Juanjoze Posted April 23, 2023 Report Share Posted April 23, 2023 Hello, first of all I would like to thank this community, because I found a lot of information and inspiration to modify my truck by myself. I would also like to thank a friend from the Datsun community in Mexico who shared his experience making the modification. Parts that were used. - LCA From Datsun 720. - LCA Bushing From Datsun 720. - LCA Torsion bar Anchor and Sun Bolt (Lower Control Arm Bolt) from 720. - Torsion Bars and Rear Anchor from 521. - Spindle and Hub from Datsun 720. - Brake Disck, Calipers, Brake Hose from Datsun 720. - UCA From Chevrolet Luv 95-05 From Mexico, ISUZU pick up USA. - Datsun 620 Strut Rod or Tension Rod. Heim Joints. How to. - Remove LCA, UCA, Tension Rod, Brake Hose from truck. - Optional: Remove the LCA bushing or use flat washers to fill the new LCA gap. First problem, if you mount a newer 720 LCA hub to fit the gap in the control arm perfectly, the torsion bars push back almost 3/8", I have to re-drill the bracket mounting holes of the rear torque arm to pick it up. -Drill the upper ball joint hole on the spindle to take the wider isuzu ball joint. 6 Quote Link to comment
]2eDeYe Posted April 23, 2023 Report Share Posted April 23, 2023 Nice solution. Looks great, thanks for sharing. 🙂 1 Quote Link to comment
Stoffregen Motorsports Posted April 23, 2023 Report Share Posted April 23, 2023 Nice clean work. 1 Quote Link to comment
thisismatt Posted April 23, 2023 Report Share Posted April 23, 2023 Looks good. Aligned it professionally yet? Results? 1 Quote Link to comment
greenthumb Posted April 23, 2023 Report Share Posted April 23, 2023 Standard 521 tie rods and Center link? 1 Quote Link to comment
Juanjoze Posted April 24, 2023 Author Report Share Posted April 24, 2023 7 hours ago, thisismatt said: Looks good. Aligned it professionally yet? Results? Not yet, I will update the results this week. 2 Quote Link to comment
Juanjoze Posted April 24, 2023 Author Report Share Posted April 24, 2023 Just now, greenthumb said: Standard 521 tie rods and Center link? - Standar 521 Center Link. - 720 - Hardbody Tie Rods. 2 Quote Link to comment
uberkevin Posted April 24, 2023 Report Share Posted April 24, 2023 This is intriguing. Thanks for sharing the info you've found so far. 1 Quote Link to comment
thisismatt Posted April 24, 2023 Report Share Posted April 24, 2023 1 hour ago, Juanjoze said: Not yet, I will update the results this week. Cool, thanks. Just noticed your TC rod bolt at the heim isn't reaching the nyloc portion, but maybe you fixed that already 2 Quote Link to comment
Juanjoze Posted April 24, 2023 Author Report Share Posted April 24, 2023 Just now, thisismatt said: Cool, thanks. Just noticed your TC rod bolt at the heim isn't reaching the nyloc portion, but maybe you fixed that already Thanks, that was my last mockup before tightening the nuts. 2 Quote Link to comment
pidge Posted April 27, 2023 Report Share Posted April 27, 2023 That’s pretty cool. Some pretty neat idea you’ve got going on. 👍👍👍 Aren’t the holes in the top of spindle tapered or am I thinking wrong? I spose you could get lowering spindles if they stilll make them. Dose it fit 14” wheels still? I love the idea and keep us posted. -Pidge 1 Quote Link to comment
NC85ST Posted April 27, 2023 Report Share Posted April 27, 2023 If it’s basically all 720 stuff, then a 14” wheel shouldn’t have a problem fitting. Two wheel drive 720 wheels were 14” from the factory. 1 Quote Link to comment
uberkevin Posted April 27, 2023 Report Share Posted April 27, 2023 Man there's an 81 720 in a yard near me, im tempted to start pulling parts from it.. 1 Quote Link to comment
Wildcat Walker Posted April 27, 2023 Report Share Posted April 27, 2023 Need to see alignment sheet. And pictures of wheel centered in fender. If this works, great information. 1 Quote Link to comment
Juanjoze Posted April 27, 2023 Author Report Share Posted April 27, 2023 1 hour ago, NC85ST said: If it’s basically all 720 stuff, then a 14” wheel shouldn’t have a problem fitting. Two wheel drive 720 wheels were 14” from the factory. Hi, stock 521 wheels, will not fit, because hub wheel bore, but 720 14 steel wheels fit perfect. 1 Quote Link to comment
Juanjoze Posted April 27, 2023 Author Report Share Posted April 27, 2023 Not everything went so smoothly, the previous owner somehow bent the shock towers. Camber was almost +2.5 degrees, I used almost 3/4 inch on shims. I don't know what would be better, cut the upper control arms to reduce camber or keep the shims, what do you think? 1 Quote Link to comment
Juanjoze Posted April 27, 2023 Author Report Share Posted April 27, 2023 9 minutes ago, Wildcat Walker said: Need to see alignment sheet. And pictures of wheel centered in fender. If this works, great information. Sorry friend, the only lineup available in my town is with classic Camber Caster Gauge. i will Post some pics. 1 Quote Link to comment
Juanjoze Posted April 27, 2023 Author Report Share Posted April 27, 2023 7 hours ago, pidge said: That’s pretty cool. Some pretty neat idea you’ve got going on. 👍👍👍 Aren’t the holes in the top of spindle tapered or am I thinking wrong? I spose you could get lowering spindles if they stilll make them. Dose it fit 14” wheels still? I love the idea and keep us posted. -Pidge Yes, you're right, it takes some day with a dremel and a lot of patience, basically I was cutting and checking the seat of the ball joint with ink. The tip of sandpaper and Aluminum Oxide Grinding Stone worked better for me. 1 1 Quote Link to comment
thisismatt Posted April 27, 2023 Report Share Posted April 27, 2023 Can also get the correct tapered reamer 👍 Quote Link to comment
Juanjoze Posted April 27, 2023 Author Report Share Posted April 27, 2023 Just now, thisismatt said: Can also get the correct tapered reamer 👍 Even get they Dremel Aluminum Oxide Grinding Stone was really hard in My Town, But a reamer will be great. Quote Link to comment
d.p Posted April 28, 2023 Report Share Posted April 28, 2023 OP makes this sound so simple…. Is everything after ”Remove….” Optional? How to. - Remove LCA, UCA, Tension Rod, Brake Hose from truck. - Optional: Remove the LCA bushing or use flat washers to fill the new LCA gap. First problem, if you mount a newer 720 LCA hub to fit the gap in the control arm perfectly, the torsion bars push back almost 3/8", I have to re-drill the bracket mounting holes of the rear torque arm to pick it up. -Drill the upper ball joint hole on the spindle to take the wider isuzu ball joint. Quote Link to comment
Juanjoze Posted April 28, 2023 Author Report Share Posted April 28, 2023 Optional Just lower control arm bush is optional, and if you go that way, it's necessary to adjust the rear bracket where the torsion bars are anchored. Implicit: - Change brake hoses. - Change the terminal of the rigid brake lines from 3/8 to 10mm fittings. - Drill spindles upper ball joint hole. - Drill upper control arms mount holes to 14mm or 9/16. - Get shims ando 9/16nf x 4" grade 8 bolts. - Front tensión rods, I used heim joints, you could solder the 720 mounts. - Replace Master Cylinder from single to.dual. I'm just testing, so far it works fine. 1 Quote Link to comment
datzenmike Posted April 28, 2023 Report Share Posted April 28, 2023 The 521 loves you for this. Probably would work on the 620??? 1 Quote Link to comment
