Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
Josh K.
  • Replies 2.5k
Fronts are perfect. With the 1.25" bump steer spacers I had to use a 0.125" spacer since the tie rod was rubbing the rim. Gotta flip the driver side caster plate on the upper strut mount...
Rears are too long. Troy is sending new bodies.
Tomorrow I'll weld out and start painting/reassembling the fronts.
You ain't kidding!
Loaded 300lbs of concrete mix in the car and spent a LOT of time test fitting the coil overs and going over measurements with Troy. I think we found the sweet spot! The final coil overs will have 5.25" of travel front and rear, 225 front, 200 rear and will go from slammed to around stock height. I'm gonna run 2.5" compression front, 2" rear. This will give 2.75" Bump up front and 3.25" Rear. PERFECT! this is what I've been waiting 1.5 years to achieve and it's worth the wait to have a proper setup.
One last outside shot. 5.625" to the bottom edge of the body seam up front, 5.375" rear. Probably gonna settle both down to 5". We'll see.
Back in the lair......
The business end... sooo nasty  :w00t:
  • 3 weeks later...
haven't gotten anything done lately. Moving on the 1st and will have a 2.5 car garage with a service pit. Car will be on the road in two months after that.
I did order and receive a new tail light panel from the Aussies.... Figured for the cost ($460 Shipped) I would be better off with new sheet metal then my tail light panel with dents and rust holes everywhere.
Here's blue in her temporary resting place...
Got the front coil sleeves welded up. They won't ever come apart again..... Pressed in the 2.75" ARP Wheel studs, new bearing races and threw some paint on everything.
Gotta get the frontend back together so she can go on the trailer next Sunday.
Thank you sir. Trying to keep myself motivated  :yawn:
I HAVE TO get these struts together and on the car by Friday....
Got the rotors bolted up, blasted and painted the dust shrouds for the discs and got new hardware....
  • Josh K. changed the title to Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
