Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
Josh K.
  • Replies 2.5k
Started installing the ebrake setup today. Looks like the stock ebrake cable would work with my adapters but I choose to go with the Lokar handle for simplicity. To use the stock ebrake handle/cable you need to move the forward cable mount forward around 4" since the cable is soo long....
Anyways. I couldn't bolt the Lokar handle from under the tranny tunnel like it's designed because it would hit my driveshaft. Instead I had to do a "mid mount". I slotted both the handle holes and the mount holes so I could drop it down.
First I roughed a slot:
Then slotted the mounts:
Mounted the handle:
Routed the cable (Passenger is just mocked up right now. Cables will be routed better and secured later):
Ordered some ss lines from the Z-Store.
Now I can make and route all new hard lines and get the brake system finalized. Then once my Ermish Stage 2 coilovers get here I can finalize the rearend and get back to buttoning up the sheet metal and start putting the car back together for a serious shake down....
Thanks Bob!
I just ordered myself a christmas present.... 3 more Grid Classic's and R1R's :)
Now once my coil overs arrive I'll have a complete roller. Then I can set suspension travel/ride height/alignment/wheel spacing/route brake lines/final fitment/attachment of panels. Then start working on all the little details to get her running again for the shakedown!!!
Got my ss lines and started routing them. It's my first time making brake lines. It's pretty simple.
I scrapped the outboard line mounts I was gonna use to simplify the hard lines...
I'm using the stock arm mount on the passenger side but moved the drivers side back so I can keep the ss line tight to the body to avoid the exhaust heat. I'm moving the tee fitting above the diff also.
One of the ss lines in the kit is female/female. I didn't want to comprise my routing to use it so I robbed one from the front and will just order another to replace it...
Just gotta run the line to the front. Gonna run it underneath and along the tyranny tunnel and not in the car like stock.
"Just gotta run the line to the front. Gonna run it underneath and along the tyranny tunnel and not in the car like stock."
Actually, running it up the trans tunnel is the stock routing.
Brock
Thanks Brock, that's good to know. Been a while since I had a dime. Seems mine was "special"....
So went in to the shop this morning to do a little machining..... Since I'll be making the interface for my set of Ermish Stage 2 coil overs I figured I would remove the old pressed-in strut tube and weld. This way i'll just make a new tube section and butt-weld like the factory did.
ToDo's
Modify and mount Brake Master Cylinder Sun, Dec 30
Finish running brake lines Sun, Dec 30
Make Bump Steer Spacers Sun, Jan 6, 2013
Install CV's Sun, Jan 6, 2013
Final Weld out of rear suspension Sun, Jan 6, 2013
Make Front Coilover adapters Sun, Jan 13, 2013
Fit Coil-Overs Sun, Jan 13, 2013
Clearance body for rear subframe Sun, Jan 20, 2013
Finish passenger axle tub Sun, Jan 20, 2013
Finish trunk pan and braces Sun, Jan 20, 2013
Finish and weld driver quarter panel Sun, Jan 27, 2013
Redo passenger rear rocker Sun, Jan 27, 2013
Finish and weld on passenger quarter and trunk pan Sun, Jan 27, 2013
Finish weld out of rear panels Sun, Jan 27, 2013
Flip car around Sun, Feb 3, 2013
Mockup all engine bay components. Oil Lines Sun, Feb 3, 2013
Mockup engine harness Sun, Feb 3, 2013
Pull motor and replace rear main seal Sun, Feb 10, 2013
Degrease motor Sun, Feb 10, 2013
Install motor Sun, Feb 10, 2013
Mount all accesories Sun, Feb 17, 2013
Run engine harness Sun, Feb 17, 2013
Wire up all lights and accessories Sun, Feb 24, 2013
Mount Exhaust Sun, Mar 3, 2013
TEST DRIVE........
Pretty optimistic but I gotta set some goals...
  • Josh K. changed the title to Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
