Alex Datsun Posted February 16, 2012 Report Share Posted February 16, 2012 Theres a cap at the top of strut housing, unscrew it and pull the strut out. I used a set of channel locks to get mine off. Link to comment
boonedock saints Posted February 16, 2012 Report Share Posted February 16, 2012 hey buddy trust me with the harnesses, your gonna want an actual harness bar that goes across both strut towers and comes out toward the front a little so that the adjustments on the shoulder straps dont snap your caller bones if and when you smash this thing into a wall. ive been around harnesses since i was about 10yo with dragracing and off roading to know that those adjustment brackets can eff your shit up if your not careful. Everyone, please please take heed to these words...comming from another ex-racer of in car crashes, DO NOT mount upper shoulder mounts 45 degrees lower then seat shoulder harness holes. I know many people run 5 point harnesses and just have a bar, but if you ever roll over.....your head will support the weight of the car if the roof and pillars dont stop the impact. That being said, if your running a harness, highly consider running some type of cage as well...if not your sorta defeating the purpose. There is two alternatives as well. If your not going to run a cage....there is a belt that has the shoulder harnesses tying together to one, with a male end of a standard belt latch on it. It pilugs into a retractable female end, which you can mount behind the seat. So with this set up you dont need a cage, due to the fact the shoulder harness portion is retractable. Mind you it can be locked into place if so deisred, but when its not you can still reach the raido, lights and the dash...which is nice. Two companies make them....Corbue...and dont remember the other one...and I spelt the first one wrong...Ill try and find pics of my camaro with them in there. " "> "> "> Link to comment
ComicArtist Posted February 16, 2012 Report Share Posted February 16, 2012 Big ass hex nut at the top of the strut tube. The shock piston actually goes through it. I used a pipe wrench and a sledgehammer to get mine off. Link to comment
jalen Posted February 16, 2012 Author Report Share Posted February 16, 2012 but when i do is moves my shock Link to comment
The Dat-side Posted February 16, 2012 Report Share Posted February 16, 2012 The ?gland nut? I put mine in a vise and turned the whole housing. Link to comment
jalen Posted February 16, 2012 Author Report Share Posted February 16, 2012 my entire strut moves with the nut. Link to comment
The Dat-side Posted February 16, 2012 Report Share Posted February 16, 2012 Post a pic maybe? Link to comment
JZ33 Posted February 17, 2012 Report Share Posted February 17, 2012 You have to loosen the top nut while it is on the car... DO NOT TAKE IT OFF, only loosen, and even when its loosened and off the car... SPRING COMPRESSORS ARE MANDATORY!! TRUST US ON THIS ONE. Link to comment
Son_of_a_Datsun_Guy Posted February 17, 2012 Report Share Posted February 17, 2012 ^ Yeah those springs will launch off if you don't use spring compressors. The factory springs aren't like coiloivers. When they are put onto the car they are compressed within the strut as a set (hence the entire thing moves when you turn the nut holding them down.) If they come loose or strip the threads and you're in the way, well, it's like a rocket aimed at you. If your fingers are in the springs when they do that you might as well say goodbye to them.... Link to comment
jalen Posted February 17, 2012 Author Report Share Posted February 17, 2012 FAwk i got to remount it. Link to comment
Alex Datsun Posted February 17, 2012 Report Share Posted February 17, 2012 If you wanna go the ghetto route, put some vice grips on the strut tube and use a half inch ratchet to turn the nut. Vice grips will keep the spring from shooting out (although i never encountered it, but obviously spin the ratchet slowly and as carefully as possible just incase. Link to comment
Laecaon Posted February 17, 2012 Report Share Posted February 17, 2012 Or do the Skib method (Heard it from him first. You should be able to turn the nut fine though... But just turn it keeping an eye on it. As you know you are close to the end of the threads, stand away and just keep barely kicking the wrench and running away at the same time. It is scary. And its still not super safe to do it on the car, but would make things easier/less likely to kill you. Link to comment
The Dat-side Posted February 17, 2012 Report Share Posted February 17, 2012 Rent some spring clamps from an auto parts store. Or take it to les Schwab. My ZX struts had a flat side that matched a flat side in the top hat. Made it so you could turn the bug and the strut would stay put. Maybe yours do too but it only works in the car. Flat spots up top. But these are Rabbit or MR2 inserts so they were slightly bigger. Link to comment
jalen Posted February 17, 2012 Author Report Share Posted February 17, 2012 Or do the Skib method (Heard it from him first. You should be able to turn the nut fine though... But just turn it keeping an eye on it. As you know you are close to the end of the threads, stand away and just keep barely kicking the wrench and running away at the same time. It is scary. And its still not super safe to do it on the car, but would make things easier/less likely to kill you. I'll just mount them back up, through some compressors on there and unscrew it. My brother tried this idea and it scared the shit out of him. Link to comment
jalen Posted February 21, 2012 Author Report Share Posted February 21, 2012 So I found some cheap Honda "lowering spring/coilovers" laying around, anybody have any ideas how I can use these for now untilll I get some legit coils? Link to comment
Alex Datsun Posted February 21, 2012 Report Share Posted February 21, 2012 You mean the ones that just come with the spring and collars? Link to comment
jalen Posted February 21, 2012 Author Report Share Posted February 21, 2012 Yeah those are the ones Link to comment
FiveTenzo Posted February 21, 2012 Report Share Posted February 21, 2012 So I found some cheap Honda "lowering spring/coilovers" laying around, anybody have any ideas how I can use these for now untilll I get some legit coils? buy some ring clamps and put them really low? Link to comment
Alex Datsun Posted February 21, 2012 Report Share Posted February 21, 2012 Have fun...i had only the spring w/o the collars, worst decision i made everererer. I just needed some springs to ride on for a days so it was whatever. I would get those clamps he suggested though or weld a perch om the strut tube for the collar to sit on. Link to comment
jalen Posted February 21, 2012 Author Report Share Posted February 21, 2012 So I would by the clamp mount it above the perch and drop the springs in? [ quote name=FiveTenzo' date='21 February 2012 - 12:47 PM' timestamp='1329857259' post='639902] buy some ring clamps and put them really low? Link to comment
FiveTenzo Posted February 21, 2012 Report Share Posted February 21, 2012 wait? are you trying to slam it? if yes i would cut the stock perch off and put the clamp lower than the stock perch, that way you can get a drop. But i think you'll have a chance of blowing your shocks or bottoming out? maybe someone else can chim in Link to comment
jalen Posted February 21, 2012 Author Report Share Posted February 21, 2012 I don't care of it's not slammed right now I just want rap- ditch the monster truck height Link to comment
jalen Posted February 22, 2012 Author Report Share Posted February 22, 2012 Double post Link to comment
Alex Datsun Posted February 22, 2012 Report Share Posted February 22, 2012 Be patient man, when you rush into things thats when things go wrong. Just deal with height until you find whats right for what you see fit. Link to comment
