nl320what Posted May 26, 2015 Report Share Posted May 26, 2015 Your plans sound pretty good, c-notch requires some engineering and knowledge. Remember, it affects your shock mounts and normally have to remove all the smaller leafs in the springs or go with a 4-link to get that low. I see what your doing, keeping the flatbed low to make loading easier. Make the flatbed as big as possible for more room, room for a quad and a tool box/gas can area. Quote Link to comment
datzenmike Posted May 26, 2015 Report Share Posted May 26, 2015 Don't remove springs. Find a way around this. Two reasons... It's the springs that give lateral stability. Remove them, and the remaining ones can allow the axle to shift sideways shredding tire and fenders. A panhard bar would be advisable. Less springs are softer and the truck will travel farther on bumps and dips. Never a good idea on a vehicle that's been lowered closer to the pavement. Have the arch removed from the springs and add a leaf to firm them even more. Quote Link to comment
sebpv Posted May 26, 2015 Report Share Posted May 26, 2015 or add airbags and a 4-link if u want to notch the frame Quote Link to comment
mikeanike99 Posted May 26, 2015 Author Report Share Posted May 26, 2015 i want it to be a 4x4..... Quote Link to comment
hobospyder Posted May 26, 2015 Report Share Posted May 26, 2015 You've gone up and down Mike, I think the last plan in the thread was go down and buy another to 4x4. Maybe update with current plans so people don't get confused? Quote Link to comment
mikeanike99 Posted May 26, 2015 Author Report Share Posted May 26, 2015 my plans tho i doubt it will actually happen is to put either toyota or samurai axles under it and either a toyota drive train or a sami t case. Quote Link to comment
mikeanike99 Posted October 2, 2015 Author Report Share Posted October 2, 2015 anyone know if the wheel cylinders are left/right specific in the rear? rock-auto doesn't show a left or right rear wheel cylinder it just says rear.... Quote Link to comment
5t341tH Posted October 3, 2015 Report Share Posted October 3, 2015 They are same. I got mine from rockauto as well Quote Link to comment
mikeanike99 Posted October 3, 2015 Author Report Share Posted October 3, 2015 awesome Quote Link to comment
mikeanike99 Posted May 23, 2016 Author Report Share Posted May 23, 2016 oh boy what a while it has been...truck is currently lifted with 30" wildcats...trying to decide if i want to do a ka24e swap or vg30e...i have almost everything for the vg so might go that route Quote Link to comment
mikeanike99 Posted May 23, 2016 Author Report Share Posted May 23, 2016 put disc brakes on the front yesterday...and also a weber side draft with a cannon intake.. Quote Link to comment
hobospyder Posted May 23, 2016 Report Share Posted May 23, 2016 Holy hell you're still alive. You know what I'm gonna ask fir, where they at? Quote Link to comment
mikeanike99 Posted May 24, 2016 Author Report Share Posted May 24, 2016 ill get some oics up later....also gonna be putting a vg30e in my rig here soon Quote Link to comment
mikeanike99 Posted May 24, 2016 Author Report Share Posted May 24, 2016 just took the wildcats off tho...rubbed bad Quote Link to comment
mikeanike99 Posted May 27, 2016 Author Report Share Posted May 27, 2016 oics! well only a few but some! just got some new AT's Quote Link to comment
