demo243 Posted December 10, 2019 Report Share Posted December 10, 2019 Did some more searching and looks like that is a SpecD header for a twin cam. Based on some other photos I doubt that particular one will fit with how fat it is down by that 4-1 junction 1 Quote Link to comment
grannyknot Posted December 10, 2019 Report Share Posted December 10, 2019 (edited) Thanks guys, the Megan looks like a good place to start. I noticed it said for a 95-98 S14, my engine came from a 91 S13, do you think there will be any problems? Edited December 10, 2019 by grannyknot 1 Quote Link to comment
demo243 Posted December 11, 2019 Report Share Posted December 11, 2019 (edited) 2 hours ago, grannyknot said: Thanks guys, the Megan looks like a good place to start. I noticed it said for a 95-98 S14, my engine came from a 91 S13, do you think there will be any problems? Both KAs I have are from S13s, and running the Megan Racing shorty header on both no issues Edited December 11, 2019 by demo243 1 Quote Link to comment
grannyknot Posted December 11, 2019 Report Share Posted December 11, 2019 Woohoo, was just on ebay and bought a used Nissan shorty header 14004-70F00 for $140 🤩 1 Quote Link to comment
grannyknot Posted December 18, 2019 Report Share Posted December 18, 2019 I just started cleaning up the MAF and this doesn't seem right, the diameter is 55mm, that seems awfully small for a 2.4L engine. Wondering if it just got thrown in with engine when I bought everything, can anyone confirm if this is the proper unit for a KA24DE? Thanks, Chris 1 Quote Link to comment
grannyknot Posted December 18, 2019 Report Share Posted December 18, 2019 Okay, I just looked it up and it is the right one, this has to be one of those components that get swapped for something larger, just seems so restrictive. Any thoughts? 1 Quote Link to comment
Draker Posted December 19, 2019 Report Share Posted December 19, 2019 5 hours ago, grannyknot said: Okay, I just looked it up and it is the right one, this has to be one of those components that get swapped for something larger, just seems so restrictive. Any thoughts? map sensor conversion possibly, but never really heard of people swapping it. 1 Quote Link to comment
grannyknot Posted December 19, 2019 Report Share Posted December 19, 2019 11 hours ago, Draker said: map sensor conversion possibly, but never really heard of people swapping it. Yes, thinking about that, I did a bunch of reading yesterday about a larger Maf but then you have to use add ons like the Apexi safc and at that point you might as well pull it all and start fresh with a stand alone system. Not sure I'm ready to go that far yet just trying to do any tweaks I can as I put it together, getting it back on the road is the first priority and I can change and restore things as a rolling project. 1 Quote Link to comment
G-Duax Posted December 19, 2019 Report Share Posted December 19, 2019 (edited) Don't knock the Apex-I S-AFC. I've been running one on my Toyota 3-liter all-motor for many years, with the only change to the ECU being different clock crystals to bump the rev limit to 8500. I run a very modified (opened up for more flow) flapper style air meter to make 400 HP. And have helped many other people set up larger Nissan hot wire meters. This is a very popular mod for Nissans, and back when I was importing from Japan sold latterly hundreds of R32 & Q45 MAFs to do just what grannyknot was talking about. But it takes a good tuner, and having a wide band A/F meter to do it right, just like a stand alone. This coming year I am finally going to an AEM Infinity to have better control over ignition timing, and going sequential injection. But keeping the S-AFC in the loop, so minor tweaks won't require carrying a lap-top in the car all the time. Edited December 19, 2019 by G-Duax 1 Quote Link to comment
demo243 Posted December 24, 2019 Report Share Posted December 24, 2019 (edited) What is everyone using for a signal to an aftermarket tach? On my 510 it pulls the signal from the megajolt unit... but on the 620 with an S13 KA24DE I am not getting a signal from the ECU via the yellow/red wire... which means its probably best to run it off the coil - but I am having a hard time tracing that back through the wiring diagram. Edited December 24, 2019 by demo243 1 Quote Link to comment
grannyknot Posted January 3, 2020 Report Share Posted January 3, 2020 On 12/24/2019 at 9:16 AM, demo243 said: What is everyone using for a signal to an aftermarket tach? On my 510 it pulls the signal from the megajolt unit... but on the 620 with an S13 KA24DE I am not getting a signal from the ECU via the yellow/red wire... which means its probably best to run it off the coil - but I am having a hard time tracing that back through the wiring diagram. Are you talking about the KA24DE wiring harness? Because I have mine laid out on the floor right now and I can trace any wire for you if that helps. 1 Quote Link to comment
demo243 Posted January 4, 2020 Report Share Posted January 4, 2020 2 hours ago, grannyknot said: Are you talking about the KA24DE wiring harness? Because I have mine laid out on the floor right now and I can trace any wire for you if that helps. yea KA24de/ECU Wiring harness --- I have the diagram with the pinout which points to the red/yellow tach output... but it doesn work... as many people have said... some say you can use a resistor an make it work... but was hoping for a more simple straightforward solution--- which should be the negative from the coil 1 Quote Link to comment
grannyknot Posted January 4, 2020 Report Share Posted January 4, 2020 Well looking at the coil end of the harness there is a one wire plug 16 ga, solid black, there is a 2 wire plug , both 16 ga, one is green/black stripe, the other is black/red stripe. The third plug is made up of 3 wires, one is 14 ga, green/black stripe, second is a 16 ga white wire and third is a 16 ga black with silver hatch marks. 1 Quote Link to comment
demo243 Posted January 6, 2020 Report Share Posted January 6, 2020 On 1/3/2020 at 9:10 PM, grannyknot said: Well looking at the coil end of the harness there is a one wire plug 16 ga, solid black, there is a 2 wire plug , both 16 ga, one is green/black stripe, the other is black/red stripe. The third plug is made up of 3 wires, one is 14 ga, green/black stripe, second is a 16 ga white wire and third is a 16 ga black with silver hatch marks. 👍 now to see if I can find a color coded wiring diagram 1 Quote Link to comment
grannyknot Posted January 6, 2020 Report Share Posted January 6, 2020 I don't have a colour diagram but do have this one, 1 Quote Link to comment
demo243 Posted January 6, 2020 Report Share Posted January 6, 2020 1 hour ago, grannyknot said: I don't have a colour diagram but do have this one, hmmm not coming out large enough to really read... Found a couple of diagrams on Jim Wolfe's website that spell out the coil negative... but they are for the 95+ S14 KA24DEs... need to do some digging. Here are the links for anyone interested http://jimwolftechnology.com/wolfpdf/DISTRIBUTOR SR KA CHANGE CAR TO EXT COIL AND TRANSISTER.PDF http://jimwolftechnology.com/wolfpdf/MSD TO SR 240SX.PDF 1 Quote Link to comment
grannyknot Posted January 8, 2020 Report Share Posted January 8, 2020 On 1/6/2020 at 9:32 AM, demo243 said: hmmm not coming out large enough to really read... Yeah, not great but there doesn't seem to be much out there, I'll keep digging too. You mention above that you have the pinout diagram, any chance you could share it? It would be nice to have as much info as possible concentrated in this one thread. Thanks 1 Quote Link to comment
demo243 Posted January 8, 2020 Report Share Posted January 8, 2020 This is what I have been referencing https://www.nicoclub.com/archives/240sx-s13-ka24de-ecu-pinout-and-wire-locations.html --- scroll below the adds for a diagram of just the connector with the pin numbers as well. Here are the photos hosted as well --- S13 Diagrams 1 Quote Link to comment
demo243 Posted January 13, 2020 Report Share Posted January 13, 2020 (edited) Double posting here..... First--- The KA in the truck is running SUPER RICH! like dripping fuel rich --- this was dripping out of the header -- not oil - seems to be gas This is the darkest plug This was the lightest I know the Idle Air Control is not working... since It when started it wouldnt hold an idle, had to manually hold the throttle open to get it to run, right now have the the throttle stop opened up to hold idle... shouldnt make it run that rich though.... maybe my O2 sensor? Only have a single one wire O2 running from the #4 cylinder in the header to the ECU... might not be right... Truck drives ok, but does seem to be "smoking" a bit when left to idle.... I dont know if this makes a difference or not... But when I first started it, it was not running this rich... the other weekend when I went to bring it down to get registered I think I ran it out of fuel while pulling it onto the trailer.... thats when it started this "smoking" and puking fuel out of the header thing... Also probably doesnt help that I am currently killing power to the whole truck --- including ecu--- everytime I turn it off --- I am assuming this is reseting the ECU every time Edited January 13, 2020 by demo243 1 Quote Link to comment
demo243 Posted January 13, 2020 Report Share Posted January 13, 2020 Double post # 2 Second thing --- Took some photos of the coil wiring... didnt get a chance to look into anything, but figured it would be worth posting. This is on my S13 KA24DE Need to figure out the best spot to tap into for the negative coil wire for the tach 1 Quote Link to comment
demo243 Posted February 2, 2020 Report Share Posted February 2, 2020 Fyi- Fixed my rich issue with some new injectors- picked em up off Ebay rebuilt from some one with good reviews. Also for anyone looking for a direct from the coil tach signal on an s13 ka24de with the external coil- I used the green and black wire - tapped into it where it was already spliced 2 Quote Link to comment
Rat-a-tat-Dat Posted April 11, 2020 Report Share Posted April 11, 2020 I'll admit that a KA24DE swap is tempting but to put it into perspective terms what is the going price for one of these engines. Albeit the mileage is a factor and general condition should also be taken into account. Here's a scenario as a starting point. S14, comes with tranny, intake manifold, wiring harness, ECU, MAP, etc. roughly 200,000 KM. Say engine is used but still in good shape, cylinder compression is lower but stable across the board. What would be a fair price for this combo? Any educated guesses out there? Quote Link to comment
Rat-a-tat-Dat Posted April 12, 2020 Report Share Posted April 12, 2020 Thanks mhub91 for your feedback. Appreciate it. $500ish USD is roughly $700 CDN. I ask because I have no starting point here. If anything, you don't see these engines up for sale around here much. Mistakingly, you'd think they were made of some rare material. Quote Link to comment
datzenmike Posted April 12, 2020 Report Share Posted April 12, 2020 8 hours ago, Rat-a-tat-Dat said: I ask because I have no starting point here. If anything, you don't see these engines up for sale around here much. There used to be 5 or 6 in a local yard but all scrapped now. All VG maybe one KA. No on has a 25-30 tear old truck. Quote Link to comment
