philcas1987 Posted September 8, 2009 Author Report Share Posted September 8, 2009 ive been collecting front end parts for a while now. im running 280zx struts with 510 perches, kyb gr2 strut inserts, and nissan comp lowering springs, 280zx hubs with arp studs, new ball joints with poly dust boots, poly lca bushings, with old school camber adjusters, techno toy tc rods, new 555 tie rods with poly dust boots, and a experimental engineering delrin idler arm bushing. im missing some pictures:fu: Quote Link to comment
DISLEXICDIME Posted September 8, 2009 Report Share Posted September 8, 2009 dam speed racer you are going to be shredding peoples tires with those lug nuts Quote Link to comment
philcas1987 Posted September 10, 2009 Author Report Share Posted September 10, 2009 dam speed racer you are going to be shredding peoples tires with those lug nuts Yeah so you better not try to pull one on me. I'll leave you on the side of the road dusted. :fu: Quote Link to comment
inline4 Posted September 10, 2009 Report Share Posted September 10, 2009 okay, so i picked up a stanza speedo. I'm hoping it will work with the dohc ka. how do you wire this badboy up? Quote Link to comment
philcas1987 Posted September 10, 2009 Author Report Share Posted September 10, 2009 okay, so i picked up a stanza speedo. I'm hoping it will work with the dohc ka. how do you wire this badboy up? ok ill take pictures of it tommorow. i dont think it will work on the dohc. Quote Link to comment
philcas1987 Posted September 10, 2009 Author Report Share Posted September 10, 2009 i finished drilling out the spot welds on the busted valance. now i just have to find one. Quote Link to comment
nismopu Posted September 10, 2009 Report Share Posted September 10, 2009 lookin good phil! Quote Link to comment
DISLEXICDIME Posted September 10, 2009 Report Share Posted September 10, 2009 we can try to straighten the gray valance for now Quote Link to comment
CorAce Posted September 10, 2009 Report Share Posted September 10, 2009 I got one you can have, its not great but its better than yours. It will need some dolly work to be perfect. Besides you’ll never see it with an air dam and bumper. Quote Link to comment
Skib Posted September 10, 2009 Report Share Posted September 10, 2009 lookin good phil :fu: Quote Link to comment
philcas1987 Posted September 10, 2009 Author Report Share Posted September 10, 2009 I got one you can have, its not great but its better than yours. It will need some dolly work to be perfect. Besides you Quote Link to comment
philcas1987 Posted September 10, 2009 Author Report Share Posted September 10, 2009 a while back i dropped off my 68 x-member to Nelson from Altered Motives. he did all the necessary modifications to reverse it. i picked it up today and installed it along with some nos motor mounts. keep in mind that the 68 has slightly higher lca mounting points. i also got rid off the old school camber adjusters. for some reason they hit the idler arm. i also mocked up the radiator and fan. radiator is a valeo vw and fan is a 12" ebay special. more updates to come soon. Quote Link to comment
DISLEXICDIME Posted September 11, 2009 Report Share Posted September 11, 2009 hows your camber in the front Quote Link to comment
philcas1987 Posted September 11, 2009 Author Report Share Posted September 11, 2009 hows your camber in the front its going to be off for shure. i wont know how much until i take it to the alignment shop:( Quote Link to comment
philcas1987 Posted September 11, 2009 Author Report Share Posted September 11, 2009 on my KAe swap i wasnt going to waste time figuring out how to hook up a speedo cable to the stock guage cluster. i looked at a 240sx speedo but it was to big to fit inside the cluster. so i was at a wrecking yard one day and a idea popped in to my head as i was laying waste to a stanza ka. why not use its speedo. its the same engine too. there is 4 wires that hook up to the back if this thing. i got a headache looking through wiring diagrams. so i said fuck its only 4 wires. two have to go to the speed sensor,one to the ecu, and another to what ever it goes to. on the back of the board there was some makings that gave me an idea on how to wire it up. i mocked it up on the garage floor with a battery, spun the speed sensor. nothing!. i was like shit there has to be a ground. so i wired up a ground to one of the sensors wires, spun the sensor, success i have a working speedo that is backlit!!. i had to trim the guage face so it can fit inside the cluster. i cant exactly say how i mounted the speedo to the cluster, i just used parts from broken toys in the garage. ok so the wiring goes like this. the screw threads you bolt your wires to is, top,bottom,right, and left. the top lug goes to the wire that feeds the speed signal to the ecu.bottom goes to switched power.right goes to speed sensor.left goes to speed sensor, and it also goes to ground. on the wires that go to the sensor i cant say waht wire goes to what wire on the sensor but its only two so if it doesnt work switch them over. :D:fu: Quote Link to comment
mklotz70 Posted September 11, 2009 Report Share Posted September 11, 2009 That's pretty dang creative!! Sweet! Quote Link to comment
DISLEXICDIME Posted September 11, 2009 Report Share Posted September 11, 2009 we can shave down that lca bolt we had to do that with steves old car Quote Link to comment
OpelWagenGT Posted September 12, 2009 Report Share Posted September 12, 2009 wow I just want to say this really makes me want to do a swap into my 1200 but I know that is a lot of work and money I don't have right now. :( Quote Link to comment
philcas1987 Posted September 13, 2009 Author Report Share Posted September 13, 2009 im just killing time. help is on the way. my kae is going in today! anyway here is a small up date. its a thule rack.i just need to scrounge up the wind deflector and the piece to attach my road bike:fu: Quote Link to comment
kiznook Posted September 13, 2009 Report Share Posted September 13, 2009 I think I might have a wind deflector laying around somewhere. Let me know. Quote Link to comment
philcas1987 Posted September 14, 2009 Author Report Share Posted September 14, 2009 i got my ka in without a hitch today. with the help of Dislexicdime. thanks:D strut bar ftw big thanks to mikey (dislexicdime) :fu: Quote Link to comment
Skib Posted September 14, 2009 Report Share Posted September 14, 2009 awesome :fu: Quote Link to comment
heirfaus Posted September 14, 2009 Report Share Posted September 14, 2009 Man, wish I could have been there :( Oh well the wedding was fun....next time :) Quote Link to comment
DISLEXICDIME Posted September 14, 2009 Report Share Posted September 14, 2009 that ka was so easy to put in! my l18 was harder to get in. Quote Link to comment
heirfaus Posted September 14, 2009 Report Share Posted September 14, 2009 Hey Phil, how sturdy is that rack? I am looking for a way to transport my bike too and wonder how that one feels when mounted. Quote Link to comment
