Oldy but a goodie for a youngster
  • Replies 265
Should be setup pretty similar to the truck box, just laying on it's side.
If you haven't seen this.... http://community.ratsun.net/topic/46635-steering-column-modifications-mklotz70/   ....give it a look.  You'll see that the worm gear is a piece that's welded onto the end of the steering shaft.  An expert welder(jesusno2?) could weld one on from a right hand drive box......saving a ton in shipping.  I used to think that the worm gear could get cut off, flipped and welded back on, but it won't change the spiral.  I've owned a right hand drive vehicle before........got that out of my system. :)
Don't think I am going to go right hand on this. The dash would be a mess to flip. As its welded in place.
When I was dreaming of putting something bigger under the hood of my 59 I remember thinking about one of these Atom. The Wizard Steer Clear. It is pricy though! I've seen some hotrod guys make their own out of bicycle sprockets and a bike chain! (scary)
Though U joints might get you there. Maybe fab some sort of column drop too?
http://wizardsteerclear.com
...so sweet!!!!
..oh....and I'm not a fan of driving RHD rigs.....been there, done that......got it out of my system when I was 19. I've never had the desire to have another.....but they look cool :)
Well then ill just mirror image the photos when it's done! Hahaha
I cleaned and sealed the floor pans today. Re sealed factory seems. I hope this thing floats when I am done. Also seam sealed the seat pan welds top and bottom. And clean and coated some of the under carriage. I ran out of paint so I will have to get some more sealer to finish the undercarriage and inner fire wall once it's done. I wanted to get the welds sealed up and clean up some of the surface rust while I am sealing something else anyways.
22A90004-19EB-44CB-91D7-46550181AF81-184
16CDD612-7DD2-49FE-87DA-CC00EBB50C96-184
3F4825E0-BB1A-4F88-A322-6931AEBD3546-184
This is a bad photo but I clean an sealed the inside of the roof also.
