70 521 "lina bear"
konig209
  • Replies 705
None of the above.and there is 1/8th steel plate welded to that pan.
What i meant was this truck was falling into pieces. The vibrations and bouncing around as a daily broke allot of parts.
Engine mount snapped missing 1 bolt too.
Trans mount only had 1 bolt
Oil pan is paper thin with small leak.
Trans had 2 of 4 bolts
Starter had 1 of 2 bolts
The list goes on.
No....2 bottom bolts fell off the trans to engine. When ide press the clutch it would split it open. Causing the trans input shaft to bend. Well that destroyed the pilot bushing and seems to have warped the hole in the crank as well. Drove like this for about 1 month with lost bolts. And about 3 months with bent shaft.
  • 3 months later...
  • 5 weeks later...
