Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
Josh K.
  • Replies 2.5k
ToDo's
Modify and mount Brake Master Cylinder Sun, Dec 30
Finish running brake lines Sun, Dec 30
Make Bump Steer Spacers Sun, Jan 6, 2013
Install CV's Sun, Jan 6, 2013
Final Weld out of rear suspension Sun, Jan 6, 2013
Make Front Coilover adapters Sun, Jan 13, 2013
Fit Coil-Overs Sun, Jan 13, 2013
Clearance body for rear subframe Sun, Jan 20, 2013
Finish passenger axle tub Sun, Jan 20, 2013
Finish trunk pan and braces Sun, Jan 20, 2013
Finish and weld driver quarter panel Sun, Jan 27, 2013
Redo passenger rear rocker Sun, Jan 27, 2013
Finish and weld on passenger quarter and trunk pan Sun, Jan 27, 2013
Finish weld out of rear panels Sun, Jan 27, 2013
Flip car around Sun, Feb 3, 2013
Mockup all engine bay components. Oil Lines Sun, Feb 3, 2013
Mockup engine harness Sun, Feb 3, 2013
Pull motor and replace rear main seal Sun, Feb 10, 2013
Degrease motor Sun, Feb 10, 2013
Install motor Sun, Feb 10, 2013
Mount all accesories Sun, Feb 17, 2013
Run engine harness Sun, Feb 17, 2013
Wire up all lights and accessories Sun, Feb 24, 2013
Mount Exhaust Sun, Mar 3, 2013
TEST DRIVE........
Pretty optimistic but I gotta set some goals...
I applaud your optimism :) I bet if i set a schedule like this i might actually pull everything together on my datto.
You gotta start somewhere. As you can tell I get sidetracked real easy....... Looks like finishing the brake line from the front to back will have to wait till I pull the motor. No room... I traded 510 OC a set of CV adapters for his JDM tail light garnish.. No idea what tail lights I'll run. Would like a set of JDM lights with the chrome bars running horizontal but don't wanna pay $500-$600 for a NOS set! 20121229_165344.jpg
Looks badass my friend. :thumbup:  I was going to try to find a set of NOS Euro tail lights. They're in your price range too.
Thanks Jordan. I've got my eye on a set of Euro lights, we'll see.....
Finished roughing out the other Coil Over Adapter.
Moved onto the Master Cylinder. The 82-83 has a horizontal bolt pattern. I decided to modify the plate to accommodate the pattern. I'll bolt through the firewall and into the pedal assembly. I welded up all the other holes. Just gotta go home and mount it up! I plan to tear it apart and rebuild it if needed.
Should be test fit tonight....
Made the Bump Steer Spacers. 1.25" Tall.
I reamed the bolt holes 0.002" over the bolt shoulder Diameter and will make a 0.013" sleeve for where the bolts go through the steering arm. This way it will have no slop and locate the same when I take it apart next time without requiring the toe be reset. I've seen how Techno Toy accomplished this but didn't like the solution they came up with. This is more robust.
Will,
I'll send you a pm soon.
Fit the cv's. With the axles horizontal they can compress another 3/4". Looks like I measured correct....
Here's a flood of pics....
Moar lower!
Good thing I tunneled the body!
  • Josh K. changed the title to Feng Shui (The 510 Experiment) (Pics fixed through page 7..)
