It really is an infection...Datsunitis
  • Replies 1.5k
Put in a new 195 temp thermostat to help keep the motor a little warmer in this cold weather
7F0D3E37-A938-4A34-8CD5-153B89A0D48D_zps
Then we set out to get the choke cables hooked up so jessi doesn't have to pop her hood every time she needs to choke her carbs
0B17BBFC-273F-4A1E-AE13-320A68B8595B_zps
Got then in and working with brackets to hold em and all
4E2D3D0C-927F-4EE9-B1BA-8C4371C475DF_zps
Not done by a long shot but they function :)
Actually Adam it was an option on all years. Hardly needed back then with the car weight, brake and tire technology available.  Yes there is a spacer... #47211-26701 under $20 but what's the chance they have one.
Yo!
I want to mount my booster , but I lost the spacer plate!
Any idea how thick is the spacer for the booster?
It was also the same one used on the 610 and 710 if that helps you find one.
Option. Would be useful on fully loaded sedans and goons carrying a load. Don't forget this was 40 years ago when men were men and didn't need girly/man brake assist. Probably aimed at woman drivers? (no offense girls, it really was like that back then)
I believe mine came out of a B210.
Bendix Part # 222-02933
Is on the booster.
And yes I do remember it was a option for the car.
I have the 13/16 master from it.
I still got a bubble somewhere.
So I am going to replace all my bleeders and flush the line again.
Maybe something is still in there?
But my point is I want to put the booster in now and flush the system.
My idea is to take the back plate on the wall of the car, to use as a alignment tool.
Then cut a piece of 3" diameter pipe and weld a flat plate on both sides!
This is why I need the spacer thickness.
Or guy with chicks, that let them drive on special occasions.
Like get you ass to the store and buy some food then make me a damn sandwich!
Oh, yeah and get some more beer too.
LOL!
well.....
some times you win
sometimes you loose
and sometimes you have WAY too much shit to do :/
in this case i lost cus i have too much to do....
the front tires are toast now, didn't get an alignment soon enough cus i kept messing with the front suspension
now the goon need new front tires AGAIN and idler arm bushings...... again
so i picked up another energy suspension idler arm bushing kit
C3495527-0512-40EA-98D4-362B4BFD868C_zps
it will get installed soon, then an alignment, then another set of tires....
Yea, ya'll have accomplished a lot on this and your 620. Really helps when you have someone to motivate you :P
I know I know "install your dizzy yo!" but I can;t find the wiring diagram... Have everything done but the wiring and no battery
