Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
Josh K.
  • Replies 2.5k
So the Coil-Overs I'll be running are Troy Ermish's new Setup:
NEW STAGE 2 PERFORMANCE PACKAGE $1800-
Eight way adjustable dampner's front and rear. Custom valved dampner for a 510 with a 2 year warranty on the dampners. The NEW kit allows for ride adjustment with no effect on the shock travel. NO MORE BOTTOMING OUT!
The kit requires the front struts to be cut off 2 inches up from the spindle base, press on adapter tube and weld.
Direct bolt in design for the rears, and bolt in design camber / caster adjustable fron plates.
Close up of the adjustable camber & caster plates.
call Troy for more information. 510-252-1001
I had to walk away for a few reasons. I just want something that works and at the time there was no good options. Troy was working on these at the same time and after some discussion I decided this was the best way moving forward. The price point for the FA coil overs was what I was wanting but sometimes you gotta pay more.....
-Josh
Thanks for the props!
I got the frontend welded on, took some creative tweaking of the front frame rails to get it right..... Still gotta do some finish work tomorrow and the rest will wait till the motor comes back out, just easier that way.
Still working on the quarter. Gotta finish some odds and ends...
I wasn't gonna use the piece between the trunk and quarter but decided I should since it adds rigidity and also braces the bumper.
Gotta finish this section.
Decided I'm not gonna run the quarter all the way to the rocker flange. Gonna weld it right to the face of the rocker. This requires removing the egg shaped section of sheet metal to reduce filler. Still gotta finish this...
  • 1 month later...
Thanks Luke.
It's been a long time since I got to work on my car. Been busy building these http://community.ratsun.net/topic/48979-510-sedan-82-83-280zx-rear-disc-adapters-run-2/
I bought a 2000 Impreza RS R160 VLSD. After some research and thought I decided to use the stock Subaru CV's and just modify them. More on that later..... :ninja:
Here's the diff:
Looks like I lost a few post when the website went crazy.
So started with the Subi stubs and 510 axle flanges. I then cut the Subi stub and turned the diameter, then turned the 510 flanges round:
And a set of VW Axles:
Then designed the new flanges:
Then started milling them. I would prefer to do this in the live tooled lathe but this is faster to setup:
Just need to finish the outboard flanges tomorrow and weld them up. Then measure and send out the VW axles for shortening and re-spline.
Waiting on these to come back from Ano. Forsale in the parts for sale forum.....
Wow, a lot of awesome work. Im digging the flares a lot too.
And I really want one of those water pump pulleys and the water neck!
I'm going to price material tomorrow for the Pulley's. The water neck I'll probably design and make out of billet on the CNC. Welding the cast is too unpredictable. Stay tuned!
Here's the finished Set. Just need welding. Going price material for these tomorrow also...... Gotta get my website going quick!
Definitely let me know if you start making these, I want a set for sure!
Started fitting the adapters and Lokar cables. Here's the routing. Looks sick and avoids the sheetmetal plus routes through the stock ebrake hole....
Couldn't be happier. Now to mount the other side and route and trim the cables and decide whether I want to use the Lokar handle I bought or the stock ebrake handle....
  • Josh K. changed the title to Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
