nis720 Posted October 18, 2009 Report Share Posted October 18, 2009 here is a small update. i bought a eprom chip that will take my speed limiter off and raise the rev limiter, a socket, and a consult cable. i already ruined a spare ecu trying to desolder the stock chip. so i will take it to a professional. i also found out that the consult wont work on my 8 bit 240sx ecu, so i have to hunt down a 16 bit stanza ecu. those have consult capabilities. i just need to read live sensor data. in order to find out whats causing my car to run slightly rich. for the moment the stock ecu will do just fine.im just happy that i didnt have any major problems building the car. ive been driving it for a couple of days now, and it drives awesome:D thanks Steve! An Auto ECU does not have that pesky rev limiter (in 4th and 5th gear). Another option to the Stanza ECU is Nistune. It has Consult capability and data logging. With the Stanza ECU you need the cable for the consult plug (I'm guessing you don't have the factory 240sx consult plug on your 510?), with nistune there's a USB port that goes right on the ECU and tunning can be done without having to open up the ECU and changing chips. Quote Link to comment
philcas1987 Posted October 23, 2009 Author Report Share Posted October 23, 2009 An Auto ECU does not have that pesky rev limiter (in 4th and 5th gear). Another option to the Stanza ECU is Nistune. It has Consult capability and data logging. With the Stanza ECU you need the cable for the consult plug (I'm guessing you don't have the factory 240sx consult plug on your 510?), with nistune there's a USB port that goes right on the ECU and tunning can be done without having to open up the ECU and changing chips. i had an auto. it ran a little off with it so i swapped it with a 5 speed one. i destroyed it trying to desolder the ecu chip. nistune would be the ticket. but i think im going to get a cam and lifters before i do that. Quote Link to comment
philcas1987 Posted October 23, 2009 Author Report Share Posted October 23, 2009 today i installed my msd 6al box and tach adapter. i got a real good deal on it. feels a little better. but not worth the price if i would have bought it retail:D. i got a small gear oil leak in the back of the tranny. i picked up some parts the seal everything up. im going to put this one off a bit just cause im being lazy. Quote Link to comment
philcas1987 Posted October 27, 2009 Author Report Share Posted October 27, 2009 not much to update lately. i installed a tornado knock off. in the hopes that it cleans up the air flow so the maf wont be all messed up. also picked up an remote oil filter adapter. im going to build it slowly. its not a priority but its nice not to spill oil all over the x member. Quote Link to comment
philcas1987 Posted November 9, 2009 Author Report Share Posted November 9, 2009 got more shit done. put on an aluminum cap on the rad,scored a 620 shifter plate and installed, now i need a 620 boot, made some free msd wires:D. got a oil filter base. Quote Link to comment
thisismatt Posted November 9, 2009 Report Share Posted November 9, 2009 Have you tried running it without the filter on the intake? Quote Link to comment
slodat Posted November 9, 2009 Report Share Posted November 9, 2009 Hey Phil - you can get high quality oil filters at Discount Import for $5. They have the Nissan part number on them.. Car is looking good! Quote Link to comment
philcas1987 Posted November 9, 2009 Author Report Share Posted November 9, 2009 Have you tried running it without the filter on the intake? you know I never have. I'll have to try one day Quote Link to comment
philcas1987 Posted November 9, 2009 Author Report Share Posted November 9, 2009 Hey Phil - you can get high quality oil filters at Discount Import for $5. They have the Nissan part number on them.. Car is looking good! thanks! The filter is just for mock up. I run wix. Is the nissan ones better? Quote Link to comment
philcas1987 Posted November 19, 2009 Author Report Share Posted November 19, 2009 not too long ago i gave parking lot drifting a try (i suck at it:(). a couple of things that need attention came up. my diff leaks cause i have no vent. shifter plate or rear tranny seal leak. need to hook up a front sway bar. my fuel filler neck leaks fuel. i took care of these problems exept the filler neck. i have a late 69 so it had the one piece one. i kept the three piece one of my 4 door. so i will be converting it. i ordered the top elbow from nissan in olympia. its a week late:mad:. i also added an ebay catch can. shit works. i must have lots of blow by. i undid the drain, and a bunch of oily crud poured all over my hand and frame rail. 240sx front links work great with my datsport sway bar:D new diff vent new plate gasket, 620 boot,240sx inner boot. catch can ka inside sticker:fu: Quote Link to comment
hang_510 Posted November 19, 2009 Report Share Posted November 19, 2009 catch can. shit works. i must have lots of blow by. i undid the drain, and a bunch of oily crud poured all over my hand and frame rail. :lol: i collect about 750ml after 2 tanks of gas, LOTS of moisture too! :blink: well i did... its dead now :mellow: Quote Link to comment
heirfaus Posted November 21, 2009 Report Share Posted November 21, 2009 Man, that thing is coming along real nice! Looking good Phil!!!!! Quote Link to comment
philcas1987 Posted November 25, 2009 Author Report Share Posted November 25, 2009 ive been dealing with fuel smell inside the cabin. my gf really hated to ride in the car. this whole time i thought it was the one piece filler neck. but it was just a vent hose. turns out the one piece filler neck is a nos piece. its beautiful. im going to keep it unless someone offers me a good chunk of change for it. i converted to a three piece neck and replaced everything while i was at it. if it leaks now. im going to be pissed off. that oem filler elbow was spendy. Quote Link to comment
heirfaus Posted November 25, 2009 Report Share Posted November 25, 2009 (edited) Dude, I didn't say anything because you said you wanted to use the one piece, but I wish I had known you were doing the 3 piece. I have 3 new top pieces in a box in the attic. They were like 16 bucks each when I bought them, I figured I'd stock up. BTW I replaced that stuff and then eventually found my fuel smell which was a loose clamp on the top connection on my vapor tank :( took about 26 seconds to find with a smoke machine..... BTWW I ordered that same catch can the other day :) Edited November 25, 2009 by heirfaus Quote Link to comment
philcas1987 Posted December 16, 2009 Author Report Share Posted December 16, 2009 got a set of 14" enkei apache mesh with new 195 60 14 falken ziex ze912. got a good deal from Jeremy (sssr20det). went down this to his shop this morning and got them installed:fu: JEREMY from PREMIUM AUTO hard at work.thanks again:D Quote Link to comment
sssr20det510 Posted December 16, 2009 Report Share Posted December 16, 2009 looks good needs to be lower lol Quote Link to comment
philcas1987 Posted December 16, 2009 Author Report Share Posted December 16, 2009 looks good needs to be lower lol thats the plan. right now im enjoying daily driving it. i dont have to worry about bumps and drive ways. they do look best slammed. i want to do it right. doing it right costs$$$ Quote Link to comment
philcas1987 Posted December 17, 2009 Author Report Share Posted December 17, 2009 my gf and mom pooled in some money to give me as a christmas present:D:D:D to buy whatever i wanted for my car. i hate having a vw part in my car. the effing radiator! so i ordered an afco from summit. it came in today. its not going in until next year. gotta save up in order to do a clean install. this thing is hella beefy Quote Link to comment
jesusno2 Posted December 17, 2009 Report Share Posted December 17, 2009 you still got a funky idle with your ka? i pmed you a while ago about it. just wondering if driving it some has helped any? Quote Link to comment
philcas1987 Posted December 17, 2009 Author Report Share Posted December 17, 2009 the idle has settled a bit. my tach resistor burned out so no tach signal. ecu code 21 no primary signal. i have one ordered from nissan. the idle settled a bit after i did this. to set the idle i unplugged the tps then the iacv, set the idle rpm using the ilde screw,plugged the iacv in then tps. Quote Link to comment
philcas1987 Posted December 30, 2009 Author Report Share Posted December 30, 2009 hella 500's cool it sound deadner on rear shelf bumpsteer spacers z car aluminium finned drums a while back my tach died. i traced it to the tach resistor on the coil harness. i bought the resistor and condenser from nissan:D Quote Link to comment
philcas1987 Posted December 30, 2009 Author Report Share Posted December 30, 2009 i need 1/4 window latches bad. so i got these from nissan. i guess i need other brackets too. my 2 door came with no latch parts.i need even the screws:confused: radiator swap parts fan temp switch universal lower hose sacrificial anode this is a never ending project. Quote Link to comment
nis720 Posted December 30, 2009 Report Share Posted December 30, 2009 This reminds me of when I did my swap.... never ending list of things needed and a very large wishlist of things you want but don't necessarily need. It's looking good and will pay off in the end. Quote Link to comment
JDM510R Posted January 3, 2010 Report Share Posted January 3, 2010 Nice project thread you got going. Updates? Quote Link to comment
78kingcab Posted January 3, 2010 Report Share Posted January 3, 2010 :cool:dude , you got one hell of a build thread ...bad azz dime...i want to drive it.lol. where can i score a front air dam like yours... :cool: Quote Link to comment
