AlexDeLarge Posted January 1, 2017 Report Share Posted January 1, 2017 Hey guys just signed up and wanted to check in. I just got a 1974 Datsun 620 in really solid shape. L18 engine with 120k, previous owner coated all underneath the truck and engine bay and has no rust other than some minor surface spots on body and in bed. Truck has a 78-79 grill and painted front bumper, but I have a new chrome bumper on the way and a mint oem early grill with beauty rings that I will slap on it in the spring. Has Chevy wheels which I will eventually replace along with the mirrors. I want to put some pictures up but I am not seeing a link to do it. I have a small oil leak under the truck which I am thinking either a bad oil pan gasket or gasket on the oil pump. I am also going to replace the base carb gasket this week as I have some air leaking around there causing a bit of rough idle. I am new to the truck and not really a mechanic but am eager to learn a lot with this motor. Couple of questions I have regarding body trim, was the side air vent on the white model truck originally a silver/gray color? Mine are and have seen some pictures online that are the same as mine, but only on white trucks. Fender emblems: I know there are "Datsun" and "Datsun1600" emblems for the 72-77 models, but I have seen a set on ebay advertised for the 620 which are "Datsun1500" which look just like the "Datsun1600" ones. Did a 620 ever come with a "Datsun1500" fender emblem? Anyways, I need a set of correct fender emblems for my truck if anybody has a set. Will get some pictures up when I figure out how. Glad to be here. 1 Quote Link to comment
datzenmike Posted January 2, 2017 Report Share Posted January 2, 2017 Power wash the front. Get the oil pan and timing cover. Spray down with carb cleaner and let dry. Drive around and inspect daily for the source. Oil migrated downward and to an extent, can be forced backward by rad wind. Oil leaks are in rough order of frequency... Valve cover Front pulley crank seal Oil pressure sender Oil pan Fuel pump gaskets Timing cover Rear crank seal Dip stick seal. Loose fram oil filter You will need to get a free Photobucket account and upload your pictures there where they will host them for you.... http://community.ratsun.net/topic/54932-photobucket-ratsun/ ... I always thought the flow through air vents were black, it goes with any color. Never seen gray ones. '73 had... DATSUN1600 (my personal favorite) '74 through '78 had.... DATSUN '79 had DATSUNby NISSAN The '79 emblem marked the beginning of the (soft) transition from Datsun to Nissan by addition of the Nissan name to the Datsun emblem. The 'hard' change was around '82 when all badges were changed over to Nissan, sometimes having a Datsun emblem or decal as well. The last Datsun emblem (I know of) was on the '86 300zx. The DATSUN1500 was the J15 engine used outside N America... maybe south of the border. 1 Quote Link to comment
flatcat19 Posted January 2, 2017 Report Share Posted January 2, 2017 Pics, homie. 1 Quote Link to comment
flatcat19 Posted January 2, 2017 Report Share Posted January 2, 2017 The DATSUN1600 emblems are 521. 620s said DATSUN. At least on American models. 1 Quote Link to comment
Draker Posted January 2, 2017 Report Share Posted January 2, 2017 Welcome! Good intro, but we are gonna need to see this thing. 1 Quote Link to comment
datsunaholic Posted January 2, 2017 Report Share Posted January 2, 2017 The DATSUN1600 emblems are 521. 620s said DATSUN. At least on American models. '73 620s still said DATSUN1600 in the US/Canada. Only that year. Emblems were unique to the US-market '73 620. Datsun 1500 emblems were common in Asia, Europe, Central/South America, etc etc, and can sometimes be found on eBay sold through Thailand (probably cheap repros, though). 1 Quote Link to comment
flatcat19 Posted January 2, 2017 Report Share Posted January 2, 2017 '73 620s still said DATSUN1600 in the US/Canada. Only that year. Emblems were unique to the US-market '73 620. Ko Datsun 1500 emblems were common in Asia, Europe, Central/South America, etc etc, and can sometimes be found on eBay sold through Thailand (probably cheap repros, though). It wasn't the same script as the 521s, was it? I don't think I have ever seen an original L16 620 before. 1 Quote Link to comment
datzenmike Posted January 2, 2017 Report Share Posted January 2, 2017 The DATSUN1600 emblems are 521. 620s said DATSUN. At least on American models. The 521 script was different .... DATSUN 1600 the 620 was tilted slightly DATSUN1600 and the 1600 was much larger than the letters. I think I have a set of both. 1 Quote Link to comment
AlexDeLarge Posted January 2, 2017 Author Report Share Posted January 2, 2017 2 Quote Link to comment
AlexDeLarge Posted January 2, 2017 Author Report Share Posted January 2, 2017 1 Quote Link to comment
flatcat19 Posted January 2, 2017 Report Share Posted January 2, 2017 Shit. That thing is nice. 1 Quote Link to comment
AlexDeLarge Posted January 2, 2017 Author Report Share Posted January 2, 2017 Thanks man, I like it. I'm going to slowly but surely get it the way I want. 2 Quote Link to comment
Draker Posted January 2, 2017 Report Share Posted January 2, 2017 Just needs a little lower.. and done! Looks great! 1 Quote Link to comment
datzenmike Posted January 2, 2017 Report Share Posted January 2, 2017 '74 or older. Yes nice and clean. When you get the badges you want don't drill holes. Use two sides tape. 1 Quote Link to comment
AlexDeLarge Posted January 2, 2017 Author Report Share Posted January 2, 2017 Yes Mike definitely no holes, going to use automotive double sided tape. Thanks for the compliments, hope to learn a lot hrre. 2 Quote Link to comment
Charlie69 Posted January 2, 2017 Report Share Posted January 2, 2017 Great first post. You will find that if you edit you signature from USA to actual city and state you will attract help that is closer to you. Quote Link to comment
AlexDeLarge Posted January 2, 2017 Author Report Share Posted January 2, 2017 Ok, thanks for the info. I am in TN just outside of Knoxville. Quote Link to comment
mcordero8 Posted January 2, 2017 Report Share Posted January 2, 2017 That's a nice solid truck. Take care of her. These trucks are becoming harder and harder to find. Quote Link to comment
sebpv Posted January 2, 2017 Report Share Posted January 2, 2017 i concure with Mike's saying. I did my homework and studied the emblems for a while. I now have a set of Datsun1600 waiting for when the truck is painted. took me 3 years to find them Quote Link to comment
flatcat19 Posted January 2, 2017 Report Share Posted January 2, 2017 I would never have guessed that was a Tennessee truck. 1 Quote Link to comment
hobospyder Posted January 2, 2017 Report Share Posted January 2, 2017 It wasn't the same script as the 521s, was it? I don't think I have ever seen an original L16 620 before. you've driven one. Probably didn't have the badges though Quote Link to comment
125 CSL Posted January 2, 2017 Report Share Posted January 2, 2017 squeeky clean. one heck of a nice find and I am envious. Quote Link to comment
flatcat19 Posted January 2, 2017 Report Share Posted January 2, 2017 you've driven one. Probably didn't have the badges though Me? Drive a 620? Never! You haz no proofs. Quote Link to comment
AlexDeLarge Posted January 2, 2017 Author Report Share Posted January 2, 2017 If I have permission, I'm going to post a wtb in the classifieds for correct side emblems, so if you guys have any leads I would appreciate it. Quote Link to comment
hobospyder Posted January 3, 2017 Report Share Posted January 3, 2017 Me? Drive a 620? Never! You haz no proofs. hmmm.... 3 Quote Link to comment
