What I'm working with!
uberkevin
  • Replies 3.2k
Make sure you grease the new cover. It is the ways for the throw-out bearing. Looks like there wasn't any lube and the friction was pulling the cover around when you used the clutch.
That's a nice bead.
Thanks guys! Definitely going to keep working on it, watch a video or two maybe.. lol. I had the father in law tell me a few things he could remember so that was nice.
And Draker, high on square tubing you mean right?
Sometimes I can't tell if I need to speed up my movement and the wire feed.
More like the concave example but all are acceptable. Sometimes when the weld is more convex you lose penetration. But your weld is very acceptable. My welding teacher would have graded a B+ to A- I think. I got a B+ in that class.. so I'm right there with ya.
  • Like 4
I'm planning on doing the same thing.. but mine will probably be quite a bit more ghetto.
This was cheap! 35 bucks shipped.
I paid something like 25 bucks for some welding magnets, and a few bucks for some wire. I jumped,kicked, hit with a hammer and these welds didn't brake. So I'll see what happens when I put the DE on.
Found a valve cover while I wait for the one from Jrock.
Imy an odd person and kinda don't wanna reuse the oil pump on the motor.. even tho I know it was a runner.. after I put this front cover on getting a new one came to mind..
Oh... and I happen to get a DZ push to start button..
Gotta fix my ign harness before installing that. Need a new stock plug.
  • Like 3
Clearly new sparkplug wires/plugs oh and thermostat, temp sensor.
I'll probably end up building some type of stand or something to hold some shit like the battery. Find a way to route the fuel pump. Oh I guess I've gotta find a alternator plug cuz Im definitely not going to cut mine from the truck harness.
Lets hear it run!
I'll definitely be setting up the gopro once I'm there. I've gotta go pick up a alt plug from a junkyard and wire everything up. Had to make my alt bracket fit.flywheel is on just need to double check torque on front pulley and the flywheel.. I've got a ton of oil around the house so I'll be using some fresh oil often. Lol
Also I've got some diesel oil that's okay to use right?
15w-40 ROTELLA T.
Ive only bought Royal Purple once and that was for gear oil..
We have a Ford diesel here and for some reason we have two 5 gallon buckets of it.. also some other oils.
I've heard of people using it before but I thought id ask.
I was thinking the same thing, I wasn't sure I needed the alternator hooked up. But that's why I asked to find out forsure.
However..
I have no clue what's up with my harness. Haha of course..
Here what's up.
No plug for this on my harness..
No knock sensor clip
Also the red temp sensor.
Now what I don't understand is why the fuck wouldn't my harness have these!
Another set back... for now.
