Jersey Posted April 23, 2020 Report Share Posted April 23, 2020 10 hours ago, LilDotty74 said: Hope so 160 bucks! Yup, they’re not cheap! 1 1 Quote Link to comment
banzai510(hainz) Posted April 23, 2020 Report Share Posted April 23, 2020 160$ FOR THE PLUG WIRES???? Im mean its a nice cool Red color. I was told by some one that when they put 8.5 mm its just thicker insolation but the core size is the same on wire sets, How true I don't know. Its to prevent arching across each other. Not more or bigger spark. I always thought the 25$ NGK wires set were GOOD I like that Edelbrock fuel pump . you know where it was made? 2 Quote Link to comment
datzenmike Posted April 23, 2020 Report Share Posted April 23, 2020 24 minutes ago, banzai510(hainz) said: 160$ FOR THE PLUG WIRES???? I always thought the 25$ NGK wires set were GOOD They are but shiny lures catch more fishermen than fish. I guess the chev alternator has higher output, how could it not? I like near 90-100 amp. Stops the headlamps from flashing when the turn signal is on at idle, the heater fan is an F3 and the wiper is pounding the A pillar in the rain. 1 Quote Link to comment
LilDotty74 Posted April 23, 2020 Author Report Share Posted April 23, 2020 1 hour ago, datzenmike said: They are but shiny lures catch more fishermen than fish. I guess the chev alternator has higher output, how could it not? I like near 90-100 amp. Stops the headlamps from flashing when the turn signal is on at idle, the heater fan is an F3 and the wiper is pounding the A pillar in the rain. Yeah 80 amps I think 1 Quote Link to comment
LilDotty74 Posted April 23, 2020 Author Report Share Posted April 23, 2020 1 hour ago, banzai510(hainz) said: 160$ FOR THE PLUG WIRES???? Im mean its a nice cool Red color. I was told by some one that when they put 8.5 mm its just thicker insolation but the core size is the same on wire sets, How true I don't know. Its to prevent arching across each other. Not more or bigger spark. I always thought the 25$ NGK wires set were GOOD I like that Edelbrock fuel pump . you know where it was made? I know right, says only difference is low resistance with the ability to express Electromagnetic interface i got the pump from O’Reillys for 60$ 1 Quote Link to comment
LilDotty74 Posted April 23, 2020 Author Report Share Posted April 23, 2020 Got these bad boys just need to blast em and paint em, going with a polished lip and a gold face After blasting 3 Quote Link to comment
5t341tH Posted April 24, 2020 Report Share Posted April 24, 2020 aren't those steel wheels? how are you going to polish the lip 2 Quote Link to comment
LilDotty74 Posted April 24, 2020 Author Report Share Posted April 24, 2020 8 minutes ago, 5t341tH said: aren't those steel wheels? how are you going to polish the lip Just going for a polished look, planning to strip down to metal and clear coat or some kind of aluminum or metallic metal spray 2 Quote Link to comment
Lockleaf Posted April 24, 2020 Report Share Posted April 24, 2020 17 hours ago, 5t341tH said: aren't those steel wheels? how are you going to polish the lip Is there a reason you think steel can't be polished? 3 Quote Link to comment
5t341tH Posted April 25, 2020 Report Share Posted April 25, 2020 3 hours ago, Lockleaf said: Is there a reason you think steel can't be polished? never knew you could polish steel. I assumed it would just rust 2 1 Quote Link to comment
LilDotty74 Posted April 26, 2020 Author Report Share Posted April 26, 2020 Putting in the hours stripping and sanding is a bitch 5 Quote Link to comment
wayno Posted April 26, 2020 Report Share Posted April 26, 2020 That looks pretty good to me. 2 Quote Link to comment
demo243 Posted April 26, 2020 Report Share Posted April 26, 2020 Those wheels look great! 1 Quote Link to comment
LilDotty74 Posted April 26, 2020 Author Report Share Posted April 26, 2020 Awhooga! Yes or no? before after 4 Quote Link to comment
hobospyder Posted April 26, 2020 Report Share Posted April 26, 2020 yes definitely yes and then have a train horn as well if people don't listen to the awooga 2 Quote Link to comment
datzenmike Posted April 26, 2020 Report Share Posted April 26, 2020 Klaxon. Polished steel will still rust. The brighter the shine the slower the rust but it will rust. Clear coat them after. 2 Quote Link to comment
Lockleaf Posted April 26, 2020 Report Share Posted April 26, 2020 Yes, what Mike said. The fact that it woukd rust after doesn't prevent you from polishing it. It just won't be permanent. But neither is any other polishing without further protection. 1 Quote Link to comment
LilDotty74 Posted April 29, 2020 Author Report Share Posted April 29, 2020 (edited) Started dash resto Edited April 29, 2020 by LilDotty74 1 Quote Link to comment
LilDotty74 Posted April 29, 2020 Author Report Share Posted April 29, 2020 Looking better and better lots of sand and fill and made a custom dash plate out of scrap metal 2 Quote Link to comment
LilDotty74 Posted April 29, 2020 Author Report Share Posted April 29, 2020 Talk about ratsun ! Haha 1 Quote Link to comment
LilDotty74 Posted April 29, 2020 Author Report Share Posted April 29, 2020 Final coat and we can start assembly 1 Quote Link to comment
