pl521sss
Part numbers
matching rubber cup parts for door trim clips:
Share this post
Link to post
Not sure if it's been posted but the interior light is still available from Nissan as of 10/1/2012. The only difference is that it comes with a clear lens compared to the white lens I have seen on some 510's.
Part Number is 2641029R01
Transmission bushing at bottom of 280Z shifter - believed to fit many Datsuns - part no 32861-N4200
Share this post
Link to post
620 Heater control valves part no-27027-B5000 still available 1/23/2013
E15F38C8-EFB2-4542-AA09-3B0156776899-110
Share this post
Link to post
Also timing pointer believed to fit many engines L20b, Z20, Z22, and Z24 (not L16 I think).
AFBD4B11-006C-45D3-B944-2401BCEBE6E6-110
Share this post
Link to post
L series 4 cylinder engine block breather screen - 11037-21001
6D2872D5-0D66-478B-8E1B-8B0B97606194-281
Share this post
Link to post
^ now even I think that's taking it a bit far...and I thought I was the resident homer :rofl:
Share this post
Link to post
Brake and clutch pedal pads 46531-78500
2DDF0087-50E4-4BE7-8F31-5F96BC837E21-606
Door Switches for early 510 25360-N4400
B14F5E34-C932-443F-9F63-6DAB5D3BA3CA-606
Share this post
Link to post
Speedo Sleeve & Blue Pinion... parts are for a '79 810 has an 18 tooth assembly...
THIS... 32703-78102..... 18 tooth pinion gear FITS INTO THIS...32707-R5600..... pinion sleeve assy [for speedometer pinions with 16 to 19]
I used the above parts to fix my '79 620 5-speed.  I have no idea if it originally came with a 5-speed or if trans is from a different vehicle. :)
Share this post
Link to post
Distributor Cap - Part Number 22162-19M01
Distributor Rotor Part Number 22157-U6091
Share this post
Link to post
I have full part list of every model, pm of you need part numbers
Share this post
Link to post
PN# 25360-N4400 door switch are they still available, will those written with 71 240z and if so what are you asking for them
Share this post
Link to post
If looking to buy and/or sell it must be in the ... http://community.ratsun.net/classifieds/category/7-electrical/?sort_key=date_added&sort_order=desc  ... forums. The forums are just that...... a place for discussion and information sharing.
PN# 25360-N4400 is a passenger side door switch for the interior lamp. This one was only used on the mid year '75 and up 280z. and has a single wire with the switch being grounded to the body. Similar year 710, 610, 620 maybe and likely others, have them but two wires with a separate ground. You find one, you can just use a self tapping screw to ground the wire.
Share this post
Link to post
Hello there,
Was looking in the part # thread for info but couldn't find what I needed.
Hoping someone can help.
I have an original item in NGP package that states:"NISSAN SASH-BACK WINDO" with part#79710-21001
Could you please tell me what it is for?
Thanks!
Angela
Share this post
Link to post
From what I can find this part # is for the weather strip for the back window of a Sedan.
Share this post
Link to post
That's what I was told but I wasn't sure.
Do you happen to know if it matters between 2 & 4 door sedans? And just to be clear, that's a 510 sedan, correct?
Thanks a bunch Kelmo!
Share this post
Link to post
79710-21001 - 510 rear windshield, 2-door & 4-door are the same.  It should have the groove to accept the stainless trim.
Share this post
Link to post
What they said.
Share this post
Link to post
Would you happen to have that fuel sending unit for the Patrols (17291-44002)? Thanks
Share this post
Link to post
This post is about part numbers. I can confirm that number 17291-44002 is the fuel sending unit used in the Patrol to 12 '72, about $50 but I doubt they are available.
Share this post
Link to post
