MaddieCycle Posted February 22, 2019 Report Share Posted February 22, 2019 Both of the fender liners are not doing so hot on my truck. Passenger side is completely shredded and the prior owner zip tied them in place. Exposed on the passenger side are two high pressure lines; A/C and power steering, both seem to be floating in this area, without any kind of brace, which is surprising and I assume there used to be something there and it is gone. I can fabricate something but was wondering what is supposed to be there. Also, have not been able to find a source for replacement fender liners. None on e-bay, no trucks in local yards. Any ideas? Thanks! 1 Quote Link to comment
weldingrod Posted February 23, 2019 Report Share Posted February 23, 2019 Don't throw them away. They are what we McGyvers call "patterns". Unless you are totally anal about using factory parts, just get some 1/8" neoprene rubber sheet, cut out some new ones, and install. I generally use rivets instead of those pathetic little plastic body fasteners. 3 Quote Link to comment
Madkaw Posted February 26, 2019 Report Share Posted February 26, 2019 I think I have 20$ in making new ones. Menards sells sheet rubber. GM plastic rivets are 25 cents a piece and work well 2 Quote Link to comment
CicliDevotion Posted February 27, 2019 Report Share Posted February 27, 2019 Any reason not to use a self-tapping sheet metal screw to attach them rather than a plastic rivet? They were originally screwed on with sheet metal screws, yeah? 2 Quote Link to comment
datzenmike Posted February 27, 2019 Report Share Posted February 27, 2019 You could use then but I think they were just push in plastic rivets. Just don't reach in there with bare hands. 2 Quote Link to comment
Charlie69 Posted February 27, 2019 Report Share Posted February 27, 2019 Mike is correct the factory fasteners are plastic push pin rivets. 1 Quote Link to comment
CicliDevotion Posted February 28, 2019 Report Share Posted February 28, 2019 Ahh. Gotcha. My truck is missing the liners...but there are a few sheet metal screws where there used to be some attached. Somebody Mickey Moused the hell outta my poor truck at some point. 2 Quote Link to comment
CicliDevotion Posted April 21, 2019 Report Share Posted April 21, 2019 Can anyone confirm if the liners on 4wd are the same as 2wd? Also do both sides match each other? I have some patterns from a truck but they look pretty different than the homemade shapes I’ve seen, which appear to have a lot more coverage. 1 Quote Link to comment
CicliDevotion Posted May 4, 2019 Report Share Posted May 4, 2019 Bumping this... what size GM body fasteners should I get to attach my liners? Pic, anyone? Are driver and passenger side identical on a 4WD? Same as a 2WD? 1 Quote Link to comment
NC85ST Posted May 11, 2019 Report Share Posted May 11, 2019 Nice work. Turned out great. 1 1 Quote Link to comment
Lockleaf Posted May 12, 2019 Report Share Posted May 12, 2019 Noice! Sometimes just taking a crack at things is the best option even if it goes wrong. A failure on something like this isnt catastrophic just annoying. But looks like you nailed it. 1 Quote Link to comment
bottomwatcher Posted May 12, 2019 Report Share Posted May 12, 2019 So what did you use for material? I know lift lips offered those as a kit for body lifted trucks but those look good. I was going to do the same thing with pond lining material but never got around to it so any tips would be helpful. 1 Quote Link to comment
CicliDevotion Posted May 13, 2019 Report Share Posted May 13, 2019 I used rolled rubber sheeting from Home Depot. I think it’s for under a (carpet) runner and sold by the foot. i had a template that someone sent me for a 2wd truck. I made a couple of mods for more coverage, but the shape is really close to OEM. i opened the holes up a hair and used GM plastic push rivets to hold it in place, as that’s how they were originally installed. We’ll see how they hold up! 1 Quote Link to comment
Madkaw Posted May 13, 2019 Report Share Posted May 13, 2019 I just went to Menards where they have rolls of different kinds of rubber 1 Quote Link to comment
Madkaw Posted May 13, 2019 Report Share Posted May 13, 2019 3 minutes ago, CicliDevotion said: I used rolled rubber sheeting from Home Depot. I think it’s for under a (carpet) runner and sold by the foot. i had a template that someone sent me for a 2wd truck. I made a couple of mods for more coverage, but the shape is really close to OEM. i opened the holes up a hair and used GM plastic push rivets to hold it in place, as that’s how they were originally installed. We’ll see how they hold up! You and I were on the same page - even with the rivets. Opened holes to 1/4” and the cheap GM rivets work great 1 Quote Link to comment
