slodat Posted October 28, 2009 Report Share Posted October 28, 2009 You should get ahold of Kyle. I think he may have what you need.. 1 Quote Link to comment
nismopu Posted October 28, 2009 Report Share Posted October 28, 2009 Didn't realize the m-30 mounted the starter on the bellhousing like the z32's. I thought it was traditional style like the z31's and pickups. The bellhousing will just unbolt off a z31 3n71b or 4n71b auto and should transfer over over to a newer RE040A like your M30 has. They're all an 8 bolt pattern but I don't know for sure if the pump case diameter is the same. Tigard pick n pull has two z31's right now ones a turbo 4n71b and the others an n/a 3n71b. I would go pull the bell housing off one of those cars and give it a shot. I have a z32 auto bell but I am positive its going to offer you the same problem your having now. 1 Quote Link to comment
yello620 Posted October 28, 2009 Author Report Share Posted October 28, 2009 Ya, i know about the two z31's at tigard. Not really looking forward to doing that work in the junkyard. I already pulled the engine oil pan from the non-turbo z31. That sucked. Front crossmember has to come out and the motor is attached to the crossmember. Was the motor still hanging from a chain and a driveline when you saw it? 1 Quote Link to comment
lynchfourtwenty Posted October 28, 2009 Report Share Posted October 28, 2009 yea i can see how an auto will help your back for sure :) just build another one for me w/ a 5spd :) 1 Quote Link to comment
kwoo510 Posted October 29, 2009 Report Share Posted October 29, 2009 I was able to put a VG in my 320 with the hood close. I fab,ed my own engine mount brackets and 510 engine mount. 1 Quote Link to comment
yello620 Posted October 29, 2009 Author Report Share Posted October 29, 2009 I was able to put a VG in my 320 with the hood close. I fab,ed my own engine mount brackets and 510 engine mount. Would like to see pics of this.. Did it get finished to a driving truck? Which intake did you use and do you have pics of the oil pan? Which transmission? Pics or it didn't happen:D 1 Quote Link to comment
lynchfourtwenty Posted October 29, 2009 Report Share Posted October 29, 2009 Pics or it didn't happen:D x2 1 Quote Link to comment
kwoo510 Posted October 29, 2009 Report Share Posted October 29, 2009 It can be done, but it takes a lot of effort and $$$. I started this project in March, 2008. I still have a few issues I haven't figured out. 1 Quote Link to comment
yello620 Posted November 5, 2009 Author Report Share Posted November 5, 2009 Worked on this a little more this evening. Mounted the VG engine rubbers to the 620 frame, just need to build a mount to go between the rubber and the motor. I also made a cardboard template of the oil pan profile for steering and crossmember clearance. This template shows where the crossmember and steering link will be at. Template is made to have approximately 1/2" clearance to the steering link and the crossmember. This design will be super easy to build. It will be combining the upper half of a Z31 pan and the lower half of a M30 pan. With all mods taking place below the factory installed baffling. However the oil pickup tube will also need shortened about 7/8". Capacity appears that it will be about 1/2 qt. more than the stock Z31 pan. This is the same template with a small bit added to the lower part of the pan for more oil capacity. However this addition would be a lot more work, and only increase the capacity about 3/4 qt. and it would hang way to close to the ground, but above a stock L series though. 1 Quote Link to comment
1badsrd510 Posted November 5, 2009 Report Share Posted November 5, 2009 Nice project......My project starts next year......VQ in my 620 1 Quote Link to comment
slodat Posted November 5, 2009 Report Share Posted November 5, 2009 I think combining the two pan halves is a good idea, especially if it works! There's the added bonus of possible repeatability.. 1 Quote Link to comment
yello620 Posted November 5, 2009 Author Report Share Posted November 5, 2009 With the two oil pans sitting beside each other and my template, this oil pan looks super easy. And very repeatable too, for anybody else that might dare take this project on. 1 Quote Link to comment
yello620 Posted November 18, 2009 Author Report Share Posted November 18, 2009 Little bit of progress today.:D Picked up another starter to try today, and this one looks like it will clear much better. Might have to shift the motor to the left about 1/4" to make the clearance a little happier. and i found a picture of another starter online that i will be going to the parts store to look at. It looks like it would have a even more clearance. So now i need to get my hands on a z31 bellhousing and attempt to see if it will fit the m30 trans.;) 1 Quote Link to comment
kwoo510 Posted November 18, 2009 Report Share Posted November 18, 2009 Little bit of progress today.:D Picked up another starter to try today, and this one looks like it will clear much better. Might have to shift the motor to the left about 1/4" to make the clearance a little happier. and i found a picture of another starter online that i will be going to the parts store to look at. It looks like it would have a even more clearance. So now i need to get my hands on a z31 bellhousing and attempt to see if it will fit the m30 trans.;) Not sure how your starter interfere with your truck. FYI, I've just compared the VG30E and VG33E starter a week ago, the VG33E starter is a bit skinnier and the starter solenoid is about at 11 o'clock position (you are facing the front of the engine). And the VG30E starter solenoid is around 9:30-10:00 o'clock position. 1 Quote Link to comment
yello620 Posted November 18, 2009 Author Report Share Posted November 18, 2009 Not sure how your starter interfere with your truck.FYI, I've just compared the VG30E and VG33E starter a week ago, the VG33E starter is a bit skinnier and the starter solenoid is about at 11 o'clock position (you are facing the front of the engine). And the VG30E starter solenoid is around 9:30-10:00 o'clock position. There are actually two different VG33 starter, those are the ones that i plan to look at at the parts store soon. That little difference in how it is "clocked" just might make all the difference. 1 Quote Link to comment
izzo Posted November 18, 2009 Report Share Posted November 18, 2009 nice man, excited to see this come along did you get both those 620s from brandon or just one? 1 Quote Link to comment
MicroMachinery Posted November 18, 2009 Report Share Posted November 18, 2009 Sweet deal man, good to hear you're making headway. What did this new starter come off? 1 Quote Link to comment
lynchfourtwenty Posted November 18, 2009 Report Share Posted November 18, 2009 just stick with the ol l20 jason... :lol::lol::lol::lol: :fu: jk ;) 1 Quote Link to comment
ariascarlos1990 Posted December 10, 2009 Report Share Posted December 10, 2009 any updates on this baby yet? looks like its going to be a solid build...:thumbup: I don't know if will work or not but, I have the auto 3spd from my truck you can have. 1 Quote Link to comment
lynchfourtwenty Posted December 10, 2009 Report Share Posted December 10, 2009 whats he gunna do with that? paper weight? hahahahaha :lol::lol: ya jason any progress man? its been mighty cold out.. cant wait to take ya in the 1/4 1 Quote Link to comment
yello620 Posted December 10, 2009 Author Report Share Posted December 10, 2009 It's freaking cold outside.:mad: So ia have been spending my outside time working on customer cars and then heading inside to warm up, but my wife found a smoking deal this evening on a propane torpedo heater. So that will get fired up tomorrow to see how it works, to bad i have a lot of work to do on another customer car. I did find a starter that clears everything really well so far. Best fit yet. I still need to find a Z31 bellhousing though. Carlos, thanks for the offer, i am going to check to see if it might work. 1 Quote Link to comment
lynchfourtwenty Posted December 10, 2009 Report Share Posted December 10, 2009 do you have a garage? if so that heater will be handy as hell man 1 Quote Link to comment
izzo Posted December 10, 2009 Report Share Posted December 10, 2009 It's freaking cold outside.:mad: So ia have been spending my outside time working on customer cars and then heading inside to warm up, but my wife found a smoking deal this evening on a propane torpedo heater. So that will get fired up tomorrow to see how it works, to bad i have a lot of work to do on another customer car. I did find a starter that clears everything really well so far. Best fit yet. I still need to find a Z31 bellhousing though. Carlos, thanks for the offer, i am going to check to see if it might work. You back to work? Or self employed now? 1 Quote Link to comment
yello620 Posted December 10, 2009 Author Report Share Posted December 10, 2009 do you have a garage? if so that heater will be handy as hell man Yes garage, but too big to heat with a little torpedo heater, hoping it will warm a small work area for me. Garage is 35w x 40 deep.:D You back to work? Or self employed now? No, not back to work yet. Not not self employed yet, might end up that way though. 1 Quote Link to comment
izzo Posted December 10, 2009 Report Share Posted December 10, 2009 Yes garage, but too big to heat with a little torpedo heater, hoping it will warm a small work area for me. Garage is 35w x 40 deep.:D No, not back to work yet. Not not self employed yet, might end up that way though. Sweet, open your own business. I am looking for work :lol: only a few classes left this semester for welding, after this i might take auto for a year, or just do one more semester of welding on mig/tig alum/stainless and throw that on the resume. 1 Quote Link to comment
