wayno Posted July 4, 2019 Report Share Posted July 4, 2019 On 6/30/2019 at 5:07 PM, 320 Newb said: Cab mount question. I know there are round rubber mounts between the cab and chassis but are there also round rubber mounts that go on the underside of the chassis with a big washer? And if so what is the function of those mounts? The rubber isolates the cab from the chassis to keep down noise/vibration, now if you were to just run a bolt thru the cab hole, then thru the rubber mount piece, then thru the chassis hole and put a nut on it and tighten it up all the noise/vibrations will be transferred thru the mount bolt, but if you put a piece of rubber on the bottom side of the chassis with a big washer to not crush the rubber piece in the center, and have the hole in the chassis large enough that the bolt cannot touch the chassis, then the cab is isolated from the chassis and all that noise and vibrations cannot be heard unless some other part of the cab is touching the chassis. This is why the steering column also has rubber pieces isolating it from the cab. 1 1 Quote Link to comment
320 Newb Posted July 21, 2019 Author Report Share Posted July 21, 2019 (edited) Chipping away at putting her back together. Front and back glass back in with 1960s Ford backglass gaskets. The windshield is modern glass cut down from a Jeep Commander windshield--the curve fit perfectly. Got my parking brake back together, dash in, seat in, wiper motor and linkage back in. Has anyone found wiper blades that fit or wiper blades that fit and can be cut down to size? Edited July 21, 2019 by 320 Newb 2 Quote Link to comment
320 Newb Posted July 22, 2019 Author Report Share Posted July 22, 2019 Got my wiper motor and linkage back together and back in with new wiper blades. The wiper blades in the yellow box are a slam dunk. Quote Link to comment
wayno Posted July 22, 2019 Report Share Posted July 22, 2019 I am a little worried, that wiper transmission/assembly appears to be put together wrong in your photo, the way you have it in this photo below the pivots will turn opposite directions, do not turn them on with the wiper arms connected as it could break something, I would not turn it on at all myself. 9 minutes ago, 320 Newb said: Got my wiper motor and linkage back together and back in with new wiper blades. The wiper blades in the yellow box are a slam dunk. Here is what it is supposed to look like, the arm between the 2 pivots is supposed to be parallel with the other piece of metal that holds the pivots in place, you need to fix this before you try to use them wipers. Quote Link to comment
wayno Posted July 23, 2019 Report Share Posted July 23, 2019 (edited) So it appears I had the middle shaft in between the pivots on the wrong side(upper side) when it needed to be on the lower side, the one I took photos of is an extra I have in case one of mine gives up, they are not making them anymore. I wondered about the notches on the center arm, but wasn't really thinking about anything other than him not turning the wipers on as it had been less than 10 minutes since he had posted them photos. I hope he can fix it without having to remove it. Here it is the the drive arm on the proper side of the the transmission drive housing/plate. Edited July 23, 2019 by wayno 1 Quote Link to comment
320 Newb Posted July 23, 2019 Author Report Share Posted July 23, 2019 Thanks for the pics. I don't have the drive arm from the motor connected to the linkage yet so I can still monkey with it. And if I have to take it all apart again it's not the end of the world. 1 Quote Link to comment
wayno Posted July 23, 2019 Report Share Posted July 23, 2019 If the drive arm is not connected yet I suspect you could flip it right over, maybe it would not go in there the way it was and you already flipped it over to install it. 1 Quote Link to comment
320 Newb Posted July 23, 2019 Author Report Share Posted July 23, 2019 Thanks for the heads-up I think I have it sorted out! 1 Quote Link to comment
jetattblue Posted July 23, 2019 Report Share Posted July 23, 2019 Dude! Your truck is looking fantastic. I love the paint color. Justin 1 Quote Link to comment
320 Newb Posted July 24, 2019 Author Report Share Posted July 24, 2019 3 hours ago, jetattblue said: Dude! Your truck is looking fantastic. I love the paint color. Justin Thanks for the kind words. I've been working on it for a couple years and I'm excited to be putting it back together. My goal is to have it finished for my little guy's 5th birthday in November. 2 Quote Link to comment
320 Newb Posted July 26, 2019 Author Report Share Posted July 26, 2019 Cut a slit in the smallest vacuum tube available at a local parts store and used it for molding on the air screen. It snugged it up pretty nicely 3 Quote Link to comment
wayno Posted July 26, 2019 Report Share Posted July 26, 2019 (edited) That looks good but it doesn't function properly, the gasket is supposed to stick up and touch the hood when it is closed. My photos above do not have the gasket that is on the upright seam across the whole back of the hood that completely seals the screen area on all 4 sides. I do not know where one would find the proper gasket for them areas. Edited July 26, 2019 by wayno 1 Quote Link to comment
320 Newb Posted July 26, 2019 Author Report Share Posted July 26, 2019 Yeah mine basically only prevents it from rattling around. That gasket you posted is probably more rare then them damn wing window gaskets. 2 Quote Link to comment
Stoffregen Motorsports Posted July 27, 2019 Report Share Posted July 27, 2019 You may find that you are sucking stinky engine bay air into the cab. Though not an automotive supply, McMaster-Carr has weatherstripping in many different profiles - https://www.mcmaster.com/weatherstripping Also, a simple google search for "automotive weatherstripping profiles" nets many results that may work. 1 Quote Link to comment
320 Newb Posted July 27, 2019 Author Report Share Posted July 27, 2019 4 hours ago, Stoffregen Motorsports said: You may find that you are sucking stinky engine bay air into the cab. Though not an automotive supply, McMaster-Carr has weatherstripping in many different profiles - https://www.mcmaster.com/weatherstripping Also, a simple google search for "automotive weatherstripping profiles" nets many results that may work. Thanks for that link they've got tons of good stuff! I'm on the hunt for a fuel filler grommet, wire harness grommet, etc. and I bet they've got it all. 1 Quote Link to comment
wayno Posted July 27, 2019 Report Share Posted July 27, 2019 A guy down in Orange CA rebuilt his 320 and he used this for his fuel filler grommet, "Steele Rubber Products" part#70-2203-39, I have never bought one so I do not have first hand experience with this part, I just searched it and the grommet showed up so it is a good part number, but it is expensive. 1 Quote Link to comment
320 Newb Posted July 27, 2019 Author Report Share Posted July 27, 2019 Holy cow that thing is listed for $50?! 1 Quote Link to comment
wayno Posted July 27, 2019 Report Share Posted July 27, 2019 (edited) $50.50 is what I seen, I said it was expensive, but it is made for the application, it's listed as "Fuel Filler Neck". Edited July 27, 2019 by wayno 1 Quote Link to comment
320 Newb Posted July 27, 2019 Author Report Share Posted July 27, 2019 Another place that might have one is Moss Motors. My digital calipers broke but once I get another set I'll get good measurements on the opening and fuel neck. 1 Quote Link to comment
thisismatt Posted July 27, 2019 Report Share Posted July 27, 2019 If you cross reference that grommet by the Dodge trucks it's for you can find it for at least half that price. 1 Quote Link to comment
thisismatt Posted July 27, 2019 Report Share Posted July 27, 2019 Now I can't find the one I saw for $25, but this one is close at <$30 https://www.ebay.com/itm/1961-62-63-64-65-66-67-68-69-70-71-Dodge-Truck-FILLER-NECK-GROMMET-Adventurer/362594785191?fits=Make%3ADodge&hash=item546c5557a7:g:xb0AAOxyQqBRHZ~4 1 Quote Link to comment
difrangia Posted July 28, 2019 Report Share Posted July 28, 2019 (edited) Might work for cowl vent screen: https://www.ebay.com/itm/Rubber-Seal-for-Doors-Hatches-Lockers-Enclosures-Cabinets-C011-Per-Foot/141056177863?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Edited July 28, 2019 by difrangia 1 Quote Link to comment
wayno Posted July 28, 2019 Report Share Posted July 28, 2019 I think that gasket would work well for the strip pointed up across the top from fender to fender if it reaches the hood. I am unsure about the other 3 sides of the cowl vent as that gasket actually mounts to the screen itself and the flap that sticks up in the ebay auction would be pointing sideways not up. I just bought eight feet of that stuff, we shall see if it works. 2 Quote Link to comment
320 Newb Posted July 28, 2019 Author Report Share Posted July 28, 2019 1 hour ago, wayno said: I think that gasket would work well for the strip pointed up across the top from fender to fender if it reaches the hood. I am unsure about the other 3 sides of the cowl vent as that gasket actually mounts to the screen itself and the flap that sticks up in the ebay auction would be pointing sideways not up. I just bought eight feet of that stuff, we shall see if it works. Curious to hear if it works! 1 Quote Link to comment
