NC280z
R200 LSD Sanity Check
Greetings all,
I've recently installed a 3.70 R200 clutch-type LSD into my Z, and just need a sanity-check on limited slip diffs. When turning the driveshaft by hand with the car on stands I noticed that both wheels turn in the same direction (as they should), but the drivers side turns at a faster rate than the passenger side. I'm guessing that more rolling resistance on the passenger side is causing it to slip more, am I correct in thinking this? The brakes aren't dragging, and the company I purchased the diff from checked the clutch adjustment and backlash.
I'm chasing down a rear diff clunk that I believe is a bad driveshaft u-joint, and I noticed the aforementioned when checking everything. I've got new diff mounts/straps in place, and all the bolts are buttoned-up nice and tight so it's new u-joints for the halfshafts/driveshaft next.
Share this post
Link to post
I had a clunk on my 280x also and swapped diff also to find out the diff was good(had a shop do this). Its a mount back there somewhere, I sold the car before I fixed it
my u joints were good
Share this post
Link to post
Ah, not in any clutch style R200 LSD I've ever handled.
The Nissan unit has preload springs disks that keep pressure on the plates at all times.
Did you ever open it up before installing it into the housing?
Sounds like it is worn pretty bad.
And a clunk noise may be due to wear also, as the Nissan clutch LSD has a camming effect that puts additional pressure on the plates as the ring gear exerts torque on the LSD.
If they have a lot of wear, they will clunk because the of all the extra distance they have to rotate before they tighten up.
Share this post
Link to post
I've seen open diffs turn together in the same direction before.
No, essentially they are locked together if off the ground. It's tire friction with the road the forces them to slip when going round turns.
Try holding one while turning the other.
Share this post
Link to post
So I held the passenger wheel and the driver side still turned freely, didn't feel the passenger side budge much. Also noticed that the wheels turn in reverse together at the same rate, just not at the same rate forward. I didn't think to open it up prior to installing it, as the gaskets were fresh and I didn't want to redo them. I purchased the unit from California-Datsun via eBay, now I'm guessing that I should've just gone with a decent 3.90 over this one.
Share this post
Link to post
California Datsun...why are we not surprised.  Open it up immediately!
Share this post
Link to post
That explains a lot.........
Share this post
Link to post
Looks like I'll be dropping and swapping this one. Just found some old posts on Cal/Dat's quality and wish I had checked sooner. I appreciate the honest info you've all provided, won't be making this mistake again!!
Share this post
Link to post
OMG. Don't open it. Take it back as is.
Share this post
Link to post
true that
Share this post
Link to post
California Datsun's has had many names over the years.
Share this post
Link to post
If ever in dought,ask us here bout buying from suppliers!! cd prays on those not in the know. But we have all been had at least once. U said u had someone ck it out? Who?
Share this post
Link to post
He said the company he bought the diff from checked it.
Share this post
Link to post
Unfortunately I'm past the 30 day mark for the "warranty" that California Datsun has, so I may be stuck with an inoperable LSD. I'm looking at Whitehead Performance for an open 3.90 as a replacement, as I gave my old 3.54 to a fellow Datsuner.
Share this post
Link to post
Well, if what you have is an actual clutch LSD, there are plates still available.
Take the LSD out, post pictures.
If you don't pull the bearings, and you don't mix the shims up, it's pretty simple to fix a worn clutch style LSD.
Share this post
Link to post
G-Duax, do you know of any good sources for clutch packs? I've searched and most forums show that the stock Nissan CLSD clutch packs are NLA.
Share this post
Link to post
I suspect this will turn out to be a viscous LSD. Which tightens up as it spins more. In theory.
Share this post
Link to post
I had considered that also, but all the information I've seen is pointing to a clutch-type. VLSD's in R200 longnoses are exceedingly rare, save for those few from the late z31 turbo cars. It looks like Whitehead Performance sells and rebuilds the stock Nissan clutch LSDs, so maybe they have the repair kits available.
Share this post
Link to post
Nismo LSDs use the same disks.
And they are the same as in the H190, but that doesn't help, as it's even older (or so people think).
Open it up, see what you find.
Then post pictures.
If the spring plates are broke, I have a couple.
If your plates are worn out of spec., I may have a couple, but I'm sure they can be bought.
Share this post
Link to post
My new R160 has a klunk. Most obvious when shifting under load.
Now I think its in the trans...
Share this post
Link to post
Yes.
(thought I answered this already)
Oh well, getting old is a bitch....
Share this post
Link to post
Yes.
I think he posted in the other thread under h190lsd by accident....
Share this post
Link to post
My apologies! I didn't realize that I had posted to the wrong thread last night. I'll correct.
Share this post
Link to post
No problem, since both diffs take the same plates....
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
