Really Ratty Rusty Ruby Ruined & Rotting RIP
wow that's a tough stance.....really like that, too bad its unuseable....its definately pimp....one of my fav shots ot your car...wait, so the plus twentys on the front dont even fit the rear ... or just cause u have maximized your lowness it rubs? u think those +20's would fit the back of my wagon... tristans 15x8 +12's looked real close to clearing the lip...i was gonna run a similar wheel to tristans 15x8 but in a 7 inch wie wheel these wheels on this car have always been the cats meow...
Keep in mind my entire rear suspension/floor/shock towers are raised 4 inches ..... So no brake drums and 16x7.5 +20 "almost" fit
the rear crossmember is only raised 3" in these pics:
Needs moar loar...
  • Replies 1.8k
that was before you took it apart lol you mean to tell me that now with all the metal fab that has been done that they wont fit in the back?
The rear crossmember is raised 3 inches in the pics on this page .... ... and the shock towers/diff mounts are raised 4 inches
... I need to raise the crossmember another inch ... .. but then there will be less negative camber,,,, and even FWD offsets won't fit
I'm just trying to decide if senior citizen offset wheels, or a flared 4dr is worse ....
I would need to re-design the floor/cage if I don't raise the crossmember the extra inch to clear the driveshaft over the floor bars
I think the key is in the shock towers, control arms half shafts and cross member.
Shorten the control arms and half shafts, move the control arm mounts on cross
member in and weld a 5" half pipe into the tower to make room for the coils to
move inward.... I am sure tou can figure out the spindles.
What's the tires size u running 195 45 ?
I like the from inside the trunk shot, reminds me of my Mazda ..... 18 inch titans make tire rub body line and I have a four inch line of burnt paint right on the bend ...... matches the twenty two hole in the cab
What are senior citizen wheels? And dont you hate flared 4drs? So your telling me you went through all this trouble and guna design a car you dont even like? :confused:
NO FLARES!
Since you've gone through this much trouble, why not fabricate a new rear crossmember? You can dial in any camber you want, move the trailing arms in any direction (including inward for more wheel offset). You would of course need to shorten the driveshafts. A tubular crossmember might be a great option at this stage. And maybe some mini-tubs.
Over +65 offset wheels ..... :lol: ...... if i was going to narrow the rear track width...... I would have moved the shock towers inward
..... flares have been an option from the beginning ...... it will look more functional and be easier to finish with flares
Guest 510kamikazifreak
haha there goes the car. do i get to drive it??????? once please
maybe Indy will let you drive it at Canby...
:poke:
OH NOOOOO... MR. BILL!!!
Mr. Bill races with me every Saturday night at the dirt track, he likes to ride on my windscreen and wave at the crowd. Maybe that's why I can't win a race... :rofl:
These cars are built like tin cans.... . everything I thought was structural isn't ...... I honestly don't know what is holding these cars together
...... it must be a combination of every piece of sheet metal I cut out ...... :rofl:
So .... .. a few more cuts and I should be done ..... :lol:
This topic is now closed to further replies.
