70 521 "lina bear"
konig209
  • Replies 705
Ill do front when all 4 are ready to mount. Ill roll the fenders then. But first i need 3 more new tires.
And every suspention piece is going to be new.
On their way to me. My dad is bringing new moog king pins and suspention links as we speak. :)
Post up the Moog part# please.
All the same as a 620 .........
Center link Moog #DS846
Idler Moog #K9058
Drivers Tie Rod Assembly AC Delco #45A2013
Passenger Tie Rod Assembly Moog #ES2339A
Moog can be bought direct or from Rock Auto. AC Delco at Rock Auto as well.
You put your time into it you should get something for it.  If I need any in the future I will contact you by PM if that is OK. I do not mind paying you extra for parts I can not source elsewhere.  even with you making some it would still be cheaper than Singapore.
So i finally got my parts.
If anyone wants any let me know. Try to guestimate prices at the moment but they change alot ok. And wont be able to get some for a while.
king pin sets.
$125
Tie rod ends and center link bar 1 complete unit.
$140
Idler arm
$120
Not sure the name but the end links from idler to knuckle with 2 tie rod looking ends
$75 each.
like i said these are rough prices with changes all the time.
all have grease nipples as well.
king pin sets.
$125
$140
Idler arm
$120
$75 each.
Should check rockauto and crossreference part numbers to summit or somewhere else.  A lot cheaper...
That may be.  When I ordered I got the idler & tie rod ends (not complete assemblies).  There was a delay on the center link and I ended up canceling that since I'm going to be using 720 parts anyways.  For reference, the 521 idler (moog) was $39.97 shipped from summit, who just dropped shipped from moog directly anyways.
  • 3 weeks later...
