72.5 datsun 620 project lucy
mikeanike99
  • Replies 414
Took my lowering blocks out of my truck to day and need to raise the front up getting wheels and tires Saturday and outing those on it will be awesome but I went to move my truck and it would start it cranked and cranked fried up them died and won't start so I will tackle that Saturday aswell
used to happen to mine.  my hot wire at the starter end would always get loose, gummed up or just loose connection and I was to broke to fix it.  new starter and hot wire fixed it.  I would say check your fusable link but if the dome light works im not sure.  just check all your connections
I had the same issue.  Mine was a loose connection at the fusible link off the positive terminal at the battery.  It was in this mess with all the PO's bad connections:
I soldered new wires and a fusible link in, and all was good again.  Check these, if that doesn't fix it, move further down the circuit and check for more loose connections.  Check the connections at your starter, ignition switch, and fuse block and fuses.
