Farmer Joe Posted March 6, 2011 Report Share Posted March 6, 2011 i dont think itll work like that with a 620... the steering box is on the inside of the frame, compare to the 720 where its on the outside... 1 Quote Link to comment
hellamikey Posted March 6, 2011 Report Share Posted March 6, 2011 Is that a stock vg crank pulley, or is it custom? 1 Quote Link to comment
yello620 Posted March 7, 2011 Author Report Share Posted March 7, 2011 No chance of it working on the drivers side. The steering gearbox is in the way. 1 Quote Link to comment
Diesel33g Posted March 28, 2011 Report Share Posted March 28, 2011 This is a VG30E right? Seems like slim chance of a VG30DE fitting without ripping out the wheel wells and such. Nice build though :) 1 Quote Link to comment
yello620 Posted May 23, 2011 Author Report Share Posted May 23, 2011 More minor progress. I ordered an aluminum radiator a few months ago. All aluminum 19"x22" double pass radiator for a sprint car. Barely fits, actually bigger than i would have prefered, but cooling wont be a problem with this huge thing. Radiator is currently being modified to work, Lower neck angle change, mounting brackets, and removal of the filler neck. Told them i was not in a hurry(Ratsun member), hope to see it delivered back to me at Canby. I also dropped a spare driveline off to be shortened and balanced. Front half of the driveline needed shortened about 2.5", hope the rear half doesnt need expensive work cause it will need redone when the rearend gets changed out for something with an LSD, have a plan for that too. Should see the driveline next week sometime. Ordering a Magnaflow muffler this week too. Part #13236 1 Quote Link to comment
motavated Posted May 23, 2011 Report Share Posted May 23, 2011 Oh yeah... So in the end your going to convert to auto right? If that 5 speed any good? Are you willing to sell? 1 Quote Link to comment
yello620 Posted May 23, 2011 Author Report Share Posted May 23, 2011 Oh yeah... So in the end your going to convert to auto right? If that 5 speed any good? Are you willing to sell? Nope, i gave up on the auto. It was doable, but i was losing motivation dealing with the wiring to make the auto work, and i wanted the VG in a 620 to work. I am in this project way more time than i ever anticipated, but that is part of the reason that i bought a mock-up truck that was already thoroughly beat up. Was not going to take apart a driver for a swap that has not been documented. 1 Quote Link to comment
yello620 Posted May 28, 2011 Author Report Share Posted May 28, 2011 Got the shortened driveline back today. Driveline work has gotten expensive. They replaced one u-joint, shortened it, and balanced the two piece assembly, and it cost me $191. But it fits perfectly. Also ordered my Magnaflow muffler, should be here tomorrow. :D now i need to order some stainless mandrel bends to get the 2.5" pipe over the rear axle. 1 Quote Link to comment
Jester Posted May 28, 2011 Report Share Posted May 28, 2011 I think we need to see some progress pics. 1 Quote Link to comment
yello620 Posted May 28, 2011 Author Report Share Posted May 28, 2011 I think we need to see some progress pics. Nothing new to see, just doing some of the little stuff and collecting parts. Dont really have time to spend on it right now anyways, so trying to keep the parts coming so that when i do have time, i will have parts to work with. :D I will post pics when i get the radiator back. On a positive note. I saw youtube? video of vgwagon's 510 running the 1/4, turned a 14.22 with cam gears, headers, and pathfinder manifold. And no LSD. I was hoping that this VG conversion would put my truck into the mid 15's, and his wagon is a couple hundred pounds heavier than my 620 currently is, not sure yet just how much weight the VG will add though. Doesnt matter either. :D :D :D :D :hyper: :hyper: :hyper: 1 Quote Link to comment
izzo Posted May 28, 2011 Report Share Posted May 28, 2011 Aren't you or didn't you move or something? Never helps with time working on projects 1 Quote Link to comment
yello620 Posted May 28, 2011 Author Report Share Posted May 28, 2011 Aren't you or didn't you move or something? Never helps with time working on projects Still in the middle of moving, dont want to bring the donor swap truck with me. So trying to get the things done that still need the mock-up truck. Hoping to make it a bolt in deal into my yellow truck. Also went back to school, very little time to spare right now. Swap might be able to happen in July though, light school load before a heavy fall term. 1 Quote Link to comment
yello620 Posted June 14, 2011 Author Report Share Posted June 14, 2011 Picked up something at Canby since the price was right. Appear to be ceramic coated. $5 for the pair. :D Been working on the wiring, received my Magnaflow muffler, and i got my aluminum radiator modded to work. Need to finish the wiring, exhaust, and have not started the fuel system yet. 1 Quote Link to comment
yello620 Posted June 15, 2011 Author Report Share Posted June 15, 2011 ASSHOLE!!! As a matter of fact, i am. :D Dont forget who passed the first deal up and told you about it. :blink: 1 Quote Link to comment
Jester Posted June 15, 2011 Report Share Posted June 15, 2011 I know. I guess that makes you my favorite asshole. I just can't believe I had those in my hand and didn't buy them. My lack of knowledge helped someone out for a change. 1 Quote Link to comment
]2eDeYe Posted June 15, 2011 Report Share Posted June 15, 2011 Nice score! I know you got the radiator too, I suppose you haven't fit it yet? Otherwise there would be more pics :D 1 Quote Link to comment
yello620 Posted June 16, 2011 Author Report Share Posted June 16, 2011 2eDeYe' date='15 June 2011 - 08:51 AM' timestamp='1308153115' post='494471']Nice score! I know you got the radiator too, I suppose you haven't fit it yet? Otherwise there would be more pics :D Actually i did rest the radiator down in place, but i have not built any brackets for it yet. Bought the metal to make them though. I pulled the motor out today to start sealing it up. Need to get a gasket kit for it. Wiring is mostly done too. Should be able to fire it soon. But i had hoped for that two years ago. 1 Quote Link to comment
yello620 Posted June 19, 2011 Author Report Share Posted June 19, 2011 Engine gasket kit is ordered. :D Built brackets for the radiator. Got a new phone that takes excellent pictures, but cant seem to figure out how to get them off the phone and onto my computer/photobucket. I used to be able to text them to my email, wont work anymore for some reason. So a picture update is coming soon. 1 Quote Link to comment
Farmer Joe Posted June 19, 2011 Report Share Posted June 19, 2011 what kind of phone is it? androids have a photobucket app i think the iphone should too. dont know about blackberrys... pfft who has one of those anymore... lol im excited to see this run! 1 Quote Link to comment
yello620 Posted June 19, 2011 Author Report Share Posted June 19, 2011 It is a new android. But no data plan. I got it to send the exhaust manifold pic, but nothing since then. Will have to figure out the apparently for Photobucket. The one pic sent to my email,not Photobucket.: 1 Quote Link to comment
Z chopper Posted June 23, 2011 Report Share Posted June 23, 2011 I keep coming back to this and finally subscribed, I have a chance to get a VG30i with 5spd and a 620 so now time to pour over your thread and start asking questions about details that are not mentioned. 1 Quote Link to comment
yello620 Posted June 24, 2011 Author Report Share Posted June 24, 2011 Gasket kit has arrived. :D I took everything back apart, time to clean a few things up. Certainly not spottless, but plenty clean to put under a daily driver. :D Should have an update showing the radiator this weekend. School just started again. Taking an accelerated learning Chemistry class that has me buried in homework for the next four weeks. Basically putting a stop to all progress on this project for a few weeks. :( 1 Quote Link to comment
