It really is an infection...Datsunitis
sitting on a boring call at work i re-read this build thread from where i took over to now...
wow!
Helps to have a guy that knows his ass from a hole in the ground when it comes to operating a wrench... :rolleyes:
Glad you're at the helm. B)
  • Replies 1.5k
  • 4 weeks later...
Drum roll please!!!!!!!
BAM!!!!!! Jessi's dad funded it and I made it happen for her birthday!
125D2EAA-EB6A-48D6-86F6-5A124CDED4A6_zps
DAA9D84A-F896-42AC-BBA2-4F1E42E2562D_zps
S13 KA24DE, "unknown mileage" and pulled "for an SR swap"
I also scored an automatic KA trans from Jrock! Jessi wants a nice daily cruser and the KA automatic is a pretty damn good trans so that's what we are doing! I can't wait to use the goon on long road trips :D
Jessi wants to build this one on her own since she watched my KA swap happen, so were gunna collect parts and go one step at a time till everything is done and ready to drop in. No real finish date in mind but we have 60% of the swap already .
  • Like 6
wow, bump steer spacers make a pretty big difference!!!!
the new tires should be here this week, we will get them mounted then an alingment! that should wrap up the "need to do" list and let me get to work on the "want to do" list!!!
WOOT WOOT
so after the tires and an alignment, i want to break down the SU's, clean them, install a Z therapy rebuild kit, and tune them again cus i have a much better understanding of how to tune them now!
  • 4 weeks later...
Do you guys know how hard it was to ignore all the builds on the way to this out on page 6 !!??
Anyway don't know if you gave much thought to having a color matched rear hatch ,, but i seen this one on the List of Craigs . Kinda pricey for all the doors but maybe they would part with just the hatch of doom.
http://seattle.craigslist.org/see/pts/4310780477.html
If it even is the right color
Got some SU tuning advice from JustJoel and was able to get he goon dialed in a little better :)
And jessi just picked this up with her tax refund so we can really dial in the motor
ED09F280-46F2-44D3-A8F7-71CB161E1DCE_zps
That will make your life so much easier, I have the same one on my car and don't know how I ever lived without it.
good to know! id like to pick your brain........
and ive got those headbolt washers for ya and have time to work n that project for ya if you want
ok, could use a hand with this one guys.....
back story:
i took the carbs apart to clean them
only removed the domes
pulled the pistons and spring
adjusted the needles
cleaned everything above
and re adjusted the gas mixture a bit
after that i ended up with this wonderful little sound that i cant find for the life of me......... its the ticking noise in this vid
th_3BC8A831-147A-4251-8D25-09CDCFDDABB2_
the sound seems to move..........
it only happens at idle and the first half second of acceleration from a stop
to me it sounds like a "rattle"
its not a consistent noise, it will stop and start at random and i cant trigger the noise or stop it
ive already pulled the valve cover (valves, springs, lash pads and cam all look just as good and when i got them back from the machinist 6k miles ago
no oil in the antifreeze and vise verse no antifreeze in the oil
the car actually performs better after the tune up than it did before
so i pulled the carbs apart again at the suggestion of a friend so heres some pics the the 2nd time around
rear carb
DB8A862C-AB28-4622-A998-DFD9133B8953_zps
rear piston and needle
B4ED6A91-D63A-40DB-8D4C-CB52951299A8_zps
front carb
5D4DD880-FEAB-422E-B985-A36077B0F323_zps
front piston and needle
C5F923B8-9FB3-4574-A67C-D3625347A07F_zps
the pics are a bit deceiving due to the angle but the needles are not bent
and just cus :D
12FA7F77-7D9B-459C-A7E5-E5C02F65289F_zps
