismatch setup either way, if you use a car KA you will have to build a custom pan. .
  • 4 weeks later...
  • 2 months later...
