'72 510 4dr Project
Three years ago (or so) I bought a '72 510 4dr from the original owner. They hadn't taken that great of care of the vehicle but it had promise. We settled on $400 and I dragged it home. I web searched and found Ratsun almost immediately. I have been semi-lurking this whole time, chiming in when appropriate and selling off spares when I could but mainly just reading, searching, reading. While I am member of the other online groups I find myself on Ratsun nearly everyday and have learned to glean the wisdom from the noise...and sometimes just revel in the noise. I have done almost all of this work myself. Lots of late nights and misdirected UPS deliveries later this is what you all have helped me do:
During that 3 years this is what I have done.
Suspension:
Techno Toy Tuning (TTT) 280ZX Struts with Coil Overs
TTT Camber Plates
TTT Rear Coil Overs
TTT T/C Rods
Penultimate Rear Crossmember
All new components front and rear (tie rods, bushings, bearings, etc)
Datsport Steering box stiffener bracket
1" front sway bar
3/4" rear sway bar
Nismo lug studs
Brakes:
280ZX front disc
Maxima rear disc
Sentra E-Brake
15/16" MC (280ZX)
Drivetrain:
VG30E completely rebuilt and balanced
VG30.com Mounting Kit w/Machined lower intake
-JWT Cams
-Adjustable Cam gears
-Pathy Upper Intake
-60mm Throttle body
-VG30.com headers
-Nistune modified ECU
-CanAm box (Thanks Icehouse!)
-Mild head flow work
-Ferrea Stainless valves
-Fidanza Flywheel
-Centerforce Clutch
Griffin Rad
SPAL Pusher Fan
2.5" Stainless Exhaust
HKS "Muffler" :rolleyes:
FS5W71C 5spd, Rebuilt (car was an Auto)
Subie R160 VLSD, Rebuilt, 3.54, custom stub shafts
VW type2 CV's w/ SwayAway CroMo axles
Matt Adapters at the Stub Axle
Shortened and balanced drive shaft
Interior:
New dash pad
Speedhut gauges
-GPS Speedo
-Tach
-Oil PSI
-Water Temp
-Volts
Stock White Needle Gas/Temp
Reconditioned Heater box and new valve
Momo Steering wheel
Late Model Acura Power Bucket seats
New Seat Belts from seatbeltplanet.com
Roll Bar
Electrical/Exterior:
Projector Headlights w/HIDs
NOS turn signal switch
New Taillights
'68 bumper and license plate light
New Taillight assemblies
'68 Grill and Surrounds
Kia 16x6 Rims w/ 205/45 tires
Reconditioned C-Pillar vents
Aftermarket side mirrors
Bumpers are currently out for straightening and chrome. Shopping for a reliable body shop to do all of the needed prep and paint. Anyone aware of such a shop in San Diego or Orange county please PM. New/restored interior to follow.
Here are more pics:
http://datsun510.com/photopost/showgallery.php?ppuser=2587&username=rpowell25
Thanks for the Assistance!
Robert
  • Replies 38
Speedhut Revolution series. The gps speedo is amazing! No cables, trans sensors, gears, etc. Mounted the gps receiver on the dash right over the speaker grill. Probably won't work in a tunnel but other than that, pretty darn cool. I need to post pics of the other gauges as well.
Speedhut
cant beat 90$
but the wheels spacer had to cost something.
I cant even selll 2 sets of Pathfinders 1 set with tire for 100$ . Everybody is broke!
Be honest. I think get some wheels and just maybe buff it out the outside. I like the Patina on this car.
Spend the money on Motor and suspension!!!!!!!! ur already mostly there what I can see buying good stuff
Actually at this point I cannot spend much more on engine/suspension/brakes...I am trying though! I figured the spacers would increase my wheel buying options. I had the same 30mm spacers on the back until I adjusted the camber. had to switch to 10mm at that point..
