'72 510 4dr Project
  • Replies 38
  • 1 year later...
Body work has begun.
The front was in the most need of attention. The PO was a bit of a pot head and didn't always remember to use the brakes. Front fenders, hood and valence were repaired years ago....badly:
Looks like rust from the inside out. Anyone else experience this on their car?
New valence:
This is as far as I got yesterday. Still working on lining up the body panels. the core support is a little tweaked so I will be spending some days on that.
For the back:
I an going to weld up all of the trim holes on the fenders, do a skim coat of filler, sand and prime for now. It is my intention not to drive the car until the body work is complete and i would like to have the car stripped out before taking it to a body shop for final prep and paint. Going to do the OE white with burgundy interior as that how it came from the factory.
This Dime is looking good! I think the rust coming through the front lower framerails is pretty typical. There are like 3 layers of sheetmetal there trapping in moisture. By all means repair it, just don't go too far or you will end up with a door dragging zombie 510, wink wink.
Valence has been replaced and the fenders and hood are fitted.
Using a spot weld drill bit I removed the old valence. I inserted 5mm rivet nuts into the core support in order to attach the new valence:
Fitted the new fenders and hood. Had to massage the core support as it was a bit tweaked out of shape. Also, my core support brace was pretty screwed as well...got a nice one form Hobbes:
Now everything will come back off to have the trim holes welded in, thin coat of filler, primer, and a lot of sanding.
  • 5 weeks later...
Eric, the hood cut for the supercharger has already been fit (and if you remember it has the hole already) so it just needs paint.
Draker, I believe I got it from someone on EBay if I remember...NOS and it cost me a pretty penny.
Ranman, I did see Boatys install and I am awaiting the gauge from Speedhut. I am going to try to do the same.
  • 2 months later...
I have gotten a few inquiries as to how I mounted my Speedhut gauges. Here is a quick and dirty synopsis. I haven't mounted my gas gauge yet so can't help much there but here are the speedo and tach:
I cut a hole out of the metal mounting plate behind the OE speedo for wire and GPS cable access. Also cut out a hole in an OE tach housing for wires.
Modified the inside of the tach housing by removing the 3 light ports to make it essentially hollow:
 I epoxied the mounting collar for the speedo to the back of the main bezel. I had screwed the collar all the way to the new speed bezel which leaves a little sticking out the front
I did the same for the new tach. I then screwed the new tach w/bezel on the assembly using the OE screws that were used to mount the bezel and clear cover.
  • 7 months later...
