Control arm shims? WTH??!
530-521
  • Replies 19
There's a lot of other things that will bend before the kingpin.  If the kingpin bends, you won't be able to turn.  Are the wheels straight up and down?  Does it have that many shims on both sides, or just the passenger side?
It's the only way the fronts of these trucks can be adjusted in stock form.  The shims can be purchased in various thicknesses, and other vehicles use the same method, although it seems most newer vehicles have gone to other, more infinitely variable methods, like cam washers.
If it's both sides and the wheels are cambered.....they may have done it to get tires to fit in the fenders.  Doesn't sound like anything is bent.  Kingpins may be really worn.  You'll have to investigate the front end or take it to an alignment shop and let them find any issues and fix them.
When the kingpins wear out, you actually get negative camber, which these shims are also doing, so I'm confused. It's possible that your kingpins are perfectly fine, and they installed these shims to get the front tires to tuck in the fenders like Mike mentioned.
Facing straight ahead on the level... if you can see any camber or toe..... it's too much. These settings are very subtle. On a 14" rim a 1 degree positive camber is sticking out at the top just 0.122"
At stock height, the UCA is angled downward.......so if it was lowered, that would push the top of the rim out and might be why they put the shims in....to pull it inboard to compensate.  Understand, if you can't look at it and figure out why they're there.....it's going to be extremely hard for us to guess at why. :)
