KlassicMotion Posted December 5, 2013 Report Share Posted December 5, 2013 Are you talking about the "glass run channel"? I got mine from Summit Racing. Part number: IS-GR-17. It's not specifically for the Datsun, but it's the correct shape and "cut-to-fit length".... I haven't installed it yet, but it was the best and least expensive option I could find. **EDITED** There is also this on eBay from siam_motorsparts1982: http://www.ebay.com/itm/221380928910?ssPageName=STRK:MESINDXX:VRI&_trksid=p3984.m1436.l2661 1 Quote Link to comment
mikeanike99 Posted December 9, 2013 Author Report Share Posted December 9, 2013 Are you talking about the "glass run channel"? I got mine from Summit Racing. Part number: IS-GR-17. It's not specifically for the Datsun, but it's the correct shape and "cut-to-fit length".... I haven't installed it yet, but it was the best and least expensive option I could find. Ok let me know how well that fits, Quote Link to comment
KlassicMotion Posted December 14, 2013 Report Share Posted December 14, 2013 Will do, but just so you know, my 620 is on the back burner for right now. It may be a couple weeks. Quote Link to comment
Llittle_Llama Posted December 14, 2013 Report Share Posted December 14, 2013 #yolo? ??? Boy you really confuse me You Only Live Once, it's something the little kids say these days. Quote Link to comment
KlassicMotion Posted December 15, 2013 Report Share Posted December 15, 2013 You Only Live Once, it's something the little kids say these days. Thanks, I had no clue either. Quote Link to comment
mikeanike99 Posted January 5, 2014 Author Report Share Posted January 5, 2014 I just got hit with the realization I am gonna be driving in 10 months... 1 Quote Link to comment
BlackBird620 Posted January 5, 2014 Report Share Posted January 5, 2014 Lol 10 months is plenty of time to have your truck perfect for you mines need down for 8 months getting a ka swap now I'm about to do interior and exhaust Quote Link to comment
denmarkboy Posted January 5, 2014 Report Share Posted January 5, 2014 Hey man , just read thru your post . Props to your family for leading you into a great first rig , the fact your 15 and rockin a 620 ! Nice ! This is a rig you can learn a lot about basic mechanics. And that's when the fun will start,you will wish you had 10 of them, just so you can make them all different. Glad to see you didn't go with the flatbed,but I have see alot of cool things that don't sound normal. I think any direction you take it will be fun in the end. 10 months will fly by can't wait to see where you take it . Quote Link to comment
mikeanike99 Posted January 6, 2014 Author Report Share Posted January 6, 2014 Yeah that ten months will be lots of work on my truck and earning money to get parts Quote Link to comment
TruenoGuy Posted January 6, 2014 Report Share Posted January 6, 2014 Anybody got a sliding rear window for a single cab I got a solid and want a slider will trade my solid for a slider I wish that you lived closer to CO, I want to get rid of my sliding rear glass. Quote Link to comment
mikeanike99 Posted January 7, 2014 Author Report Share Posted January 7, 2014 Got my truck up and running and I realized it doesn't leak oil! 1 Quote Link to comment
mikeanike99 Posted January 7, 2014 Author Report Share Posted January 7, 2014 Nope it leaks oil... 1 Quote Link to comment
KlassicMotion Posted January 7, 2014 Report Share Posted January 7, 2014 lol Not a big deal in a 620. Easy to get to most seals with engine in. Quote Link to comment
mikeanike99 Posted January 7, 2014 Author Report Share Posted January 7, 2014 Yeah I suspect I need to tighten my oil pan bolts Quote Link to comment
mikeanike99 Posted January 7, 2014 Author Report Share Posted January 7, 2014 As that is where the oil is coming from Quote Link to comment
Aibast Posted January 7, 2014 Report Share Posted January 7, 2014 I suggest to remove the oilpan (you can also clean out any dirt that are in there) - but on new seal and retighten. Works better than tightening the polts. I think the seal doesn't cost anything. Quote Link to comment
KlassicMotion Posted January 7, 2014 Report Share Posted January 7, 2014 Check to see if your rear main seal is leaking too. Mine is both the pan and rear main seal. It doesn't look to difficult to just pull the trans, drop the pan and do both at the same time. Clutch too while I'm at it.... I hate doing things twice, so it would bother me to put a new pan gasket on, only to find out I've got to remove it to fix a rear main seal leak. Quote Link to comment
mikeanike99 Posted January 7, 2014 Author Report Share Posted January 7, 2014 Thanks for the tips, should I get the seal from rockauto? Quote Link to comment
KlassicMotion Posted January 7, 2014 Report Share Posted January 7, 2014 I get my seals from Nissan, and they work beautifully. There is a definite difference. My second choices are Felpro or National. Quote Link to comment
mikeanike99 Posted January 7, 2014 Author Report Share Posted January 7, 2014 Thanks for the advice I will hopefully be ordering one soon Quote Link to comment
mikeanike99 Posted January 8, 2014 Author Report Share Posted January 8, 2014 I found out that my heater works, but the low setting doesn't the high setting does Quote Link to comment
KlassicMotion Posted January 8, 2014 Report Share Posted January 8, 2014 I found out that my heater works, but the low setting doesn't the high setting does Your talking about the fan, correct? Clean all your electrical connections and then check the relay (link below). The relay in my '73 is on the passenger inner fender near the hood hinge. http://community.ratsun.net/topic/58498-how-to-repair-your-relays/ Quote Link to comment
mikeanike99 Posted January 9, 2014 Author Report Share Posted January 9, 2014 Yeah, but I probably won't e using the low setting so it doesn't matter Quote Link to comment
mikeanike99 Posted January 13, 2014 Author Report Share Posted January 13, 2014 Looking for a set of 8 spoke steelies if anybody's has some forsale or finds some for cheap please let me know Quote Link to comment
willz Posted January 13, 2014 Report Share Posted January 13, 2014 why not look for a set of some rally's off of a chevy? Quote Link to comment
