LilDotty74 Posted April 29, 2020 Author Report Share Posted April 29, 2020 (edited) Need to order a 2” gauge set and put on finishing touches Edited April 29, 2020 by LilDotty74 Quote Link to comment
BrothersGarage Posted April 30, 2020 Report Share Posted April 30, 2020 That dash look sick! What are the red buttons for on the sides? 2 Quote Link to comment
LilDotty74 Posted April 30, 2020 Author Report Share Posted April 30, 2020 2 minutes ago, BrothersGarage said: That dash look sick! What are the red buttons for on the sides? Haha thanks they pop the doors open 2 Quote Link to comment
BrothersGarage Posted April 30, 2020 Report Share Posted April 30, 2020 22 minutes ago, LilDotty74 said: Haha thanks they pop the doors open Uh huh, can't fool me twice! 😄 Really slick! 2 Quote Link to comment
Jersey Posted May 1, 2020 Report Share Posted May 1, 2020 Are you running the inside door button release as an, in addition to, or instead of, the regular inside handles? If instead of...You might consider (if you haven’t) running an auxiliary cable release on one/both doors. That 620 that my brother had years ago had only button release on the inside and sometimes they didn’t work...So we’d have to climb out of the window. I love Datsun 620s! However, that one... 3 1 Quote Link to comment
LilDotty74 Posted May 1, 2020 Author Report Share Posted May 1, 2020 3 hours ago, Jersey said: Are you running the inside door button release as an, in addition to, or instead of, the regular inside handles? If instead of...You might consider (if you haven’t) running an auxiliary cable release on one/both doors. That 620 that my brother had years ago had only button release on the inside and sometimes they didn’t work...So we’d have to climb out of the window. I love Datsun 620s! However, that one... In addition to the original handles, I wanted to make sure I had a Mechanical way of getting out in case of emergency or the car dies, they are more just for aesthetic purposes and flash but will be completely fictional. Haha yeah I don’t want to be climbing out the window but you gotta do what you gotta do ! Ha 3 Quote Link to comment
LilDotty74 Posted May 1, 2020 Author Report Share Posted May 1, 2020 Electric dizzy came in the mail today !!! 5 Quote Link to comment
Jersey Posted May 1, 2020 Report Share Posted May 1, 2020 Yeah climbing out of the window when you’re 18 is a lot different than when you’re...Older... 2 2 Quote Link to comment
BrothersGarage Posted May 1, 2020 Report Share Posted May 1, 2020 23 minutes ago, Jersey said: Yeah climbing out of the window when you’re 18 is a lot different than when you’re...Older... I don''t think my back or gut would like me even attempting it. 4 Quote Link to comment
banzai510(hainz) Posted May 1, 2020 Report Share Posted May 1, 2020 Is that the HotSpark distributor? for like 60$ can you do a short vid on how its installed compared to the stock one. Meaning is it drop in, use the stock plate from the old dist, or move the oil spindal a tooth, or flip the timming plate that come with it ecttt to make this work. I know I can be done but like to see some do it then post on you tube in the how to section. Nobody can give me a sure EZ install as the tiimming plate miight not match the mount used by the orginal mount.(don't line up as the L16 and L20 ones are different tang orientation. I know it say fit all L series but it not really a true drop in as most think. 1 1 Quote Link to comment
LilDotty74 Posted May 1, 2020 Author Report Share Posted May 1, 2020 8 minutes ago, banzai510(hainz) said: Is that the HotSpark distributor? for like 60$ can you do a short vid on how its installed compared to the stock one. Meaning is it drop in, use the stock plate from the old dist, or move the oil spindal a tooth, or flip the timming plate that come with it ecttt to make this work. I know I can be done but like to see some do it then post on you tube in the how to section. Nobody can give me a sure EZ install as the tiimming plate miight not match the mount used by the orginal mount.(don't line up as the L16 and L20 ones are different tang orientation. I know it say fit all L series but it not really a true drop in as most think. Yeah, I figured as much you get what you pay for. I’ll do my best to do a detailed explanation of installation and all the issues I encounter I’ll post it up tomorrow or later today 2 Quote Link to comment
banzai510(hainz) Posted May 1, 2020 Report Share Posted May 1, 2020 ONE guy got that distributor and said it worked ok but then he dissappeard. he said to had to rig the plate and move the oil drive spindal i think but be nice to have something on the web so people can reference to for later . I myself know I can make it work but be nice for novice folks to have something to ref too. also mos distributors are getting worn and maybe this will work. I know its China but for 60$ and use the ballast resistor like in the instructions I assume it should be ok. really I ue a PowerSelect Rockauto 35amp alternator and I got 3 yrs out of it so far. The rebuilds don't even last me 8months. I stick with the small 35amper. 2 Quote Link to comment
LilDotty74 Posted May 1, 2020 Author Report Share Posted May 1, 2020 That sounds solid, Im most definitely not going rebuilt next time I’ll post videos and pictures 1 Quote Link to comment
banzai510(hainz) Posted May 1, 2020 Report Share Posted May 1, 2020 (edited) I just notice your dist is different than the one I’m the ad. the Nissan one should be a clip dist cap and the one in the ad is a clip type the one you have a photo of is screwed in cap and a square rectangle center connector??so one needs to know what car that comes from to replace it. maybe they made a mistake shipping the wrong one let is know Edited May 1, 2020 by banzai510(hainz) 2 Quote Link to comment
LilDotty74 Posted May 3, 2020 Author Report Share Posted May 3, 2020 Ok guys so to my surprise that dizzy was pretty much direct hookup, yes it had screw top and different color wires, but all I had do was drill the hole in the bracket slightly wider so it wouldn’t rub on the bolt but other than that it was a easy install no extra hang ups definitely recommended coil doesn’t get hot and truck runs 1000% better 3 Quote Link to comment
gene knight Posted May 3, 2020 Report Share Posted May 3, 2020 nice dash setup. when i shaved my door handles on my S10 xtreme back in 2005 i ran a bicycle brake cable under the cab and along the frame rail in case of dead battery or remote for door popper quit working. On 5/1/2020 at 11:12 AM, LilDotty74 said: In addition to the original handles, I wanted to make sure I had a Mechanical way of getting out in case of emergency or the car dies, they are more just for aesthetic purposes and flash but will be completely fictional. Haha yeah I don’t want to be climbing out the window but you gotta do what you gotta do ! Ha 1 Quote Link to comment
banzai510(hainz) Posted May 3, 2020 Report Share Posted May 3, 2020 Ok looks like you have the more common L20 distributor mount.thats what I need to know.the L16 one the tang is more at 90deg and screw hole would be way toward the shaft underneath be nice to know what dist cap and rotor to order i might order one but want the Datsun one with the clips 1 Quote Link to comment
LilDotty74 Posted May 4, 2020 Author Report Share Posted May 4, 2020 Haters will hate haha 1 Quote Link to comment
LilDotty74 Posted May 4, 2020 Author Report Share Posted May 4, 2020 She’s getting there definitely come along way 2 Quote Link to comment
Crashtd420 Posted May 4, 2020 Report Share Posted May 4, 2020 11 hours ago, LilDotty74 said: Haters will hate haha Do you know how many ratsun guys have a similar setup.... I have had a Gatorade bottle catching my coolant for almost 2 years... I keep saying I'll buy a proper over flow and never do..... Looks good to me... 2 Quote Link to comment
LilDotty74 Posted May 4, 2020 Author Report Share Posted May 4, 2020 4 minutes ago, Crashtd420 said: Do you know how many ratsun guys have a similar setup.... I have had a Gatorade bottle catching my coolant for almost 2 years... I keep saying I'll buy a proper over flow and never do..... Looks good to me... Gatorade bottle compared to Japanese giant ramune bottle? I wouldn’t call that a similar set up.... but thanks Quote Link to comment
banzai510(hainz) Posted May 4, 2020 Report Share Posted May 4, 2020 I got Gatorade bottle Just replace my water pump and new Champion radiator. the 1st OPL(looks like a Champin leaked right when new. This one I just installed seems better. I don't think Ill get another Chinese radiator ever again. 1 Quote Link to comment
LilDotty74 Posted May 4, 2020 Author Report Share Posted May 4, 2020 10 minutes ago, banzai510(hainz) said: I got Gatorade bottle Just replace my water pump and new Champion radiator. the 1st OPL(looks like a Champin leaked right when new. This one I just installed seems better. I don't think Ill get another Chinese radiator ever again. I feel that, and the price is not all that different I kinda feel like a cheap bastard for that one, haha but we will see how long my little Chinese radiator will last Quote Link to comment
