q-tip Posted November 29, 2015 Report Share Posted November 29, 2015 So you're using it to weld a shock mount too or are you bolting it to the unistrut rail. 1 Quote Link to comment
TENDRIL Posted November 30, 2015 Author Report Share Posted November 30, 2015 something like this Quote Link to comment
Draker Posted November 30, 2015 Report Share Posted November 30, 2015 To absorb shock from the airplane propeller. 5 Quote Link to comment
q-tip Posted November 30, 2015 Report Share Posted November 30, 2015 Bi planes are a bitbofban outbdated design. So you're going to use it for multiple shock mounting locations. Makes sense but why do you need lateral movement in the top mount? Quote Link to comment
fritzdixxon Posted November 30, 2015 Report Share Posted November 30, 2015 Options to dial it all in? I like the simplicity of the single piece, lining every thing up will stay consistent from one side to the other. Are you going with a four link? Quote Link to comment
TENDRIL Posted November 30, 2015 Author Report Share Posted November 30, 2015 It already has a four link that was air bagged, It ate the bushings up when driven low, it had more of a drag style cross bar, I'm going to be figuring out a pan hard, and yes a few different upper mounting points to make sure I can get the best/ smooth est movement, 2 Quote Link to comment
Lockleaf Posted November 30, 2015 Report Share Posted November 30, 2015 So what made you bail on the air bags? You only ran them for a little while, correct? Quote Link to comment
TENDRIL Posted November 30, 2015 Author Report Share Posted November 30, 2015 I would need to re do everything to be happy with it.... So I figured since I need to pretty much redo it just for it to be safe, I would re-do it mor how I want it with more reliable, and less cost, but I sourced a rx7 rear end that in am going to shorten one day and do a triangular set up or adapt the watts link and stick with coilovers, but bags are not practical for me right now, and I just need it to not kill me right now if I drive it and figure all that out later 1 Quote Link to comment
TENDRIL Posted November 30, 2015 Author Report Share Posted November 30, 2015 And because I need it to be on a tow dolly and be safe in the near future Quote Link to comment
Lockleaf Posted November 30, 2015 Report Share Posted November 30, 2015 Not dying seems like a decent reason. Glad to see your build back up and progressing. Quote Link to comment
Ratwagon1600 Posted November 30, 2015 Report Share Posted November 30, 2015 Post 822 Tendril. What are the calipers and rotors off pls ? 1 Quote Link to comment
TENDRIL Posted November 30, 2015 Author Report Share Posted November 30, 2015 those are the early 90's infinity q45 front brakes dual piston sliders 30mm thick ebay pre drilled to 4 lug rotors, however you can make an adapter for other struts , they bolt onto infinity m30 struts which is what i have. Quote Link to comment
]2eDeYe Posted November 30, 2015 Report Share Posted November 30, 2015 Did you find the oil loss source, was it those rings? 1 Quote Link to comment
Lockleaf Posted November 30, 2015 Report Share Posted November 30, 2015 My niece wrecked my m30 years ago. I kept the brake setup and still have it. Yet regardless of how ridiculous this is, I'm irritated that I didn't keep the struts. I didn't even own a 510 at the time, but dammit I had those struts! 1 Quote Link to comment
Ratwagon1600 Posted December 1, 2015 Report Share Posted December 1, 2015 Thanks mate. Dont suppose I could push my luck and ask if you have a part No for the calipers? Quote Link to comment
TENDRIL Posted December 1, 2015 Author Report Share Posted December 1, 2015 Did you find the oil loss source, was it those rings? yep 1 Quote Link to comment
TENDRIL Posted December 1, 2015 Author Report Share Posted December 1, 2015 Thanks mate. Dont suppose I could push my luck and ask if you have a part No for the calipers? hmm part number no but this is what i have http://www.ebay.com/itm/Disc-Brake-Caliper-Friction-Choice-Caliper-w-Bracket-Front-Left-fits-90-96-Q45-/251907144732 i got mine from a junk yard though Quote Link to comment
Ratwagon1600 Posted December 1, 2015 Report Share Posted December 1, 2015 ^^^ Thanks, the Egay link is very handy as its got better Oics. Quote Link to comment
datsunfreak Posted December 1, 2015 Report Share Posted December 1, 2015 My niece wrecked my m30 years ago. I kept the brake setup and still have it. Yet regardless of how ridiculous this is, I'm irritated that I didn't keep the struts. I didn't even own a 510 at the time, but dammit I had those struts! Shoot me a PM if you want a pair. Quote Link to comment
]2eDeYe Posted December 2, 2015 Report Share Posted December 2, 2015 yep Now you can fix it :) Quote Link to comment
TENDRIL Posted December 12, 2015 Author Report Share Posted December 12, 2015 10 Quote Link to comment
Draker Posted December 12, 2015 Report Share Posted December 12, 2015 Well it's on all 4.. and the hood is closed. 4 Quote Link to comment
Draker Posted December 12, 2015 Report Share Posted December 12, 2015 I thought you got it fixed? 6 Quote Link to comment
hobospyder Posted December 12, 2015 Report Share Posted December 12, 2015 Well it's on all 4.. and the hood is closed. theoretically hood could also be removed 2 Quote Link to comment
