KlassicMotion Posted October 7, 2013 Report Share Posted October 7, 2013 I like turbine wheels. They look good on your truck. Just a suggestion, but you could take some black spray paint and darken in your grill area. I like semi flat black. Quote Link to comment
GRpufnstuf Posted October 7, 2013 Report Share Posted October 7, 2013 Those wheels look great! What size? 15x8. What's the tire size? Quote Link to comment
jastrunk97 Posted October 7, 2013 Report Share Posted October 7, 2013 They are 15x8 with 215/65/15 on the front and 225/65/15 on the rear. Quote Link to comment
mikeanike99 Posted October 7, 2013 Author Report Share Posted October 7, 2013 My trucks looks like a hot wheel :P Quote Link to comment
GRpufnstuf Posted October 8, 2013 Report Share Posted October 8, 2013 I just unboxed my new carrier and bearing from Rock Auto. I ordered the DEA part and a National Bearing part. DEA is $22 http://www.rockauto.com/catalog/moreinfo.php?pk=4375947&cc=1210093 National is $34 The DEA part looked like just the rubber on the Rock auto site but it turns out its a bearing and carrier rubber for $22 +shipping. The bearing feels just ok but it barely experiences a load and the rubber is what fails first (typically) The National part is a bearing only so pretty useless as there isn't a carrier rubber listed for sale on Rock Auto. I'll be returning it. The next cheapest part is in the $60 range made by Timken. I like Timken but I'm going to try the DEA part because it's a cheap experiment. 1 Quote Link to comment
mikeanike99 Posted October 8, 2013 Author Report Share Posted October 8, 2013 I think the parts truck we have has good rubber I will check today. Quote Link to comment
mikeanike99 Posted October 8, 2013 Author Report Share Posted October 8, 2013 Sad face it ripped up as well guess I need to get a new rubber from A.rock auto or B.do what pdx Matt did. Quote Link to comment
mikeanike99 Posted October 14, 2013 Author Report Share Posted October 14, 2013 Got a coil spring booster today gonna install it tomorrow. Thinking about put the stock steelies back on. But need to get new hubcaps cause the ones I have are beat to heck and super dinged up. And my gas tank has a massive dent in it that I need to fix somehow any tips on how to do that? Quote Link to comment
KlassicMotion Posted October 14, 2013 Report Share Posted October 14, 2013 And my gas tank has a massive dent in it that I need to fix somehow any tips on how to do that? Either a suction cup style dent puller, or pop the sending unit out and push the dent back out with a wood rod (if reachable). Or, empty the tank and throw a match down it..... :no: Quote Link to comment
mikeanike99 Posted October 14, 2013 Author Report Share Posted October 14, 2013 I have a dent puller and could drain my tank pull it and weld the hole up. Quote Link to comment
Hooligan Posted October 14, 2013 Report Share Posted October 14, 2013 Be very careful welding a gas tank. Fumes are your worst enemy... I have done a couple at work but they have to be completely rinsed (super clean) and completely aired out Quote Link to comment
GRpufnstuf Posted October 14, 2013 Report Share Posted October 14, 2013 Do not weld on an empty gas tank. Unless its been sitting, open for a long time. There will be residual fumes for a long time. They will ignite and you will lose a gas tank and at least your hair. I had an old school radiator guy fix a tank for me A few years ago at Mac's Radiator in Portland. He filled it with water and left the hose running in it and then welded on it. It was amazing to see, I'll never try it. You should be able to get a good piece of wood in there and shove on that dent. Metal rod runs the risk of poking thru I'd think. How big is the dent? Do you really need to fix it? Quote Link to comment
BlackBird620 Posted October 14, 2013 Report Share Posted October 14, 2013 The guys that turn old propane tanks into BBQ pits run a hose to the exhaust from a car into it and let in run for about 15min before starting the first cut or weld Quote Link to comment
mikeanike99 Posted October 14, 2013 Author Report Share Posted October 14, 2013 The dent is pretty big il get some pics up later today. Quote Link to comment
mikeanike99 Posted October 14, 2013 Author Report Share Posted October 14, 2013 I'm thinking about just leaving my tank dented. Any thoughts otherwise? Quote Link to comment
420n620 Posted October 14, 2013 Report Share Posted October 14, 2013 U got a toilet plunger ? that might work. Just clean & wet the area before you use it Quote Link to comment
mikeanike99 Posted October 14, 2013 Author Report Share Posted October 14, 2013 Maybe Quote Link to comment
mikeanike99 Posted October 14, 2013 Author Report Share Posted October 14, 2013 I have 521 fedish I want a 521 so bad I wanted one to be my first car but my 620 won because I had the option and money. Also I need to think of a name for my truck any ideas? Quote Link to comment
Hooligan Posted October 15, 2013 Report Share Posted October 15, 2013 Snowflake Quote Link to comment
KlassicMotion Posted October 15, 2013 Report Share Posted October 15, 2013 Ratflake Quote Link to comment
jastrunk97 Posted October 15, 2013 Report Share Posted October 15, 2013 Mouse-rat, Rat-mouse, HorseShoeHorror, Rat, Mr. Pickles, TheChickDiggenMachine, TimeKiller, MoneyBags, MoneyPit.....List goes on Quote Link to comment
mikeanike99 Posted October 15, 2013 Author Report Share Posted October 15, 2013 mr rusty. Rust-rat. Rat-rust. White lantern. O'l rusty. Rusty Kreme. S.S. rust bucket. Rusty. White rust. RustFlake. Krispy rust. Revlon. Beast mobile. Any other ideas? Quote Link to comment
mikeanike99 Posted October 15, 2013 Author Report Share Posted October 15, 2013 Rust rod. Rust-sun. Ratty. Rat-a-tat. Rustafir. Smokey. Bandit. Smokey and the bandit. Quote Link to comment
420n620 Posted October 15, 2013 Report Share Posted October 15, 2013 a few come to mind. Rat Trap Lab-Rat Quote Link to comment
mikeanike99 Posted October 16, 2013 Author Report Share Posted October 16, 2013 I think I'm gonna name my truck rust-sun. Quote Link to comment
