r0p0doe Posted May 12, 2014 Report Share Posted May 12, 2014 Changed out my leaking fuel pressure regulator for a pretty much new one I bought off of a member here, works like a charm just need to adjust it and tighten some things. Quote Link to comment
edekalil Posted May 13, 2014 Report Share Posted May 13, 2014 Jacked up the rear and put the 8mm spacers on and could not resist to put these on the rear of the car. 1 Quote Link to comment
INDY510 Posted May 13, 2014 Report Share Posted May 13, 2014 You better not drive with ANY spacers .... unless you get longer lug studs (which are almost impossible to install with rear drum brakes) Quote Link to comment
datsunfreak Posted May 13, 2014 Report Share Posted May 13, 2014 unless you get longer lug studs (which are almost impossible to install with rear drum brakes) Actually, it's really easy. :rofl: Quote Link to comment
edekalil Posted May 13, 2014 Report Share Posted May 13, 2014 You better not drive with ANY spacers .... unless you get longer lug studs (which are almost impossible to install with rear drum brakes)I'm going to put the other rims back on I just had to see this wheel on the car and make sure the weights would not rub the swing arm and it does not. Quote Link to comment
Busta Nut Posted May 13, 2014 Report Share Posted May 13, 2014 You better not drive with ANY spacers .... unless you get longer lug studs (which are almost impossible to install with rear drum brakes) With an 8mm spacer I ran the stock studs........theres just enough for a good grab......... .................................just make sure you torque'em and double check it after the first run.......... 1 Quote Link to comment
Son_of_a_Datsun_Guy Posted May 13, 2014 Report Share Posted May 13, 2014 With an 8mm spacer I ran the stock studs........theres just enough for a good grab......... .................................just make sure you torque'em and double check it after the first run.......... I'm running a 1/4 in spacer on my rears, only get like 5-6 full threads but it should be enough... I have lost lug nuts before though. Quote Link to comment
jovial_cynic Posted May 13, 2014 Report Share Posted May 13, 2014 Built an arduino-based multi-gauge indicator. So useful for any car, but this one is going to live in my 510. https://www.youtube.com/watch?v=Mw6Cf_TSfcA Quote Link to comment
datsunfreak Posted May 13, 2014 Report Share Posted May 13, 2014 only get like 5-6 full threads but it should be enough... I have lost lug nuts before though. The general rule of thumb for safety is that you need as many threads engaged as the width of the bolt. So on a 12x1.25 stud (stock), you want at least 12mm of the threads engaged, so 12mm of depth with a 1.25 thread pitch is 9.6 tuns of the lug nut. Any less than that is not "safe". If you haven't already, swapping to the 10mm longer Nissan Quest rear studs would solve the problem, and still be easy to install (unlike the ARP studs). :thumbup: 1 Quote Link to comment
Busta Nut Posted May 14, 2014 Report Share Posted May 14, 2014 The general rule of thumb for safety is that you need as many threads engaged as the width of the bolt. So on a 12x1.25 stud (stock), you want at least 12mm of the threads engaged, so 12mm of depth with a 1.25 thread pitch is 9.6 tuns of the lug nut. Any less than that is not "safe". If you haven't already, swapping to the 10mm longer Nissan Quest rear studs would solve the problem, and still be easy to install (unlike the ARP studs). :thumbup: Yes....true.....but we don't always play by the rules...... Just sayin'........I ran it like that......checked lug torque periodically.......never had one come loose..... I torqued them to 80lbs........ Quote Link to comment
Busta Nut Posted May 14, 2014 Report Share Posted May 14, 2014 Slow day today.........spur of the moment paint session....... 2 Quote Link to comment
edekalil Posted May 14, 2014 Report Share Posted May 14, 2014 The general rule of thumb for safety is that you need as many threads engaged as the width of the bolt. So on a 12x1.25 stud (stock), you want at least 12mm of the threads engaged, so 12mm of depth with a 1.25 thread pitch is 9.6 tuns of the lug nut. Any less than that is not "safe". If you haven't already, swapping to the 10mm longer Nissan Quest rear studs would solve the problem, and still be easy to install (unlike the ARP studs). :thumbup: I will go seethe partsman at the Nissan dealer here and check out those studs maybe today.Thanks Quote Link to comment
edekalil Posted May 14, 2014 Report Share Posted May 14, 2014 Datsunfreak what year Quest van rear studs so I will know what to ask the parts guy. Also what do you mean when you say ARP studs. Quote Link to comment
Dime Dave Posted May 14, 2014 Report Share Posted May 14, 2014 Quest studs are Dorman P/N 610-403, 45.5mm long Stock 510 studs are: 32mm (front) 41.5mm (rear) If you need longer, FutoFab has 60mm @ $3.50/ea Quote Link to comment
paradime Posted May 14, 2014 Report Share Posted May 14, 2014 Every time I go into the garage to do my laundry my 510 mocks me in a passive aggressive needy way, so I kicked it. This weekend I'll fix the dent and try and patch things up between us. Having a relationship with an old car is hard work. Quote Link to comment
edekalil Posted May 14, 2014 Report Share Posted May 14, 2014 Quest studs are Dorman P/N 610-403, 45.5mm long Stock 510 studs are: 32mm (front) 41.5mm (rear) If you need longer, FutoFab has 60mm @ $3.50/ea Thank you Dave I'll be making another order soon. Quote Link to comment
datsunfreak Posted May 14, 2014 Report Share Posted May 14, 2014 . Also what do you mean when you say ARP studs. ARP #100-7708. Pops right into the stock holes, but they are 2.5" long. Then you can usually run up to a 1" spacer in the rear and a 1.25" spacer up front and still have about 15-20mm of thread engagement. :thumbup: http://www.summitracing.com/parts/arp-100-7708 Quote Link to comment
67_1600 Posted May 15, 2014 Report Share Posted May 15, 2014 New gas cap! Nothing special but it fits really well and looks a lot better than the smaller one I had. I'd rather have something with a chrome or stainless handle - maybe I'll find one at the swap meet this weekend. Quote Link to comment
edekalil Posted May 15, 2014 Report Share Posted May 15, 2014 ARP #100-7708. Pops right into the stock holes, but they are 2.5" long. Then you can usually run up to a 1" spacer in the rear and a 1.25" spacer up front and still have about 15-20mm of thread engagement. :thumbup: http://www.summitracing.com/parts/arp-100-7708 I do believe I will for sure need some of those for the front of the car that is all apart and will have the 280zx setup on the front from what I have read. Thanks Quote Link to comment
Dime Dave Posted May 15, 2014 Report Share Posted May 15, 2014 ARP #100-7708. Pops right into the stock holes, but they are 2.5" long. Then you can usually run up to a 1" spacer in the rear and a 1.25" spacer up front and still have about 15-20mm of thread engagement. :thumbup: http://www.summitracing.com/parts/arp-100-7708 The ARP studs are 12 x 1.5 thread. That means you'll need lug nuts. Quote Link to comment
Busta Nut Posted May 15, 2014 Report Share Posted May 15, 2014 I do believe I will for sure need some of those for the front of the car that is all apart and will have the 280zx setup on the front from what I have read. Thanks If you're gonna run those Z wheels with 280zx struts you will......... Quote Link to comment
datsunfreak Posted May 15, 2014 Report Share Posted May 15, 2014 The ARP studs are 12 x 1.5 thread. That means you'll need lug nuts. But, it gets you to a thread pitch with waaaaaaaaay more lug nut options. ;) As far as I've seen, only Nissan and Subaru use the 12x1.25 pitch. Pretty much every other car company in the world uses 12x1.5. :thumbup: Quote Link to comment
510T Posted May 17, 2014 Report Share Posted May 17, 2014 Got this fender on today: 6 Quote Link to comment
Busta Nut Posted May 18, 2014 Report Share Posted May 18, 2014 That's hideous.......take it off....... :lol: 2 Quote Link to comment
edekalil Posted May 19, 2014 Report Share Posted May 19, 2014 Just recived this for the 72/510. And pulled the cars out of the garage. 1 Quote Link to comment
