WAGON JON Posted November 25, 2010 Report Share Posted November 25, 2010 Looking good. It reminds me of a yellow 4 door I sold to a guy up in Oregon. Looks just like it. Keep the pictures coming! Quote Link to comment
dennis Posted November 25, 2010 Author Report Share Posted November 25, 2010 Hard to believe this is what my 510 looks like under all that cammo spraypaint I am removing! My yellow might be lighter though. But the stock paint I am finding is way more beat up. Thanks for the inspiration to keep scrubbing! Scott, you have made some great progress. I am a disabled vet so basically that means I am mister mom. I have to take care of the day to day needs of my four kids and dinners. Right now I have a 5 year old and once he starts school next year and we are moved into our new house the fun will begin. Besides the basic household chores I should be able to devote on average 5 to 6 hours per day on the 510. This pic was a bright Texas day so the yellow on a normal day isnt so bright. Tomorrow I am going to take another entry for the Ratsun Calendar in HDR. I will probably set the car up in multiple positions, I think it will look best with part of the grille showing so I might polish it up a bit. Quote Link to comment
dennis Posted November 25, 2010 Author Report Share Posted November 25, 2010 Looking good. It reminds me of a yellow 4 door I sold to a guy up in Oregon. Looks just like it. Keep the pictures coming! Thanks, I would have a ton more pictures but my garage is not close to my apartment and I forget my camera all the time so I have to shoot them with my EVO phone. Quote Link to comment
dennis Posted November 26, 2010 Author Report Share Posted November 26, 2010 Ok here is the rear wilwood install. 1. I removed the wheels then drums and cut off the backing plate with a combination of a cut off wheel and my dremel tool. No pictures but it was easy enough, here is a pic of the area before the install. 2 I then cleaned everything up just a little and then installed the caliper adapter. 3. Caliper and stainless steel hoses. Overall a pretty easy install. The hardest part was removing the backing plate and loosening up the old hard line and old brake hoses. I haven't had any time to take it for a spin since I was trying to raise the rear coil overs just a little bit before going out but the teflon stopper on the set screw is jammed up on the sleeve so I will be messing with that tomorrow. I also noticed a little rubbing after the brake install so I rolled it even further and it went away. Quote Link to comment
fisch Posted November 26, 2010 Report Share Posted November 26, 2010 ^^That was 100% simpler looking than I thought it would be! Nice to know. And I would kill for 6-8 hours a day dedicated to the Datsun! Can't wait to follow when you get there! Quote Link to comment
dennis Posted November 26, 2010 Author Report Share Posted November 26, 2010 I wont be 6 - 8 hours a day till Aug 2011. It was very easy to do the rear disk conversion. Hardest part of the whole job was getting those damn old rusty brake lines off. Quote Link to comment
dennis Posted November 28, 2010 Author Report Share Posted November 28, 2010 I decided to use one of my body hammers to fold over the lip in the rear wheel wells. It was extremely tight in that area and if there was any fore and aft movement in the shock then I am sure the coil would rub. Quote Link to comment
sick620 Posted November 28, 2010 Report Share Posted November 28, 2010 man this car inspires me. keep up the sweet progress. Quote Link to comment
dennis Posted November 28, 2010 Author Report Share Posted November 28, 2010 Here is a latest pic for the calendar thread. My first HDR shot for the 510, still not happy with the angle. Quote Link to comment
dennis Posted December 14, 2010 Author Report Share Posted December 14, 2010 here is the latest pic of my 510 for the calendar submission thread. I shot this in HDR 1st layer black and white second in color . 1 Quote Link to comment
fisch Posted December 14, 2010 Report Share Posted December 14, 2010 That is the hottness right there Dennis! Great stance man. Quote Link to comment
juancho Posted December 14, 2010 Report Share Posted December 14, 2010 nice job dennis Quote Link to comment
dennis Posted December 14, 2010 Author Report Share Posted December 14, 2010 That is the hottness right there Dennis! Great stance man. Thanks Scott nice job dennis Thanks, when are you going to start a build thread? Quote Link to comment
juancho Posted December 15, 2010 Report Share Posted December 15, 2010 soon hopefully..........just waiting on a couple of parts,to start tearing it up and put it back together Quote Link to comment
DARIN 510 Posted December 15, 2010 Report Share Posted December 15, 2010 hey whats the cold cranking amps on that Odessy battery and does it crank over the motor pretty good? Quote Link to comment
dennis Posted December 15, 2010 Author Report Share Posted December 15, 2010 hey whats the cold cranking amps on that Odessy battery and does it crank over the motor pretty good? My trunk mount is only mounted and not hooked up, this time of the year is not good for me to work on the 510 because of family. I will probably hook it up in a few weeks after I bleed my brakes again. I know of two people on this board that uses them and both have no issues. I know of a whole bunch of people outside of the board that use them without issues as well. One thing is for certain, if you have a amplified stereo system I wouldn't run one. If you have the basics on your car then this is perfect for the small displacement engines. Make sure you alternator can handle all of your accessories and you will be fine. If you only drive your car a little bit at a time and once in a while then you are going to have to charge it frequently (this is going to be my case). Odyssey rates their batteries a little different than just using CCA, CCA measurements are not held to a standard so they go off of a real world measurement. 680 cranking amps for 5 seconds 595 cranking amps for 10 seconds 525 cranking amps for 20 seconds Quote Link to comment
WAGON JON Posted December 15, 2010 Report Share Posted December 15, 2010 Now, just go and drive the thing. :D Quote Link to comment
dennis Posted December 15, 2010 Author Report Share Posted December 15, 2010 Now, just go and drive the thing. :D LOL, It isnt safe right now. I have to bleed the brakes. If I pump them twice they work good but I am real busy with my kids right now. Hopefully this weekend. Quote Link to comment
DARIN 510 Posted December 16, 2010 Report Share Posted December 16, 2010 thanks for the info i think this battery is perfect for me.oh yah your car looks fucken sick. Quote Link to comment
dennis Posted December 16, 2010 Author Report Share Posted December 16, 2010 thanks for the info i think this battery is perfect for me.oh yah your car looks fucken sick. Thanks man, that keeps me motivated. Hopefully I will get this battery hooked up before the first of the year. Quote Link to comment
dennis Posted December 30, 2010 Author Report Share Posted December 30, 2010 Picked up a hopefully low mileage good compression SR20DET S13 Blacktop Quote Link to comment
Wide14u Posted December 30, 2010 Report Share Posted December 30, 2010 this is coming out great Quote Link to comment
dennis Posted December 30, 2010 Author Report Share Posted December 30, 2010 this is coming out great Thanks, my 620 motor mounts/isolators should be here by monday. My modified crossmember should be here in a week and a half. My tranny mount should be here in a week and a half. I am not going to order any more parts till I can get rid of my L16 and transmission, I need to get this mounted because I only have a single car garage and it is very tight right now. Quote Link to comment
Rustina 510 Posted December 30, 2010 Report Share Posted December 30, 2010 The good old sr20. Nice dude, how much did you pay for that? Quote Link to comment
