spec-bre Posted October 1, 2012 Report Share Posted October 1, 2012 Guy's I am in need of info ASAP in regards to an issue I am having. I have a race on Sunday I am wanting to make. I bought a TGI air cleaner for my Mikuni's and it will not clear the rear air horn due to the master res. I have seen a larger single res setup on another car on this forum but can't locate it now. What one do I need and is it a direct swap??? Thanks for any info you can give me!! Quote Link to comment
D52E Posted October 1, 2012 Report Share Posted October 1, 2012 This is not for a single reservoir master but an idea another member had for a shorter master cylinder. Its on the 510Realm about 1/2 way down the page. http://the510realm.com/viewtopic.php?f=27&t=10313&hilit=whitebird&start=30 Quote Link to comment
datzenmike Posted October 1, 2012 Report Share Posted October 1, 2012 I would find a way around this somehow. In a single master system any, I mean ANY, leak or loss of pressure affects the whole system. The brake peddle goes to the floor and .... nothing. There's no feeling quite like expecting brakes and they aren't there. Quote Link to comment
datsunaholic Posted October 2, 2012 Report Share Posted October 2, 2012 Well, there's a difference between single-reservoir and single-circuit. A number of modern vehicles have a single reservoir feeding both pistons of a dual-circuit master. But, that being said, the reservoir is gonna be even BIGGER than what you have. Really, what you have to do is make the air cleaner fit. You already have the tiny OEM reservoirs. The only other solution is to go remote-reservoir. I've seen it done on 240-280Zs that were built for racing. But if you really were trying to use a single-circuit master (single piston, single circuit) master like the older 60s Datsuns or trucks, BAD idea. Wouldn't pass tech (or shouldn't) and you'd then need a proportioning valve and all sorts of mods, and then have a 50% more unsafe system. Quote Link to comment
banzai510(hainz) Posted October 2, 2012 Report Share Posted October 2, 2012 I had one of those singe SSS type but sold it. Just run the foam sock type. I dont run them on my yellow car can you trim the horns on a disc sander???????? My 44ss with Nismo the rear horn was right up on the blled screw. I hit it with a disc sander at work. Quote Link to comment
DISLEXICDIME Posted October 2, 2012 Report Share Posted October 2, 2012 if you go find a reservoir relocate from a mid 80's/90's chrysler mitsubishi minvan pick up starion conquest k car it will relocate your reservoir like this one phil maid from parts in my garage not sure if it will work for dual carb's we did it so the fluid was farther from the turbo Quote Link to comment
MikeRL411 Posted October 2, 2012 Report Share Posted October 2, 2012 For what it's worth. The NISMO catalogs listed P/Ns 46010-N0110, Single brake master cylinder and the required 46255-21005 Brake tube connector which adapted the single fluid outlet to the dual brake tubing of the standard 510s. Factory authorized and fully functional replacement designed to accomodate the dual SU on 510 engine. A possible alternate might be to use a 310 roadster brake master cylinder and have a brake line adapter made up. Datsunparts.com lists many roadster brake parts including a "wrong side outlet" master cylinder for the roadster which was just perfect for my RL411. See what they offer! Quote Link to comment
spec-bre Posted October 2, 2012 Author Report Share Posted October 2, 2012 Thanks for all the feedback!! I did not concider the downside of a single master. If a remote unit would work I would go that rought but I still think it would be an issue... I've temporarily solved the issue so I can race on sunday. I unbolted the master and moved it to the side enough to get the breather on. I'm going to refrain from modifying the air horns. Breather is what it is. Not a fan of the socks. I had them on my SU's and hated the look. It's a race car but I still would like it to look clean. I'm most likely going to look into a willwood setup or other alternatives for the long haul. I'll try and link more pics. Quote Link to comment
DISLEXICDIME Posted October 2, 2012 Report Share Posted October 2, 2012 this is the only pic i could find of how phil mounted the reservoir http://community.ratsun.net/topic/14286-phils-510-2-door-the-tranny-68/page__st__240 it is the 4th pic from the bottom Quote Link to comment
Jesse C. Posted October 2, 2012 Report Share Posted October 2, 2012 I have a single res unit for the SSS conversion and I think I also have the brass block for the lines. Interested? Quote Link to comment
Ranman72 Posted October 3, 2012 Report Share Posted October 3, 2012 Guy's I am in need of info ASAP in regards to an issue I am having. I have a race on Sunday I am wanting to make. I bought a TGI air cleaner for my Mikuni's and it will not clear the rear air horn due to the master res. I have seen a larger single res setup on another car on this forum but can't locate it now. What one do I need and is it a direct swap??? Thanks for any info you can give me!! just run a remote reservoir looks like there is room for that Quote Link to comment
Ranman72 Posted October 3, 2012 Report Share Posted October 3, 2012 you could also do a reverse under dash master with remote reservoir Quote Link to comment
bonvo Posted October 3, 2012 Report Share Posted October 3, 2012 just run a remote reservoir looks like there is room for that i agree with this if i remeber right 80s toyotas did this Quote Link to comment
