Australian goon makeover
  • Replies 162
No velocity stacks ( yet).
These filters came with the carbies so will keep them till I find a decent set of what we call ram tubes.
Will eventually be running foam filters on them.
Nothing! Beats the sound of twin side draughts on an L series motor IMLTHO.
looking very good! go the ram tubes.
also how goods Melbourne Bitter!
Thanks mate!, pretty happy with how the linkages came out.
As my beer fridge would attest.
Melbourne bitter, the beer for any discerning (Aussie) Datto enthusiast.
Sadly, I sense the fridge will be emptied tonite :)
What are those carbs????? Dellortos?????????
alot of the old school Mada Rotary guys know Dellortos
Not much after market here anymore on those.
Yep, twin 45 dellortos on an Australian "Datrally" manifold.
Wanted webers, but these came up at the right price and also were off an almost identical spec motor to mine so that was a bit of a bonus.
Sound like webers under full throttle which is good enough for me !
Been a little while since I've provided an update.
Postman delivered these the other day.
Given them a clean up.
This afternoons job is to clean up all the threads, and give the jets etc a clean in the ultrasonic cleaner.
Came off a similar spec motor to the goon, so, hopefully instant get up and go when they are bolted up.
how did you clean these, im guessing soda blasting or something like that.
Lucky enough to have a bead blaster. It uses glass silica microspheres which, after stuff is degreased and dried, produces the results pictured.
Very happy with how stuff comes out of it, Christ, I bloody well bead blast everything these days :)
Following on from some of the great rising sun paint jobs I've seen on some of the US cars on Ratsun, decided to start small and do my air cleaner covers. Pretty happy with my first attempt, results below. Masking them up was a PITA though !
You should have polished the covers, masked them in rising sun, and then bead blasted them.
Thought about it, but, the chrome plating underneath was absolutely fucked!
I've got a buffing wheel on one of my grinders.
Did the whole clean up and polishing process but there was just too much pitting in the chrome plate.
Even after a good session in the bead blaster it still looked like shit.
There's a fair bit of what we call " spray bog" or spray can body filler (I think you call body filler bondo?) underneath that paint job.
Can't find my brake line flaring kit to make the lines for the big brakes (must be with the stash of number plates)'so in my hungover state, decided to bolt the 240K struts back in so I can get her driveable again.
Adjustable control arms have given the goon some serious negative camber !
Took it for a quick spin around the block before and even with a quick home made wheel alignment it turns in beautifully.
Quick coat of Matt black paint for the bonnet.
Spring has finally arrived here and today's weather is awesome so in addition to getting the goon driveable again, working on the tar in the back. What a Cnut of a job, this shit is piled on thick and everywhere!
Twin dellortos have also made a difference :)
ugh! I hate that tar, and someone added it the back floor in your goon! I don't envy you that job at all..
If I could get my hands on the fuckwit who applied it I would gleefully choke the life out of them.
I weighed what I have scraped out so far (by my estimate about 30% of the shit).
Came to just a touch over two kilos !
Quick clean up of the wiper motor and a bit of faux carbon fibre stick on for some bling.
Starting on the strut brace.
Front piece is a main rotor housing brace off a squirrel helicopter. Been carting it round for nearly 17 years and thought I should use it on something.
And my wife says I never use anything I collect :)
It's something different. The ones i got were being thrown out because of minor scratches on the surface(s).
A no no on an aircraft component as you would appreciate.
Have to try and fit the oven in this pigsty.
I have faith I'll make it fit :)
Rear section of brace tacked up.
Time to weld it up and start on the mounting brackets for the front part of the brace.
Nice day here, I'm off work for another month so, in celebration it's time for.
Mmmmmm beer, only in moderation of course ;)
