AZhitman Posted June 6, 2012 Report Share Posted June 6, 2012 Hey guys - Getting my 510 reassembled, and considering making a little more room for more tire. However, the body / paintwork is already done, and the inner fender lip on the sedan seems pretty beefy. I've got a fender roller, but I wanted to see what everyone else has done on theirs before i go bending s*** and making a mess. Suggestions / experience? Thanks all! Quote Link to comment
Dime Dave Posted June 6, 2012 Report Share Posted June 6, 2012 On the 510 there is a ridge inside the rear wheel well above the fender lip. This bulges inward and can be a clearance issue as well. I flattened mine out on my racecar with a scissor jack and a hammer. That was after getting hit by a Chevy Monza. I didn't have to worry about the paint at that point so my procedure was pretty crude. The biggest trick with finished bodywork is to use a heat gun to warm the paint and make it more flexable. Not too much heat, you don't want to lift or burn the paint. Most of the guys that rent out fender rollers ship them with a heat gun or suggest using one to help keep from damaging the paint. Good luck. 1 Quote Link to comment
dennis Posted June 7, 2012 Report Share Posted June 7, 2012 I rolled mine with a 2.5" steel pipe, I didnt use heat because I didnt care about my paint. Once I rolled it I then used a hammer and dolly to flatten out the lips, this gave me an additional 2 - 4mm of clearance. Quote Link to comment
AZhitman Posted June 8, 2012 Author Report Share Posted June 8, 2012 ^ Thx, but that doesn't help me any. I'm pretty adept with a fender roller (I have an Eastwood unit), but the 510 sedan rear fender is a different beast. Anyone have any other experience with doing it successfully? Quote Link to comment
Laecaon Posted June 8, 2012 Report Share Posted June 8, 2012 Are you talking about the lip, or the "step"? Because each are a different approach. Quote Link to comment
AZhitman Posted June 8, 2012 Author Report Share Posted June 8, 2012 The lip. The "step" has been removed, reinforced, re-welded, and smoothed on mine. Quote Link to comment
Z chopper Posted June 8, 2012 Report Share Posted June 8, 2012 when you do this take lots of pics, I think Jun did it to his goon Quote Link to comment
AZhitman Posted June 21, 2012 Author Report Share Posted June 21, 2012 Anyone? I know there's some flush-fitting sedans here on Ratsun.... Quote Link to comment
INDY510 Posted June 21, 2012 Report Share Posted June 21, 2012 . Tell me the offsets, wheel size, tire size, and rear camber correction mods, if any ... .. and I can tell you if you even need to roll the fenders ....... I've used a baseball bat before, or floor jack handle ........ I've also made a small score with a cut off wheel,,, but that's looked down upon .... :lol: Not like my cars have good paint,,,, but I HATE the pulled fender look ..... . and it doesn't take much to tweak the whole rear quarter even with a mild roll Quote Link to comment
AZhitman Posted June 21, 2012 Author Report Share Posted June 21, 2012 Everything's put together - I don't currently *need* a roll. However, I'd like to go about 5-10mm wider in the rear track. Like I said, I know how to roll fenders, I own a roller - I'm just asking if anyone's tackled rolling the double-walled lip, and if so, how they went about it. The steel seems pretty damn thick back there. Quote Link to comment
INDY510 Posted June 21, 2012 Report Share Posted June 21, 2012 . Is this a 4dr?? ..... 2dr's don't have that extra metal in the arches ...... . . . I've never rolled a 4dr ,,, but I have tried to remove the "bump" just above the inner fender lips, on my red 4dr .... to tuck the extra 10mm ..... and failed miserably,, bendeing and warping the rear quarter panel ....... .. because that "bump" is the rear door jam,,, and alot of overlapping structural seams You can fit a 16x8 +10 and 215/40 rear tires about 2mm away from that bump: Quote Link to comment
HAM8URGER Posted September 13, 2013 Report Share Posted September 13, 2013 Hey so on my 2 door, I've done a HEALTHY roll on all of my fenders with a roller and heat gun, they turned out perfect but I'm having rub issues on the "ridge" or "bump" you guys are referring to up inside the rear fender. How are you guys flattening that thing out? Or is there some other way to get rid of it without jacking up the quarter? Quote Link to comment
KyushaKai Posted September 14, 2013 Report Share Posted September 14, 2013 http://community.ratsun.net/topic/56468-4-drs-and-wgns-who-went-wide/ Here you go buddy. I still gotta do mine. Quote Link to comment
Just Joel Posted September 14, 2013 Report Share Posted September 14, 2013 Guna need to cut and weld... the paint doesn't do well ;) Quote Link to comment
Just Joel Posted September 14, 2013 Report Share Posted September 14, 2013 Wait, you have a two door... you don't have that bump Quote Link to comment
Dime Dave Posted September 14, 2013 Report Share Posted September 14, 2013 2 or 4 door it doesn't matter, the bump in the inner fender is the same. The outer half of the inner fender is the same part on both the 2 & 4 door. Quote Link to comment
HAM8URGER Posted September 14, 2013 Report Share Posted September 14, 2013 http://community.ratsun.net/topic/56468-4-drs-and-wgns-who-went-wide/ Here you go buddy. I still gotta do mine. Thanks. Looks like a solid way to go Quote Link to comment
Just Joel Posted September 14, 2013 Report Share Posted September 14, 2013 2 or 4 door it doesn't matter, the bump in the inner fender is the same. The outer half of the inner fender is the same part on both the 2 & 4 door. interesting... the part I cut out (see thread above) I thought only occurred in wagons and for doors. Quote Link to comment
datsunfreak Posted September 23, 2013 Report Share Posted September 23, 2013 2 or 4 door it doesn't matter, the bump in the inner fender is the same. The outer half of the inner fender is the same part on both the 2 & 4 door. I've owned 12 different 2dr 510s. Rolled the lips on all of them. Never seen that step on any of them. All 3 of my 4drs and all 3 of my wagons had it though... Quote Link to comment
datsunfreak Posted September 23, 2013 Report Share Posted September 23, 2013 Oh, and I always use a wooden baseball bat. Seems to damage the paint less. :rofl: Quote Link to comment
Ranman72 Posted September 23, 2013 Report Share Posted September 23, 2013 I had a guy do mine cuz I was scared to crack the paint he used a heat gun carefully but it softens the paint and maybe slightly the metal do baby steps a little at a time this guy had done alot and it took him at least 2 hours for both sides [/u RL] Quote Link to comment
macgyver Posted October 4, 2013 Report Share Posted October 4, 2013 Question for you experienced long time owners My car had metal flares/roll done way back when, but left the that 90 degree bump on the Inner side fender. So I cut it out.:) behind that was my outer "new" metal flare. My question is do you guys think I need to weld up/ fill that gap? or since there was metal construction done to build the flares out that seam sealer would be enough? to me(IMO) it's looks and feels super solid. Thanks Maybe should've started a separate thread? Sorry if I hijacked. Quote Link to comment
datsunfreak Posted October 4, 2013 Report Share Posted October 4, 2013 My question is do you guys think I need to weld up/ fill that gap? Yes, you do. B) Quote Link to comment
macgyver Posted October 4, 2013 Report Share Posted October 4, 2013 Damn... With all the extra metal a PO did I was hoping I was good to go... Put it on the list...:/ Quote Link to comment
